How to identify what to cut (285s + lift)
Discussion in 'Wheels & Tires' started by SCFirefighter, Dec 15, 2011.
  1. Dec 15, 2011 at 5:55 PM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Title says it all. I put on new shoes but they do rub a little on full lock, and reverse. Since I can't be under the fender and drive it at the same time, how do I figure it out?
    I may be overcomplicating things.
    Also, how come driving backwards causes rubbing but the same stretch driving forward doesn't? I don't understand how driving backwards changes the geometry to cause rubbing.
  2. Dec 15, 2011 at 5:58 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Turn to about 90% of the way to full lock and get out and look.
    Then turn it the other way.
    The places where it's really close, will rub.
  3. Dec 15, 2011 at 6:04 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Or you just find yourself a friend to look lol... bit rub marks will be there
  4. Dec 15, 2011 at 6:18 PM
    jandrews
    '09 FourDubDee TRD OR
    Step 1 is to find a location where you can flex the suspension. Or a forklift.
    Flex it out at 25%, 50, 75, and full lock in one direction. Check both sides for contact during each flex. Most common areas are fender flare, fender liner, cab mount, frame, UCA, LCA. Mark your areas for trimming.
    The metal stuff you can't really do anything about other than the cab mount. It can be chopped and plated. The frame and control arms are more complicated.
    The plastic stuff can be trimmed with dykes, a grinder with a cutting wheel, hell even cuts-all scissors. Once you expose the pinch weld, you may very well get contact there too. Best way to handle that is to beat it flat with a hammer....4lb. sledge or so seems to work pretty well.
    Repeat all this for steering in the other direction.
    Note that trimming the fender liner opens some pockets between the sheetmetal panels that the front tires will essentially throw dirt, rocks, mud, etc. into. Pay special attention to cleaning here when washing the truck after wheelin'. No sense in letting the crud build up in there.
    If you expose any metal during your trimming, be sure to re-seal it from the environment somehow (rattle can paint, RTV, whatever you like) to prevent rust.
    The rear doesn't steer, so that's a little easier. Just completely stuff each side and trim anything you're contacting.
    Questions welcome.
  5. Dec 15, 2011 at 7:31 PM
    SCFirefighter
    Stephan
    Cary, NC
    Thanks for the suggestions. Now can anyone shed some light on why driving in reverse on a straight causes rubbing while driving forward on the same stretch does not? Makes zero sense to me.
  6. Dec 15, 2011 at 7:41 PM
    SCFirefighter
    Stephan
    Cary, NC
    I wonder if it would be worth to push my adjustable toytec coilovers a little higher to avoid the rubbing.
    Maybe find the point where alignment becomes an issue and then go back a turn or so.
  7. Dec 15, 2011 at 7:42 PM
    jandrews
    It's probably rubbing in both directions, but going in reverse the tire treads are catching an edge in the plastic/metal/etc. and making a much louder noise, making it more noticeable.
    Puts your CV boots at a little more risk, if that's a worry to you.
    Plus, that really won't help rubbing when the suspension articulates.
  8. Dec 15, 2011 at 7:46 PM
    SCFirefighter
    Stephan
    Cary, NC
    Good points. Thanks, again.
  9. Dec 15, 2011 at 7:49 PM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    I have 265/70 17 with 1.25" spacers, had tons of rubbing. Took my wheels off and went to town with a dremel, trimmed the exterior fenders plus took out most of the black lining. Took a 16 lbs sledge to the pinch weld and I am all set. Also set my 5100s to 1.75 to avoid can mount rub, still rubs slightly when flexed or wheel is cut 100%.
    Went wheeling last weekend with no real issues.
  10. Dec 15, 2011 at 7:51 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    265/70s with lots of rubbing? Sounds like your wheels already had ideal backspacing, and they are being pushed out too far by using the 1.25" spacer.
  11. Dec 15, 2011 at 7:55 PM
    jandrews
    x2.
  12. Dec 15, 2011 at 8:03 PM
    bgsmith
    Brian
    Hingham, MA
    Slight wheel rub on the calipers, so rather than grind them down I got spacers.
  13. Dec 15, 2011 at 8:04 PM
    TexasTacoma37
    Ah...you might want to try a thinner spacer. As thin as possible.
  14. Dec 15, 2011 at 8:06 PM
    jandrews
    Fixed that for ya.
  15. Dec 15, 2011 at 8:08 PM
    TexasTacoma37
    I disagree, I personally would never remove any material from something that is there for my safety.
  16. Dec 15, 2011 at 8:09 PM
    jandrews
    Like your brake rotors that wear down as you use your brakes? Or your brake pads?
    Grinding the calipers involves knocking off the casted lettering on the outside of the caliper in most cases. It's not even structural.
  17. Dec 15, 2011 at 8:11 PM
    TexasTacoma37
    Correct, I would never take a grinder to my rotors or to my brake pads either.
    Why not just buy the correct wheels that fit the truck?
  18. Dec 15, 2011 at 8:14 PM
    jandrews
    No need - they're self grinding :laugh:
    Also a sensible solution, but he could grind the calipers without spending hundreds of dollars. And it wouldn't affect his safety one whit.
  19. Dec 15, 2011 at 8:16 PM
    TexasTacoma37
    I didn't tell him not to do it, I said I would never personally do it. And you changed my quote to say I would...false advertising :D
  20. Dec 15, 2011 at 8:18 PM
    jandrews
    I changed your quote to make you suggest to him he do it, not to make you say you would do it.
    You fibber! :p
