how to hook up an air compressor
Discussion in 'Technical Chat' started by gualter, Apr 27, 2013.
  1. Apr 27, 2013 at 3:34 PM
    gualter
    gualter [OP] New Member
    ca
    2006 supersport d-cab
    hi I'm trying to hook up air lift on board system stuck on wire harness
  2. Apr 27, 2013 at 3:49 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    I'm sort of doing something similar, but I'm not getting enough info from your post. It might help if you put in some more detail.
    I installed the ARB on board air compressor, put the switch in the dash, and wired everything up, hooked up the harness to the battery, but I forgot to pull power from the fuse board to the switch itself. D'oh!
    If you look on the interwebz, you might be able to find the ARB diagram for installing the OBA. The diagram that I'm thinking of showed how to hook it up to the solenoid for the air lockers, too.
  3. Apr 28, 2013 at 2:07 PM
    BamaToy1997
    Bill
    Navarre, FL
    X2
    More information on what you are needing would be best. We have no idea what help you are wanting.
