How to Install a Viper 5704 Alarm/ Remote Start
Discussion in 'Audio & Video' started by Riverdog, Dec 6, 2012.
  1. May 19, 2014 at 7:14 PM
    #221
    Riverdog
    Riverdog [OP] Well-Known Member
    Collin
    Portland, OR
    '05 Double Cab PreRunner
    Maybe get your truck's battery checked. Sometimes if the voltage is low the alarm goes off.
  2. May 19, 2014 at 7:25 PM
    #222
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    Going to bring it in tomorrow to the dealer that installed the alarm. Thx.
  3. May 19, 2014 at 7:26 PM
    #223
    Riverdog
    Collin
    Portland, OR
    Good idea and good luck! Hopefully its something simple.
  4. May 19, 2014 at 7:31 PM
    #224
    stphnman20
    SCV
    2016 T4R
    Hopefully it's something minor. The alarm is only 2 weeks old.
  5. May 25, 2014 at 6:51 PM
    #225
    Z E R 0
    Z E R 0 Well-Known Member
    California
    02 Tacoma 4x4
    hello , in which step do i need to do sometingn with the keysense connector? iam installing the viper alarm and remote start right now on my 2014
  6. May 26, 2014 at 8:59 AM
    #226
    Rickalders
    Rickalders Well-Known Member
    So what was the problem with the false alarms? I've had mine installed (a self installed 5706v) for about 3 months and no problems.
  7. May 26, 2014 at 9:34 AM
    #227
    stphnman20
    SCV
    2016 T4R
    It was the hood trigger sensor. The plastic piece broke. Got it replaced. All good now.
  8. May 26, 2014 at 11:44 AM
    #228
    Riverdog
    Collin
    Portland, OR
    The keysense wire on your truck will connect to the bypass.
  9. May 26, 2014 at 11:53 AM
    #229
    Z E R 0
    California
    02 Tacoma 4x4
    OK, but why does it say warning on the instructions, please check attached file.
    i have a messssss of cables!!!!!asdqjwdjnq
    almost done, just have a few questions. thanks~!
  10. May 26, 2014 at 12:19 PM
    #230
    Riverdog
    Collin
    Portland, OR
    Hmmm.... It looks like that's one of the differences between our trucks. The instructions for my 2005 say to use the keysense wire. So maybe you don't have to use it on your truck? [​IMG] I'd do what the instructions say. Maybe someone else knows the exact answer.
  11. May 26, 2014 at 2:14 PM
    #231
    Z E R 0
    California
    02 Tacoma 4x4
    ok thanks! do you know where to connect the 12v (+)- red cable of the idatalink bypass? the one on the diagram attached o previous post..
    thanks in advance
  12. May 26, 2014 at 2:26 PM
    #232
    Riverdog
    Collin
    Portland, OR
    According to your attachment a few posts ago, you should connect the bypass's 12V wire to the Viper's 12V wire.
  13. May 26, 2014 at 5:50 PM
    #233
    Z E R 0
    California
    02 Tacoma 4x4
    HELP, the remote wont start!! the 2way remote wornt start, is there a way to turn it on! thx!
  14. May 26, 2014 at 6:36 PM
    #234
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    If its the one with a screen, then you have to plug in the charger for about 30 minutes before it starts up. Make sure to fully charge it. If its the non screen 2 way, make sure the plastic battery cover is pulled out and battery is properly installed
  15. May 26, 2014 at 6:50 PM
    #235
    Z E R 0
    California
    02 Tacoma 4x4
    the one with the screen still doesnt turn on,.. the one without the screen it does work, but it seems like it doesnt communicate with the viper brain because it does nothing!
  16. May 27, 2014 at 5:15 PM
    #236
    Riverdog
    Collin
    Portland, OR
    Have you completed the pairing process for the remotes? If so, you may want to do it again if the remotes still are not working.
  17. Jun 2, 2014 at 11:11 PM
    #237
    Z E R 0
    California
    02 Tacoma 4x4
    Alarm works, but remote start doesnt work. the relay doesnt make any sound of movement when I click remote start. Like if the brain doesnt send a signal to the relay.. what could be the problem.
    edit: headlights flashes 8 times, and remote start error.. 8 flashes means MTS must be enabled, but i have an automatic. how is that possible
  18. Jun 6, 2014 at 11:07 PM
    #238
    Riverdog
    Collin
    Portland, OR
    Manual transmission mode is the default. You have to change it to automatic mode before you use it.
  19. Jun 11, 2014 at 3:58 PM
    #239
    Z E R 0
    California
    02 Tacoma 4x4
    I just left it with just the alarm .. lol
    how can i program viper brain to DOUBLE PULSE MODE?
    thx in advance
  20. Jun 12, 2014 at 8:00 AM
    #240
    Z E R 0
    California
    02 Tacoma 4x4
    I found how, but it only unlocks all doors twice with a single click. Why is that
