How to increase payload
Discussion in 'New Members' started by amanzin, Jul 12, 2019.
  1. Jul 12, 2019 at 9:52 PM
    amanzin
    amanzin [OP] New Member
    2015 Tacoma Off-Road
    I am maxing out my Tacoma's payload capacity (~1100 lbs) with cargo in the bed. What modifications could bring the payload up significantly, say to 2000 lbs? Has anyone been able to achieve this?
  2. Jul 12, 2019 at 9:55 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Im sure heavy duty leaf springs would help a ton, but you have to remember that the bed is a composite plastic, NOT metal. Therefore, it’s not as strong. Why do you need to increase your payload? You’re better off using a trailer than stuffing your bed full of heavy stuff.
  3. Jul 12, 2019 at 9:57 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Trailer.
    You cant increase the rated payload without new components such as frame bracing, suspension upgrades, bigger rear end.
    You can improve how the truck handles load by upgrading springs, or adding airbags. But your truck wont be a 1 Ton unless you do some work and spend $$$$$.
  4. Jul 12, 2019 at 9:58 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
  5. Jul 12, 2019 at 9:58 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Long run, trailer will be cheaper and cause less damage to the truck...
  6. Jul 12, 2019 at 10:01 PM
    Bishop84
    Bishop84 Well-Known Member
    You may read into a lot of false information, but the payload is in fact determined by structure, axle, suspension, and brakes. Upgrading springs will make it sag less, but the truck isn't designed for it.
    I've overloaded an F150 with air-ride to 2200lbs (wet soil is heavy!!!) and it wasn't even remotely safe. I hit a bump and thought the truck was going to flip over.
  7. Jul 12, 2019 at 10:01 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Feel like this is a Friday post....
    Taco critter, windsor and whatstcp like this.
  8. Jul 13, 2019 at 6:20 AM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    irayfz6 and buckhuntin-tacoma like this.
  9. Jul 13, 2019 at 6:27 AM
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    I have hauled an 1800 pound load of copper scrap in my 4 banger. It was a fun trip down the mountain to the scrap yard. The truck will do it, not recommended but for me it was worth it cashing in...
    irayfz6 likes this.
  10. Jul 13, 2019 at 11:53 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6 likes this.
  11. Jul 13, 2019 at 12:04 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Air bags, helper springs and a trailer, or buy a full sized truck
    irayfz6 likes this.
  12. Jul 13, 2019 at 12:14 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Buy a bigger truck, or a trailer. FWIW very few 1/2 ton trucks are rated for 2000 lbs and some 3/4 tons are not. You probably need a trailer.
    There is no way to safely or legally increase payload above what is on the sticker. Modifying the suspension or adding air bags etc. will help improve ride when loaded right up to max, but they won't increase what you can haul. The trucks frame, suspension, brakes, and steering are all designed to work at no more than the weight listed on it. Just because you're able to modify things so it sits level with 2000 lbs in the bed changes nothing.
    There has probably never been a truck that wasn't overloaded at some point. For short distances on rare occasions going over by a couple of hundred pounds probably won't break anything if you drive carefully. But if you need to haul that much it ain't safe to do in a Tacoma.
    ColoradoTJ likes this.
  13. Jul 14, 2019 at 3:29 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  14. Aug 12, 2019 at 11:13 PM
    amanzin
    Thanks for the replies, guys. Tell me what you think of this: A friend of mine told me that everything is essentially the same--besides cosmetics--between the Tacoma and the Hilux. Tacoma has a payload of ~1100-1400lbs, depending on bed length. The Hilux specs says its payload is 1040 KILOGRAMS, i.e, 2,300 lbs. So do Americans just get the toy version of the truck, and Europeans, the real thing? Or are the trucks the same, but Toyota thinks they have to tell Americans the rating is lower for liability purposes?
  15. Aug 12, 2019 at 11:32 PM
    Fishious
    Fishious Master Researcher
    Arizona | Utah
    2022 Trail Edition
    Damn. That difference is insane.
  16. Aug 12, 2019 at 11:57 PM
    Tsinajinii
    Tsinajinii Black Wood Streak People
    Jamin
    AZ
    2011 DCLB 4x4 TRD Sport
    OME 885's paired to Bilstien 5100's, LR UCA's, OME Dakars w/ 5160's, Debadged Tailgate, TRD Stickers Removed, ARE Topper, Tailgate Theft Deterrent Mod, Mobtown Tailgate Skin, Light Bar in Hood Skewp, VIAIR OBA, Diaz Fabrication - T.H.R.B., Always on Cig. Outlet, BAMF behind the grill light mount with KC HiLites Pro Halogens, KC HiLites Flex ditch lights
    I don’t think that the differences between the Tacoma & Hilux are only cosmetic.
    If I’m not mistaken, the Hilux has a fully boxed frame (adding to payload capacity).
    I wouldn’t be surprised if it also had a different rear axle (for example, an axle with full-floating shafts, which would greatly improve payload capability).
    And I doubt that the Hilux’s rear springs are the same as the Tacoma (which wouldn’t be hard to beat the Tacoma’s payload capabilities).
    The Tacoma has been tailored to the North American market and doesn’t necessarily need to be competitive in the payload department since there are so many full size options (including the Tundra) that are available in the US.
    4RunninInATacoWorld likes this.
  17. Aug 13, 2019 at 12:01 AM
    Tsinajinii
    Jamin
    AZ
    Before the arrival of the Tacoma in 1995, the Toyota pickups sold here in the US were essentially the same as the Hilux in the rest of the world, but once we received the Tacoma the similarities with the Hilux started to change.
  18. Aug 13, 2019 at 4:32 PM
    amanzin
    Interesting. The Tundra though, is a large but still light truck, with only 1600 lbs payload capacity.
    It seems like there is no small-medium size (Tacoma-sized), heavy duty truck in the US. So disappointing, because that's exactly what I need for my business, and trailers aren't really feasible for me.
