How to keep my leaf from moving...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TacomaDC, Jun 6, 2010.
  1. Jun 6, 2010 at 7:53 PM
    08TacomaDC
    08TacomaDC [OP] Member
    08 double cab sr5 4x4
    This has happened about a 4-5 times now. I have a 3" lift on my truck that Les Schwabs put on for me, it's also their lift kit (tough country). I just drove up from Oregon to Alaska and the middle leaf has drifted over yet again.
    It gets over and rubs against a rubber guard and is got awful to listen to, it is beyond annoying. Everytime it happens I take it to Schwabs and they fix it. Well, no more Schwabs up here in AK. Plus I'm tired of doing that, it's a wast of time and shouldn't happen. Also, it's always the same side, never the right side.
    What needs to be done to keep this from happening? Also, this happens from nothing but driving on gravel roads, I don't off road my rig.
    Thanks
  2. Jun 6, 2010 at 7:54 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Superglue! Check the u bolts they may not be tight enough.
  3. Jun 6, 2010 at 8:00 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    could be a defective leaf.
  4. Jun 6, 2010 at 8:02 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    The stock leaves have a ring sort of thing holding them together.
  5. Jun 6, 2010 at 8:05 PM
    toytaco970
    toytaco970 Well-Known Member
    avon/vail, co
    05 trd offroad 4x4
    Front: Icon IVD coated extended travel coilovers Rear: 5125's with AAL and 1" block. Front sway bar removed. Brute Force Fab bumpers AllPro stuff: UCAs , front skid plate, sliders, rear u-bolt flip kit, e-locker guard Kenwood/Garmin single DIN DVD-NAV system, amp and sub. V1 radar, Foglight anytime mod,
    Had the same issue with mine, had to re-torque the U bolts with a little extra torque
  6. Jun 6, 2010 at 8:18 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    hit it with a hammer
  7. Jun 6, 2010 at 9:42 PM
    08TacomaDC
    Ya, you can pound on it all day long as hard as you want with a mini sledge and it won't budge. How that thing moves is beyond me. It does not have a bracket around it and I agree that it should, who knows. I'll take it to a new place and see what they can do as far as securing and possibly torquing the U-bolts down tighter.
    Thanks
  8. Jun 6, 2010 at 9:47 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    There is your problem:D
  9. Jun 7, 2010 at 8:00 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    u could take apart your leaf pack and make sure the center pin is in and/or just tighten it, as well as re-torquing your ubolts
  10. Jun 7, 2010 at 1:40 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Loosen your u bolts and realign the leaf. Install a couple of leaf spring clamps and then retighten your u bolts. As you are already aware, anything less is a total waste of time.
    I've made them for my '98 Tacoma and have had a pair installed on my 2005 for a couple of years now. Very easy to make yourself for cheap.
    8213d1258851882t-budget-leaf-spring-clam_e2f2aa1b0ab9768388e7e87591c281a63ab47abc.jpg
  11. Jun 7, 2010 at 1:43 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    you dont have to loosen the ubolts to move it back.. it happens to me with the overload leaf every now and then. just jack the truck up so the axle has no weight at all on it. then take your sledge and beat it back in line. when the weight of the truck is off it it will move when you hit it. after that i would suggest checking to make sure the ubolts are tight enough.
  12. Jun 7, 2010 at 2:11 PM
    Fortech
    CANADA
    This or you could also use a large C clamp to "press" the leaf back into place if the sledge doesn't work. Weight off the springs should be a given.
  13. Jun 7, 2010 at 2:52 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Make sure the center pin is tight. But the main thing is to make sure your u-bolts are torqued down properly. Min would be like 75lb/ft. I prefer 100lb/ft myself.
