How to install a 2009+ OEM Radio w/AUX-IN in 2005-2008 Tacoma
Discussion in 'Audio & Video' started by billyjoe, Jan 14, 2011.
  1. Aug 15, 2011 at 8:38 AM
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    It was wired for JBL already. A few things did surprise me though. When they added bluetooth in 2009 they also updated the amplifier. Since the speed sensor and bluetooth voice input all run through the amplifier I thought I would need to update that as well. This was not the case. I used the same pin configuration from the FSM and was pretty excited when that obnoxious loud voice from the bluetooth radio started shouting instructions to me. I have a pretty scattered/unorganized thread about all the stuff I did to make the BT work here if you are interested.
    I could definitely see where a JBL harness would be very handy for someone who wanted to upgrade. I have seen head unit and amplifier combos go for pretty cheap. It kind of reminds me of this pdf installation I saw for tundras. I attached it in case you haven't seen it yet. It basically goes through the steps for upgrading a tundra that did not come with a separate amplifier to a nav unit which requires a separate amplifier.
    One request though... How do you find part numbers for the harness pins? I had a few extra that I swiped from a wrecked tacoma but I didn't know what I was looking for at the time. They work for now but I would like to get the right ones eventually.
  2. Aug 15, 2011 at 8:49 PM
    billyjoe
    billyjoe [OP] Taco Fever - I've got it bad!
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Extang Trifecta Tonneau
    Reference the Connector List and Part Number Of Connectors sections of the OEM Wiring Manual (see link below). Then, cross-reference connector part # in the Toyota Wire Harness Repair Manual (see link below) to get corresponding Wire/Terminal part #.
    2005 Toyota Tacoma OEM Wiring Manual:
    http://www.customtacos.com/tech/files/05FSM/wiring.html
    Toyota Wire Harness Repair Manual:
    http://www.scribd.com/doc/21980878/Toyota-Wire-Harness-Repair
    For 2009+ connectors/terminals, I usually subscribe to Toyota TIS for 2 days ($15) and reference their interactive EWDs.
    Toyota Technical Information System (TIS):
    http://techinfo.toyota.com
  3. Jan 21, 2012 at 1:07 PM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
  4. Aug 8, 2012 at 9:46 AM
    Jeromes
    Jeromes Member
    Western NC
    White Tacoma Double Cab
    Do you know why the OEM Aux-In Jack has the two resistors in place? I have done the same type of mod to a number of Subarus (installed newer radio with aux in capability) and made up a aux in harness that had a single wire that you connected directly to ground to enable the aux input on the radio. Not sure why the radio would want to see a 15.05K resistor if the aux cable was not inserted in the jack and then a 2.76K resistance when the cable was inserted in the jack.
    I have a 2011 non JBL radio that I will install in a 06 tacoma. My plan was to add the necessary pins to the existing 20 pin connector to bring out the aux connector to a standard stereo plug and connect the AUXI signal (Conn R3-19) to AGND (Conn R2-18).
    Do you see any issue with doing this?
    Thanks
  5. Aug 8, 2012 at 11:12 AM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    As stated in NOTES:
    1. Internal switch (in jack module) closes when audio plug inserted.
    Resistors R1 & R2 are then in parallel (2.76k), pulling AUX-In
    Enable signal (AUXI) low, signaling radio that AUX-In is active,
    automatically selecting AUX-In as source.
    Yes, grounding the AUXI signal will permanantly enable the AUX in port. Obviously, this is not ideal considering you have several sources (AM/FM/SAT/CD).
  6. Aug 8, 2012 at 11:25 AM
    Jeromes
    Jeromes Member
    Western NC
    All i can guess is that the radio prefers to not see a open circuit when the aux plug is not inserted (i.e. 15K resistor), and that the parallel combination of 2.76K pulls the signal low enough to enable the radio.
    I do not have the external aux jack (yet). I will take a 3.5mm harness, attach pins to the right & left audio, and the shield. connect them to the correct pins in the existing 20 pin connector in the truck. add a 2.76K resistor to two pins and add that to the existing connector pins 19 and 18. That will enable the aux input all the time. This would mean that I might have to touch the aux/disc button two times to select the aux input if I have a disc in the unit.
  7. Dec 27, 2012 at 10:19 AM
    nrojay
    nrojay Active Member
    PARIS, TX
    05 tacoma
    was you able to perform this mod ?
  8. Mar 8, 2018 at 7:38 AM
    the macf
    the macf Well-Known Member
    Daily Driver - 09 RCLB Barcelona Red base, Sold - 08 BSP X-Runner TRD SC 332rwhp
    Subbing for my 09 base.
  9. Mar 8, 2018 at 9:35 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    the macf[QUOTED] likes this.
