How to Install a Viper 5704 Alarm/ Remote Start
Discussion in 'Audio & Video' started by Riverdog, Dec 6, 2012.
  1. Nov 19, 2015 at 6:04 PM
    #341
    frizbal
    frizbal Well-Known Member
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    was just the fuse (thus the asshat). Ended up being a good install without issues besides the programming of my bypass.
    mbroughton02 likes this.
  2. Nov 23, 2015 at 7:48 AM
    #342
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    Which fuse did you blow? I didnt even realize it, but when my GF got in my truck last night she said "it looks dark in here". I shrugged it off, cuz whatever, but then i went to adjust the heat and what do ya know- i couldnt see anything! the lights are out, only on my climate control unit. All other lights work. Was that your issue? And what fuse should i check out?
    P.S. glad to hear you got a good install done.
  3. Nov 23, 2015 at 10:03 AM
    #343
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    It was the "tail" fuse in the panel inside the cab. I believe top row, third from the left. 10 amp fuse.
  4. Nov 23, 2015 at 5:36 PM
    #344
    ranger098
    Brian
    Minnesota
    I found an exposed wire from my trailer brake controller that was popping the tail fuse. Totally unrelated to the remote start. a little scary tho, when that fuse is popped your running tail lights dont work (they still work when you hit the brakes). Not sure how long that was an issue. Anyway all good now!
  5. Dec 13, 2015 at 7:13 PM
    #345
    REBinc
    REBinc Well-Known Member
    Pittsburgh
    2012 Reg 4x4 5spd / 2006 GTO
    I just installed this on my manual '12 RC with manual locks/Windows. Here are a few of my notes/tips that I feel would have made this a lot easier. I honestly didn't read past the first two pages, so sorry if these were mentioned.
    The biggest thing if you don't care about anything I write is that all the ignition wires pass through the fuse box area, there is no reason to go digging into the column and having longer wires going more places.
    Second biggest tip is don't snip or tie up the wires you don't plan to use, depress the tab on the pin and pull the pin out. This prevents you from having to bundle a lot of useless wires, while still giving you the security of putting the pin back in if you ever actually do need it.
    The only technical difference I found for the 2012 is the green/yellow marked in the diagram is actually the ebrake (-) wire, the door trigger is the green/yellow wire on the other 18 pin is the door open trigger.
    Since the write up was for a automatic, the two additional pieces for the manual was the ebrake and dealing with the clutch sensor. Instead of grounding the neutral wire, I attached it to the ebrake wire which is the green/yellow mentioned above. To get around the clutch sensor, I wired up the defrost wire to the "clutch cancel" button so that everytime the car remote starts, it enables the clutch cancel so the car will actually start. My goal was to keep all the stock safety functions, so this still requires the clutch to start the car at all other times.
  6. Dec 13, 2015 at 7:33 PM
    #346
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Absolutely agree with the ignition wires being at the panel. I would have also determined where exactly I wanted to place the unit, then cut the wires to length. I got excited and jumped in and soldered the original length which means I had a lot of extra wires to tuck.
  7. Dec 28, 2015 at 10:00 AM
    #347
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    Great post Riverdog!! I just completed the install and everything works great but one issue. After setting the alarm the doors lock but I get a door is open fault a second later on my fob. Has anyone seen this before? Is it a diode issue?
  8. Dec 28, 2015 at 10:18 AM
    #348
    REBinc
    Pittsburgh
    Does it do with the both the ebrake set and the ebrake not set?
  9. Dec 28, 2015 at 10:26 AM
    #349
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    Hi thanks for the reply!! Yes regardless
  10. Dec 28, 2015 at 10:28 AM
    #350
    ranger098
    Brian
    Minnesota
    First thing id check is the connections at the door wires... maybe that goes without saying ha.... but i bet theres a loose wire there.
  11. Dec 28, 2015 at 10:37 AM
    #351
    frizbal
    Sean
    Tulsa, Oklahoma
    2012 TRD Off-Road
    Are you using a dummy key in the ignition or did you install a bypass? If you are leaving a key in the ignition, it may be sensing it when you lock, and popping the locks back open?
  12. Dec 28, 2015 at 10:40 AM
    #352
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    I had the same issue. I followed the wiring schematic posted to the letter as well. What I found was the wiring for those who want to shut off their lights after a remote start (shut down sequence) caused my issue. I re-wired it according to the viper manual and my problem went away.
  13. Dec 28, 2015 at 10:44 AM
    #353
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    I'm not following you. Can you explain thanks
  14. Dec 28, 2015 at 10:48 AM
    #354
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    I'm using a bypass
  15. Dec 28, 2015 at 12:29 PM
    #355
    ranger098
    Brian
    Minnesota
    Theres a post a few pages back now that talks about the headlights staying on if you leave the headlights on. Ex. you remote start the truck, the headlights come on because you kept the lights on. Then, the truck shuts off, either because you cancelled the start or it timed out. Now the headlights stay on becuase it's waiting for you to open the door (thats the trigger to shut the headlights off).
    you can do some wiring to automatically shut the lights off and prevent this problem... but for revalations it caused the same issue you had.
    Id suggest going back a few pages on this post and read it through... not sure if you tried that mod or not.
    Revelations likes this.
  16. Dec 28, 2015 at 12:47 PM
    #356
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    Ok thanks I filter through
  17. Dec 28, 2015 at 8:01 PM
    #357
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    Ok thanks for the revision. I went back through the thread and rewired the trigger to the proper location and wired in the factory arm output wire to the driver door wire with a diode as well. It cleared the fault.
    Now I am having issues with my remote start. Initially when I first hooked it up and moved it from manual transmission to automatic transmission it worked with no problems. Now every time I try to use the remote start it cranks but does not start. It tries three times, but never starts. The key fob tells me after the third time I have a low tach signal. I rechecked the wires and everything is still hooked up. Does anyone have any idea what the problem is? Like I said it worked initially.
  18. Dec 28, 2015 at 9:10 PM
    #358
    Revelations
    2014 MGM DCSB
    Put your key into the ignition, but don't turn it on. Try the remote start. If it starts, then check your bypass module wiring. You may need to reprogram it.
  19. Dec 28, 2015 at 9:39 PM
    #359
    andradea21
    andradea21 Member
    Anthony
    2006 Grey Tacoma
    Yup that was it. Started right up. So do I have to take it back to the dealer who sold me it or is there a way I can reprogram it?
  20. Dec 28, 2015 at 9:48 PM
    #360
    Revelations
    2014 MGM DCSB
    check the wiring first. make sure nothing came loose. depending on the module, you can probably find directions online to reprogram. it's usually really easy to do.
