How to Install Lamin-X fog light covers
Discussion in 'Lighting' started by ccoorreeyy, May 7, 2009.
  1. May 7, 2009 at 10:54 PM
    ccoorreeyy
    ccoorreeyy [OP] www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    Hey All,
    I couldn't find an install guide of this so I made one (or was told to at least).
    First things first, all pictures are taken with my iPhone. Sorry.
    *Note - You are doing this at your own risk. I'm not responsible for anything related to the install of this product on your vehicle. This is simply a guide to help you when applying Lamin-X fog light covers.
    What you will need:
    1. Lamin-x fog covers http://www.lamin-x.com/Toyota-Tacoma-05-Fog-Light-Covers-p/t112.htm
    *Note - This product DOES come with two covers in the package.
    2. All purpose cleaner
    3. Rag
    4. Razor blade
    First Step:
    Turn the fog lights on. This will help with the cleaning and application of the cover.
    Second Step:
    Clean those dirty fog lights! Make sure they're free of any particles that are unattractive because you will see them through the cover. I used a natural all purpose cleaner but soap and water will do.
    Third Step:
    Dry it.
    Fourth Step:
    Open package and separate the two plastic pieces.
    Then, separate the wax paper from the Lamin-X cover.
    Don't worry about handeling the covers. It's sticky on one side. I tried not to touch that part, but I don't think it really matters.
    *Note - Do not cut the little taps hanging off the cover. These a really helpful.
    Fifth Step:
    Once removed, pick a fog side of your choice.
    Align the middle of the cover to the highest point of the foglight and stick the cover on. Make sure it's center by pushing down the outer circle to the fog lamp with out touching so that it doesn't stick. (i.e. Measure Top, Bottom, Left, and Right parts of the cover to the fog light).
    It's really important that the whole fog light is covered and that you measure the top, bottom, etc... totally right. Otherwise, you will have to peel off the cover and that just sucks. (It's not a problem if you do, it's just annoying).
    Sixth Step:
    This is the hardest part (and the hardest part to explain). Start from the middle point you just alligned and use your fingers (all of them if possible) to EVENLY and SYMMETRICALLY lay down the cover. If you don't do it evenly, you will have large air bubbles. Press and slide with your finger tips like so:
    Don't worry about very small air bubbles. They will go away over time through the heat of the light. Mine has to many to count. I'm not stressing it though because the label on the package said this would happen.
    Seventh Step:
    Now you're ready to cut off the tabs. Take your razor blade and cut them off. Try to cut them with a little roundness. It will make it look better and more professional.
    Eighth Step:
    Do the other side.
    BOOYA!!! Your lights are finished! Here's my truck just after the install. :D
    Light affects on my door.
    On at night!
    Off in the garage.
  2. May 7, 2009 at 10:59 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Nice writeup.
  3. May 7, 2009 at 11:39 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Sweet write up man. I personally would not do anything with the lights while they are on. Mainly because the foglight generates so much heat that it may dry up the solution (Windex, rubbing alcohol, etc.) too fast and leave harsh residue basically burnt on there. And taking the foglight housings would give you much more room to work with and avoid hurting your paint.
  4. May 8, 2009 at 8:27 AM
    06WHITETRD
    06WHITETRD Gotta Love my Taco!!!!
    So Cal
    06 Toyota Tacoma OFF-ROAD
    Tinted windows, window visors, XDI True Flow intake, White Devil Emblem, sport white grill, stubbie 6' antenna, TRD license plate frame,TRD Exhaust, weathertech floor front & rear, LED map/dome & license plate lights,Black Grille,T-Rex eyebrows,black Skid Plate,Lower bumper cover,Black emblems,white TRD Emblem,lamin-x yellow,Slotted & Cross Drilled rotors,Redline shocks(hood),HID 6k,more to come
    Viet2100 ... your making it too much for yourself but hey u got time for it.. anyways hey COREY, thanks a lot for the write up. great job. Your going to get a lot complaments and thats the shit. Ima do mines this sat. so this is going to help a lot thanks.
  5. May 8, 2009 at 11:31 AM
    ccoorreeyy
    Corey
    Yea. I believe you. I just found that the cover easily took shape when it was hot and I didn't have any problems with using soap with my lights, but I can see what you mean. Thanks for the input!
    C
  6. May 8, 2009 at 11:32 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    nice writeup looks great thanks for taking the time to do it :D
  7. May 8, 2009 at 11:35 AM
    ccoorreeyy
    Corey
    Haha. Thanks man. No stress. I appreciate the comments! And you're welcome. :D
  8. May 8, 2009 at 11:36 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    nice work!! They look great... wish I could say mine looked that good.. :)
  9. May 8, 2009 at 11:38 AM
    ccoorreeyy
    Corey
    Why don't yours look that good? :confused:
  10. May 8, 2009 at 11:42 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Great write up, looks good.
  11. May 8, 2009 at 1:32 PM
    white+Peal
    white+Peal Well-Known Member
    Kris
    Henderson, NV
    08 prerunner
    Magaflow catback exhaust, AEM CAI, front bumper made by famous fabrication, JBA long tube headers, All pro back bumper, BPF raptor style grill, 3' toytech lift
    but r these for show or do they have a function??
  12. May 8, 2009 at 1:43 PM
    06WHITETRD
    So Cal
    Show lol
  13. May 8, 2009 at 1:53 PM
    ccoorreeyy
    Corey
    I think they're for show, but I could be wrong... They protect the lens from getting scratched if nothing else.
  14. May 8, 2009 at 1:56 PM
    mainland_newfie
    mainland_newfie Mainland Newfie
    ontario, canada
    TRD Tacoma
    skid plate, side step rails, new rims, hose clamp, 20% tint, G4 Tonneau cover, JVC 7 in double din stereo/dvd
    has anyone used the blue and have pics, I have indigo ink and wonder if the matching blue would be better than the yellow
  15. May 8, 2009 at 1:56 PM
    ccoorreeyy
    Corey
    I also read somewhere that yellow and amber light cuts through fog the best. I can't find the link so I can't find out if the source is creditable. Could be though. And, why not? It looks good.
  16. May 8, 2009 at 1:57 PM
    ccoorreeyy
    Corey
    I'm curious too. My girlfriend asked me last night why I didn't get blue. I didn't even think about it. Anybody got photos?
  17. Sep 18, 2009 at 6:06 PM
    TacoSox
    TacoSox Well-Known Member
    Diz
    Atlanta, GA
    09 PreRunner TRD SR5 Off Road
    K&N Air Filter, Bug Deflector/Hood Protector, Window Vents, Lamin-x Fog Light Covers
    Thanks for the thread, C. This is a big help, cool of you to take the time.
  18. Sep 18, 2009 at 6:32 PM
    ccoorreeyy
    Corey
    Sure thing man. Glad I could help.
  19. Sep 21, 2009 at 5:03 PM
    mmako220
    mmako220 New Member
    Ontario, Canada
    07 TRD Off Road Pkg
    Hey where did you get these covers? look really good!!
  20. Mar 1, 2011 at 12:22 PM
    donovan6241
    donovan6241 Well-Known Member
    Donovan
    San Diego
    2017 TRD Sport Double Cab Long Bed
    you have HIDs on ur fog lights right?
