How to jack up a taco with a 8in lift???
Discussion in '1st Gen. Tacomas (1995-2004)' started by bowhunter11199, Nov 11, 2010.
  1. Nov 11, 2010 at 7:21 PM
    bowhunter11199
    bowhunter11199 [OP] Well-Known Member
    hey just wondering if anyone out there has a taco lifted big time and how you are able to lift up your truck to change stuff like tires? I've tried a normal jack but it took 5 2x4's to just reach my frame. I've heard about sky lifts but would i be able lift the truck in the middle of the fame?
  2. Nov 11, 2010 at 7:59 PM
    YouNext
    YouNext General Calamari
    San Diego
    K&N FIPK, Gibson Exhaust, Doug Thorley Headers, URD pulley, Stoptech Cryo-treated Slotted Rotors, Deaver J59, Bilstein 5150s, Total Chaos LT (w/Spindle & Tower Gussets), Icon LT C/Os.
  3. Nov 11, 2010 at 8:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    or a big one of these
    and a big set of these:
  4. Nov 11, 2010 at 8:07 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  5. Nov 11, 2010 at 8:28 PM
    bowhunter11199
    i was also told by a local autozone that i could just use an ordinary jack (cheap one) but just jack up my truck under that arms.:confused: but how would that work out with the idenpendent suspension? and are you even able to jack up a truck under the arms with out messing it up? and what about the rear how would i do that???
  6. Nov 11, 2010 at 8:36 PM
    bowhunter11199
    this is when i hate lifted up tacos... but there are plently of good things. like helping chicks get in( im 16)
  7. Nov 11, 2010 at 8:37 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    for simple tire changes, you can use a floor jack under the stock lower control arms... i did that for about 4 years on my truck before it went long travel... never had an issue... figured the weight of the truck already sits on the arms and beats the hell out of them everytime the truck was jumped, so it should be strong enough to handle a floor jack underneath...
    for any extended period of time, you may want to come up with an alternative, or if lifting to work on the suspension...
  8. Nov 11, 2010 at 8:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    NOO! they will break. Always use wood or metal.
  9. Nov 11, 2010 at 8:55 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ehh I dont like how the LCAs flex while you jack them up, IMO shell out 60 bucks at harbor freight to get a good sized floor jack and or a piece of 4x4
  10. Nov 12, 2010 at 12:54 AM
    fireman_343
    fireman_343 Ultimate TRD
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    Viper Alarm, XD Series Wheels, Pioneer touch screen radio/nav system.
    I just jack up under the control arm in the front and under the rear axle for the rear.
    Been doing it for years and it won't mess up anything! How did u get a 8" lift... 5" suspension and 3" body?
  11. Nov 12, 2010 at 5:51 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i would suggest you not use one of these for driveway jacking if you're not experienced with it ....it's probably one of the most dangerous tools you'll ever use on your truck.
  12. Nov 12, 2010 at 7:51 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    get a full size floor jack and put if in the tool box, you can pick up on the lower control arms without hurting anything, and the rear you can pick up under the shock mounts or the pumpkin.
  13. Nov 12, 2010 at 7:58 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  14. Nov 12, 2010 at 8:41 AM
    bowhunter11199
    i have a 6 in suspension and 2 in body lift. thats how i got 8 in lift. so jacking it up under the arms are ok?
  15. Nov 12, 2010 at 8:48 AM
    MyYota05
    MyYota05 Well-Known Member
    Muskogee, Oklahoma
    2005 Toyota Prerunner w/ TRD Offroad Pkg.
    3'' Lift Kit, Bed Rug Liner, Black Rims
    Now that is a lift. :D
  16. Nov 12, 2010 at 8:52 AM
    SmallTacoBigDream
    SmallTacoBigDream RidinHigh
    Beau
    Kaplan,La
    Black 1998 4cyl Lifted
    Intake,Dana44 front axle,5.38 Gears,315/75/16 BFG KM2,Bilstien 7100 series.
    straight axle??? or no???
  17. Nov 12, 2010 at 9:17 AM
    bowhunter11199
    im pretty sure its not a staright axel. i didnt personal put the lift on. The previous onwer(only 1) put it on and im almost positive that he just stuck with stock axels
  18. Nov 12, 2010 at 9:31 AM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    You can jack up by the control arms...but be wary. NEVER get under the truck with it sitting on the control arm alone. I had my Tacoma fall on me because of that.
    It definitely won't hurt the control arm in the least bit, but it is not a stable location to support your vehicle.
    http://www.tacomaworld.com/forum/general-automotive/93056-i-almost-got-seriously-injured-due-my-stupidity.html
    And oh boy...you don't know if it's a straight axle...that's not a good sign that you should be jacking it up. Any truck with a SFA and an 8 inch lift can be distinguished immediately by anybody who knows anything about trucks.
    Since you're asking about control arms, you're IFS.
  19. Nov 12, 2010 at 9:42 AM
    bowhunter11199
    i just check it out i know for a fact that it has independent. i have just never look before because i've never really cared cuz i dont do extreme 4 wheeling. and all i need to do is just rotate my tires so i just need to get it off the ground them i can put some big jack stands under it. and dude chill out im 16 and im learning on the go
  20. Nov 12, 2010 at 10:31 AM
    fireman_343
    Brian
    Columbus, OHIO
    05 TRD Dlb Cab
    What/who's lift is it??
    Just wondering who is still making 6" suspension lifts for 1st gens
