How to install a Old Man Emu Lift on Tacoma Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Low Range Off-Road, Mar 27, 2017.
  1. Mar 27, 2017 at 3:56 PM
    Low Range Off-Road
    Low Range Off-Road [OP] Well-Known Member
    Here is the Video for the installation of a Old Man Emu Lift Kit
    Components List:
    • 2887 - Old Man Emu Coil Spring (Free Height 400mm | Spring Rate 590lbs)
    • 90021 - Front Old Man Emu Nitrocharger Sport Struts x2
    • CS047R - Rear Old Man Emu Leaf Springs x2
    • 60091 - Rear Old Man Emu Nitrocharger Sport Shocks x2
    • OMEU53A - Old Man Emu Leaf Spring U-Bolts x4
    • FK29 - Old Man Emu Rear Drive Shaft Spacer Kit
    • OMESB108 - Old Man Emu Leaf Spring Bushing Kit x2
    • OME95PF5 - Old Man Emu 5mm Trim Packer x1
    • TAC-SP-SM-05+
    • OMETAC16LKSB
    Link to Complete Kit:
    http://www.lowrangeoffroad.com/toyota...
    Before and After Height Measurements:
    Stock Height Front : 34-7/8” Rear : 36-3/4"
    Lift Height Front : 37-7/8” (+3”) Rear : 39-1/4” (+2-1/2”)
    W/ 32.7” Tires Front : 38-7/8” (+4”) Rear : 40-1/4” (+3-1/2)
    Front to Rear Comparison: 1-1/2” Higher in the Rear
    Tire Size: 285/70R17 BFGoodrich KO2
    Wheel Specs: Method NV 305 Matte Black - 17x8.5 - Back Space 4.75”
    grubburg, Ducman82, synaps3 and 20 others like this.
  2. Mar 27, 2017 at 4:41 PM
    StORmTrooperLV
    StORmTrooperLV Well-Known Member
    Stephen
    Las Vegas
    2016 SuperWhite Tacoma DC Off Road
    RCI Front Skid
    Great video, thanks for putting together. I hopefully will be purchasing this kit by years end.
  3. Mar 27, 2017 at 4:44 PM
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Is it necessary to loosen the alignment cam bolts? I've been looking at install tutorials and haven't seen most ppl do that. Just wondering, that's all.
  4. Mar 27, 2017 at 4:49 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    No you don't have to.
  5. Mar 27, 2017 at 4:54 PM
    2015 TRD Sport
    South Carolina
    2021 TRD Pro
    It makes it easier to get the strut assembly out and in if you do,but still can be done without loosening the lower cam bolts.
  6. Mar 27, 2017 at 5:02 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Great video! I'm going to be installing this setup in the next week or 2. :D
  7. Mar 27, 2017 at 5:30 PM
    ievko82
    WV
    Thank you
  8. Mar 28, 2017 at 10:08 AM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
  9. Mar 28, 2017 at 12:24 PM
    goose13
    goose13 Well-Known Member
    NY
    Soon to be 4Runner TRD Pro
    Wow, that's great. Beats the heck out of reading the instructions and figuring out what exactly to do. Thanks for posting.
  10. Mar 28, 2017 at 12:55 PM
    17tacosport
    17tacosport Well-Known Member
    Hasmeet
    Buffalo,NY
    2017 MGM Tacoma DCLB 4x4
    Let us know how that goes, I'm planning to purchase this kit myself maybe during the summer and wanna hear some real reviews of its ride handling.
  11. Mar 28, 2017 at 1:25 PM
    Fyreguy11
    Fyreguy11 Well-Known Member
    North Texas
    2018 DCLB 4x4 TRD Off Road
    Wish this was out on Sunday morning when I installed mine!
  12. Mar 28, 2017 at 1:25 PM
    Fyreguy11
    North Texas
    Mine did not come with directions!
  13. Mar 28, 2017 at 1:26 PM
    SuperBad
    Dallas, TX
    Truck stuff
    I've riden in a 2016 with this setup on 886 coils and the 9000 shocks (stiffer than the 90021). it rode a little stiff but still felt good to me. Takimg the ride is what sold me on this lift setup.
  14. Mar 28, 2017 at 1:29 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I've installed a lift without loosening the LCA and also a lift with loosening the LCA. Loosening the LCA makes the process SO MUCH EASIER. As long as you use a sharpie to mark your alignment tabs, you'll have no problem getting your truck drive-able again to take it to get an alignment.
  15. Mar 28, 2017 at 1:43 PM
    HoboDave
    David
    Carlsbad, New Mexico
    2023 Toyota Prius
    Nice. This might be the setup I'm going with sometime in the near future. These guys act like they know what they're doing.
  16. Mar 28, 2017 at 2:03 PM
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2012 DCSB TRD OR
    GREAT video. This makes the process so much easier for dummies like me. :drunk:
    Fyreguy11 and 17tacosport like this.
  17. Mar 29, 2017 at 9:13 AM
    Low Range Off-Road
    Just added Part 2. Thanks for all your views. Hopefully this helps everyone out.
    PNWTacoma and baileybrandon like this.
  18. Mar 31, 2017 at 5:16 PM
    Pportera
    Pportera Well-Known Member
    3rd gen.
    Wish i would have seen this before I did my install. Had some nasty rear driver lean after installing the dakar leafs. Went to this video and saw the part about leaving the shackle bolts loose untill u jump and bounce the rear under weight, then torque down.
    I found out my shackles were kinda binding and sticking, causing the driver rear to stick down. After I did this, it's perfect stance and the steering wheel is even back centered.
    Thanks for the video guys. :thumbsup:
    James at Lowrange likes this.
  19. Apr 3, 2017 at 8:12 AM
    James at Lowrange
    James at Lowrange Well-Known Member
    200 miles from Moab
    You are welcome glad to hear it was an easy fix!
  20. Apr 3, 2017 at 8:14 AM
    James at Lowrange
    200 miles from Moab
    Do it. It's a great set up and install if very straight forward.
