How to keep something cool in a hot truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by In2Ndo, Aug 21, 2021.
  1. Aug 21, 2021 at 7:18 PM
    In2Ndo
    In2Ndo [OP] Well-Known Member
    California
    MGM 2021 Tacoma TRD OR
    That’s what I though too. The problem is not so much the actual meters. Even do they do need about 20 minutes to a aclimate when moving from one temp to the other. The bigger issue are the test strips that come with the meter. If exposed to high temps for long periods of time. They become unreliable. I believe the upper limit is 90 degrees. And long periods can be anything from an hour up.
  2. Aug 21, 2021 at 7:18 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    It isn’t just the meter and test strips. It’s also insulin.
  3. Aug 21, 2021 at 7:19 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    Yeah, that all makes sense. I'm curious how my FIL deals with this as he's diabetic. I'll ask and respond if I turn up anything useful.
  4. Aug 21, 2021 at 7:24 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There are only two ways to cool something. Ice in a cooler or refrigeration. That's it. Pick one.
    Skydvrr likes this.
  5. Aug 21, 2021 at 7:25 PM
    In2Ndo
    California
    By what I’ve seen. A lot of people have the attitude of “I just leave it in the car” and whatever. But I’m controlling this without meds. So I have to be more careful with the tools I use. And of course I’m also asking on a group related to my question. But I figured since a lot of you guys spend a lot of time out with no air conditioning… I might find an answer here.
  6. Aug 21, 2021 at 7:28 PM
    DLRIII
    David
    Baton Rouge
    How about a swamp cooler, 3rd category?
    Skydvrr and hiPSI[QUOTED] like this.
  7. Aug 21, 2021 at 7:32 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Only two ways man... ice in a cooler or a fridge. That's it. No other options.
    DLRIII likes this.
  8. Aug 21, 2021 at 7:41 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
  9. Aug 21, 2021 at 8:11 PM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Have you tried reaching out to the manufacturer of the monitor? I would trust what they recommend more than I would from Google or an internet board.
  10. Aug 21, 2021 at 8:19 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Can’t you just put the meter and strips in a backpack and take it with you to the beach?
    If you’re going to the beach, you should be bringing a cooler for the beverages, right?
  11. Aug 21, 2021 at 8:24 PM
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    THAT is absolutely true my friend! Excellent point.
  12. Aug 21, 2021 at 8:27 PM
    djgynee
    Southern California
    Either keep suspended in an ice cooler to prevent moisture damage or place out of the direct sunlight, in the back where you probably have dark tint and crack all windows about 1” down and if possible park in shade all these things combined will be about 30 degrees cooler than sitting out in the sun with windows up.
  13. Aug 21, 2021 at 8:35 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    doesnt do a person much good .................meter in truck
    OP in cubicle farm or factory floor.....................more than afew minutes away from meter when info is critical
    i would think Op would want it MORE accessible at snack & meal times
    simply Not a convenience device
  14. Aug 21, 2021 at 9:07 PM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Useful answer:
    They'll be fine. It is absolutely best practice to keep the strips <90F, but they are commonly used outside those bounds (we run multi-hour backcountry calls in >110F ambients) and at least one study (https://journals.sagepub.com/doi/full/10.1177/1932296815598775) shows no significant degradation with test strip exposure up to 50C (122F). Many meters do require meter temp to fall below 105F prior to testing.
    Less useful answer:
    Battery/solar powered rooftop AC unit. We get ~8 hrs of continuous operation depending on ambient temps. Wife tested, pig approved.
  15. Aug 21, 2021 at 9:13 PM
    #35
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Sounds like a good opportunity for a project. Could go with adding a second battery to run a small fridge. You wouldn’t even need to run it low because it sounds like you want it close to ambient air temperature anyway. It’s a small device it looks like. I wonder what the smallest 12 volt fridge is. Seems like the go to answer for this forum. Buy stuff, mod truck, solve problem.
  16. Aug 21, 2021 at 9:30 PM
    #36
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You could make a very small pelican box sized solid state electric cooler by using these- They run on 12V and draw about 6amps:
    HiLetgo 2pcs TEC1-12706 Semiconductor Refrigeration Tablets TEC1-12706 12V 6A Heatsink Thermoelectric Cooler Cooling Peltier Plate Module 40x40MM https://www.amazon.com/dp/B00M1PM7H6?_encoding=UTF8
    add one of these to the circuit for temperature control:
    LM YN DC 12V Digital Thermostat Module -58℉ to 257℉ Fahrenheit Temp Display Temperature Controller Board With 20A Relay Waterproof Sensor Probe Dual LED Display Red Blue https://www.amazon.com/dp/B076Y5BXD9?_encoding=UTF8
    Solid-state Peltier modules (refrigeration tablets) are pretty cool gagets, no moving parts and they have a cold and hot side for cooling or heating. Here’s some information about what and how to make use of them:
    https://www.google.com/amp/s/www.instructables.com/DIY-Portable-Mini-Refrigerator/?amp_page=true
    https://www.elecfreaks.com/blog/post/refrigeration-tablet-user-guide.html
  17. Aug 21, 2021 at 9:39 PM
    #37
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The Cooluli USB fridge is supposed to cool to 35-40 below ambient. Makeup storage is part of their marketing, so it should be a dry cool.
    OnHartung'sRoad likes this.
  18. Aug 21, 2021 at 9:47 PM
    #38
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    My ex wife who is T1D took hers everywhere…
  19. Aug 21, 2021 at 9:51 PM
    #39
    OnHartung'sRoad
    That fridge looks perfect for storing meds, or insulin and a BG monitor. It uses the same solid-state technology as I described above in the DIY version.
    Another idea for the Peltier units I posted about above is that you could use them to turn your glovebox or cubby into a cooler too!
  20. Aug 22, 2021 at 3:59 AM
    #40
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Maybe you can make a storage box under the truck to keep it somewhat cooler?
