How To Grease The ICON Delta Joint.
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Apr 30, 2020.
  1. Apr 30, 2020 at 11:46 AM
    Icon_Adrian
    Icon_Adrian [OP] Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
    imjustabill1970, Law950 and livpool14 like this.
  2. May 13, 2020 at 3:47 PM
    Tacompa
    Tacompa Well-Known Member
    San Jose, CA
    2019 Toyota Tacoma OR DCSB 4x4
    Thanks or the video. What is the recommended grease for the UCA bushings?
  3. May 13, 2020 at 3:58 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    NLGI#2
  4. May 13, 2020 at 4:02 PM
    Tacompa
    San Jose, CA
    I could use schaeffer 221 on both the UCA bushing and the Delta Joint? I thought the polyurethane bushings required silicone based synthetic grease? Could I use the schaeffer 274 for both?
  5. May 21, 2020 at 6:07 PM
    TWTaco
    Dave
    Whats the size of the o-rings for the screw down caps?
  6. May 21, 2020 at 6:13 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Shouldn't use Schaeffer 221 because it contains molybdenum disulfide, which likes to absorb water and turn into sulfuric acid. Just use a non-moly NLGI #2 grease.
  7. May 21, 2020 at 6:57 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I have never heard of MoS2 absorbing water and turning into Sulfuric acid. Can you give me your sources?
  8. May 21, 2020 at 7:16 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
  9. May 22, 2020 at 6:20 AM
    Tacorific
    NE Iowa
    I'm not trying to argue or discredit in any way, I'm trying to get educated.
    I read the summary of the "Chapter 15 Corrosion and fretting" but was unable to read the entire chapter. If I understand it correctly, the corrosion sited is caused from "dry film" MoS2. I have also read of suspected corrosion from dry film MoS2 in gun barrels. Doesn't dispersing the MoS2 in oil (and therefore grease) prevent the compound from causing corrosion?
    Edit: In no way am I advocating the use of MoS2 greases on UCA bushings.
  10. May 22, 2020 at 10:40 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    I'm no chemist, just going by what I read in the tribology books. Remember grease degrades. From what I see at work (aviation i.e. cutthroat maintenance cost control) parts lubricated with MoS2-fortified grease do exhibit more corrosion than with the same grease without MoS2.
    Tacorific[QUOTED] likes this.
  11. May 22, 2020 at 5:52 PM
    Tacompa
    San Jose, CA
    What grease would you suggest for the ICON UCAs and DJ?
  12. May 22, 2020 at 6:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Use whatever major-brand NLGI #2 grease that happens to be available at your local store. Mobil Unirex EP 2, Lucas X-tra, Shell GADUS S5 V100 2... If your front driveshaft U-joints still have zerks, you can use the same grease there.
    Tacompa[QUOTED] likes this.
  13. Oct 10, 2020 at 9:47 PM
    Tacompa
    San Jose, CA
  14. Feb 22, 2021 at 3:12 PM
    SpudGT
    SpudGT Well-Known Member
    Burt
    Boise, ID
    2021 Taco
    Would Lucas Red N Tacky #2 be OK to use in the Icon Delta Joint? Already using this grease on things like bushings. Looking at the label it says "NLGI", so maybe that's not so good.
    Lucas X-tra says NLGI #2.
    If it has to be NLGI #2, maybe it's time to buy a second grease gun to have both types ready to go.
  15. Feb 23, 2021 at 7:46 PM
    Tacompa
    San Jose, CA
  16. Feb 23, 2021 at 7:54 PM
    Tacompa
    San Jose, CA
    I have two grease guns. One with superlube for the bushings and one with the moly grease for the DJs.
  17. Aug 8, 2021 at 11:11 AM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    I just finished installing my delta joint UCAs. Do they need to be greased or are they ready to roll?
  18. Dec 22, 2021 at 9:37 AM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    For the upper zerk fittings, after lowering the vehicle, what are the torque specs on the bolts that needed to be loosened prior to greasing?
    Also, is it the same kind of grease as the DJ in the first video?
    https://youtu.be/DzM-tTI1qII
    Thanks!
