How to install floor mat retainer clip
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco916, Dec 27, 2011.
  1. Dec 27, 2011 at 7:14 PM
    Taco916
    Taco916 [OP] Member
    Sacramento
    2001 Tacoma Double Cab V6 Auto 2WD TRD
    I have a 2001 double cab and the mat keeps sliding so I bought the clips, but not sure how to install them. I tried to squeeze it through the hole and find the spot to pop in, but couldn't locate. Then I proceeded to remove the floor board plastic piece, but still can't seem to located the hole. Help!!!
  2. Dec 29, 2011 at 10:29 AM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    If I remember correctly... There are 2 pieces to the retainer. One round piece goes under the carpet, which you have to remove door sill and get under carpet from there. Then the other round part goes on top and they clip together with carpet between, kind of like an eye-let. Then you just need to pop the hook into there and its secured.
    Did you only get the hook part and not the metal ring???
