How to install a speedhut boost guage
Discussion in 'Performance and Tuning' started by Tacoma SS, Oct 27, 2015.
  1. Oct 27, 2015 at 4:50 PM
    Tacoma SS
    Tacoma SS [OP] Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    When I ordered my boost guage I just assumed that it would be a power wire, a ground wire and a hose to run to the supercharger. I got this thing in the mail and it's got like 7 wires. Is there a thread on how to install this thing or has anyone done it before that can guide me through it? The directions that come in the box are not very clear.
  2. Oct 27, 2015 at 9:20 PM
    Tacoma SS
    Denver
    Anybody?
  3. Oct 28, 2015 at 6:09 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    You received only a gauge.
    Do you have a MAP sensor? Normaly you should have a MAP sensor installed on the firewall in the engine bay. The MAP is conected to the boost port with a tube. Then you have a wire(s) from the MAP sensor to the gauge. From the gauge you normaly have to connect 2 or 3 wires (12V power, ground, sometimes a third one activated by Hi/LOW beam).
    The 2 black connectors are probably a IN and a OUT. They can be connected to a computer to program/set the gauge (need the cable and software for that) or to connect to an other device to create a data logging chain. Like said, it's maybe that but you should check with the supplier.
  4. Oct 28, 2015 at 6:50 AM
    Tacoma SS
    Denver
    Do I HAVE to hook up to the MAP? Or will it still work if I just took it up to power and ground and then run the hose to my supercharger?
  5. Oct 28, 2015 at 7:01 AM
    Tacoma SS
    Denver
    Are all boost gauge is like this? Why is this one so complex?
  6. Oct 28, 2015 at 7:17 AM
    Tacoma SS
    Denver
    Is this more accurate than a mechanical guage?
  7. Oct 28, 2015 at 8:01 AM
    Tacoma SS
    Denver
    Which would just make it a bigger guage or what?
  8. Oct 28, 2015 at 8:04 AM
    Tacoma SS
    Denver
    Also, did you install your own gauge and could possibly take any pictures of where you have your wiring connected? I'm pretty mechanically inclined and there's a good chance I could do it myself with a little guidance
  9. Oct 28, 2015 at 8:05 AM
    Tacoma SS
    Denver
    That's what I thought I was going to have to do anyway haha seems easier than running all these wires
  10. Oct 28, 2015 at 10:04 AM
    Tacoma SS
    Denver
    All the places that I've talked to want $140 or more :eek:
  11. Oct 28, 2015 at 10:57 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Mechanical ftw
  12. Oct 28, 2015 at 11:04 AM
    Tacoma SS
    Denver
    Just got off the phone with one of the customer service reps over at speedhut. He informed me that if I was so inclined I could just twist all the positive wires together and all the negative wires together, find a good source of ground and put all the power wires to a switched power source and it would work perfect. He said all the additional wires are in case you want the ability to dim the lights or have to gauge hooked up to your headlight switch but I'm not interested in that. So this actually will be a pretty simple install. :thumbsup:
  13. Oct 28, 2015 at 11:09 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Speedhut gauges are nice - i have a few. I found them very easy to install. where is the harness and sensor?
  14. Oct 28, 2015 at 11:11 AM
    Tacoma SS
    Denver
    They are separate. I did not have them connected for that picture
  15. Oct 28, 2015 at 11:47 AM
    Tacoma SS
    Denver
    How did you wire up yours?
  16. Oct 28, 2015 at 1:14 PM
    CanadaToy
    Greg
    Toronto
    It was a few years ago, but i combined the harnesses together like so:
    They all plugged into the sensors.
    Then, i tied the power and grounds and illumination together, and connected it behind the dash. Sorry no pics of that,
    You can kind of seem them on the left side here, sorry, terrible camera.
  17. Oct 29, 2015 at 9:20 AM
    Tacoma SS
    Denver
    Installed my boost gauge last night. Twisted all the ground wires together and hook them to a body ground, then twisted all of the power wires together and hook them up to the ignition fuse. Ran my hose over to the boost port on my supercharger and wala! it was good to go. Only pushing 6 pounds of boost is kind of a bummer but that's why I'll be picking up my new pully soon.
  18. Oct 30, 2015 at 7:47 AM
    Tacoma SS
    Denver
    Installed my boost gauge and also finally got the bung welded in for my wideband. It's looking like I'm running about 6 pounds of boost and my AFR is 14.6 at idle and 10.1 at WOT. Do these numbers sound normal/good
  19. Oct 30, 2015 at 7:50 AM
    CanadaToy
    Greg
    Toronto
    They sound right.
    With a tune, you will want to be 11.5-12:1 at WOT for the most HP. You are running rich (which is normal, stock).
  20. Oct 30, 2015 at 7:52 AM
    Tacoma SS
    Denver
    So if I were to buy an intake and drop S/C pulley size that would help me out?
