how to jack up truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by colinb17, Jul 14, 2009.
  1. Jul 14, 2009 at 7:14 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    hey everyone, tomorow i finally have a full day off...i'm using it to clean out my squeaky leaf springs. (florida mud makes lots of noise between moving parts). i can't quite tell, but i think the squeak is coming from both the springs, and the bushings at the ends of the springs. my question is about jacking up the truck. i'm guessing the frame, right in front of where the leafs connect to it is the best place to jack...but what about lift height? the jack i have only lifts 20 inches, and i'm sure with the travel our trucks have, that's not going to get all of the pressure off of the rear end to allow me to spread the leaf pack... what do i do? block of wood between the jack and truck?
    any other suggestions about other parts of this project are also welcome since i haven't done it before. thanks in advance
  2. Jul 14, 2009 at 7:28 PM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    i just put it under the rear axle or just use a pressure washer and u wont need to jack up the truck thats what i did
  3. Jul 14, 2009 at 8:23 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i tried a pressure washer, but the squeaking just came back
  4. Jul 14, 2009 at 8:26 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Is getting a full size, heavy duty jack an option? If you work on own vehicles enough, It will pay for its self in the long run. Buy a quality jack and it will last you for 20+ years, easy.
  5. Jul 14, 2009 at 8:30 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i have a big craftsman 3 ton jack with a 20 inch lift. the thing weighs about 90 lbs. it lifts the truck easily for changing/rotating tires and such, but since i want to undo the the leaf springs, even the 20 inches isn't enough to compensate for the "expansion" of the springs when i jack it up.
  6. Jul 14, 2009 at 8:38 PM
    SC4333
    Grant
    FL
    Lift the truck from the rear axle (as high as possible), place jack stands under the chassis at the proper locations, and while the jack is still under the axle remove the wheels and then you can drop the jack.
    You can use this trick if your jack isnt quite cutting it.
  7. Jul 14, 2009 at 9:55 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ah, i hadn't thaught of it like that. i have some tall ass jack stands, but they don't do me much good if the jack doesn't go that high...but now i gues i have a use for them. thank you for the help
  8. Jul 15, 2009 at 2:28 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Your owners manual should have a diagram of 'jacking points'
  9. Jul 15, 2009 at 7:13 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Isn't there arrows? I remember seeing them, not sure if they were my truck or my car.
  10. Jul 15, 2009 at 7:39 AM
    jonny
    jonny Betty White Edition Heep ZJ
    kinda boot leg, but when i clean out my leafs/spray them with wd40 to shut them up. i use a wood block and my small jack and jack it up under the hitch receiver.I never get the wheels off the ground, just enough to spray down the leafs. fwiw just my .02
  11. Jul 15, 2009 at 1:29 PM
    branct06
    Thomas
    wd40 works great
  12. Jul 15, 2009 at 1:33 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    one of my buddys used to have a taco that he mudded down here and was jacked up with a 6inch lift. he said that no matter what he did the squeek would always come back after mudding it here in florida.
