How to go about lifting and adding 17's to 2020 tacoma sr5 2WD?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TinyBoyTacoma, Jul 24, 2024.
  1. Jul 24, 2024 at 5:07 PM
    TinyBoyTacoma
    TinyBoyTacoma [OP] New Member
    Cody
    2020 Tacoma SR5 2WD
    My Taco is completely stock and is sort of a pavement princess but I occasionally hit the mountains and trails for hiking/camping. I want a slight lift on it, thinking of 2" spacer in front and 1" block in rear to level it a bit but Im wondering what yalls take is on spacers? From what I gather, seems like 2" spacers or less are pretty safe when you want to keep the integrity of the way it drives while stock. Also spacers and blocks just seem affordable.
    Also, where in the world do you go to get spacers installed? Do I just buy them online and find a dude with a shop that will do it or does anyone have experience with a more legit business like Les Schwab or something similar? Thanks in advanced.
    Extra credit: if anyone can recommend a slightly bigger/more aggressive tire that would accommodate my lift, id appreciate it! My stock tires are wimpy as heck looking. Not looking for anything that overly compensates, just a slight all terrain upgrade.
    Tocamo likes this.
  2. Jul 24, 2024 at 5:24 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Spend a tad more and get a 2" Bilstein 5100 shocks up front, and a 1" rear block.
    265/75/16 or 265/70/17 Duratracs are the mist aggressive A/T tire.
  3. Jul 24, 2024 at 6:09 PM
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    You can run 17” with no changes. There are stock 15, 16,17,18” rims… it’s the tire size (diameter and width) that matters. Stock size for 17” is 265/265/17. Spacers are used to correct aftermarket rim offset or tire width issues, so again aren’t typically needed unless you go extra wide or have an offset issue to correct.
  4. Jul 24, 2024 at 6:27 PM
    TinyBoyTacoma
    Cody
    2020 Tacoma SR5 2WD
    Seems like the shocks you mentioned generally come with both front & back shocks as opposed to just the front. Can you point me in the direction of finding just the front? Also wondering if you think some 2" spacers could do the job instead since I can't stress enough how little off roading I would do. I baby my Taco, my wife even makes fun of me for how slow I pass over speed bumps lol
  5. Jul 24, 2024 at 6:33 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    If on a budget spacers will work but not optimal. If you can set aside enough to get the bilstein 5100 lift I would especially if you plan on keeping it for a long time.
    NoOne likes this.
  6. Jul 25, 2024 at 8:42 AM
    SlippRott
    SlippRott Well-Known Member
    22 Silver OR
    Planning...suspension, front slimline bumper, winch, full skids, 2" lift, SCS Ray 10's, Pizza cutters, Power Tray, Switch-Pro, Alu-Cab Contour Canopy.
    Spacers are for Mall Crawlers only. If you are doing any off roading and you don't want your spine sticking through the back of your neck when you are done on the trails then just save up for a set of Bilstein 5100's all around. They are only like $200 each and it will be a night and day difference. They would be considered the entry model for off-roading but they are highly capable regardless. There are a thousand Youtube videos on install, it is NOT hard. I am not a car guy and I did all of mine including new rear springs, U-Bolt flip Kit and bump stops. And I am about to put on 17's (just ordered Ray 10's) with Pizza Cutters (Falken AT4W 255/80 R17). This is basically a 33" tire which will also provide about 1" lift and should fit without any mods or minor mods (Some people have had slight rubbing but was easily fixed with heat gun). I've been studying this for over a year on TW and have read just about every post there is. The amount of information here is crazy if you have the time and tenacity to read it all.
    Note: I did not do 510O's but rather 6112's up front and 5160's in rear on my Tacoma. That was about a $2k upgrade. Love it! I did put 5100's on my Sequoia however and they are awesome also.
  7. Jul 25, 2024 at 12:32 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You can buy the shocks individually. The ride quality is 100% better than a spacer lift. If you baby your Taco, you'll appreciate the nice ride over a spacer lift ride. Your front brake dive also disappears with the 5100's.
    Another thing you could do is just raise the 5100's 1" up front and avoid the block in the rear altogether. Still looks lifted @ 1"
  8. Jul 25, 2024 at 4:25 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    For tires a ~32" tire (265/75R16 or 265/70R17) will fit fine with no modifications needed and minimal performance loss.
    I would just find a way to set aside whatever money is needed for a budget friendly suspension swap like B5100s or similar vs a spacer lift if you plan to lift all around. Up front a small top spacer (0.5") to help level is probably fine if that's all you want but anything more IMO and you'll end up regretting it long term. Spacer blocks in the back make you lose suspension down travel if you don't also change to appropriately sized shocks, and coil top spacers in the front either risk bottom the shock or require extended bump stops that cost you uptravel and make you hit the bump stops much more often. Both of which result in more wear and tear on the suspension and worse ride quality, more so during even mild offroading.
    I used to run rear 1" rear blocks with a 1" front preload spacer and 0.5" top spacer (Wescott lift), and in my experience it objectively made the truck worse other than it sitting higher with slightly better ground clearance and looking cooler. You don't need to spend an arm and a leg on suspension like Fox or Kings, but something more budget friendly and scaled to your actual use like B5100s or TRD lift will be much better than just spacers alone.
