How to install an inline ATF filter for 05 Tacoma 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Back40, Jul 15, 2015.
  1. Jul 15, 2015 at 10:57 AM
    Back40
    Back40 [OP] Well-Known Member
    SC
    2005 4x4 Dbl Cab
    Planning on full flush and replacing OEM ATF filter @ 135k. Performed a full flush @ 68k but did not drop the pan. Considering installing an inline filter. Which ATF cooler line (to or from) should the filter be installed? Any brand suggestions? Thanks in advance for your feedback.
  2. Jul 15, 2015 at 11:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i wouldnt even bother. doing a full 13quart change every 60k is more than plenty.
    But if you really wanted to, i would put the filter so it doesnt drain back into the trans when turned off, where every thats the easiest to do as anywhwere on either of those lines is essentially the same.
