How to: Keyless entry for the price of a KEY FOB!
Discussion in '1st Gen. Tacomas (1995-2004)' started by nchiker1, Mar 8, 2021.
  1. Feb 12, 2023 at 4:20 AM
    #41
    nchiker1
    nchiker1 [OP] Well-Known Member
    Happy to help!
  2. Feb 12, 2023 at 4:21 AM
    #42
    nchiker1
    Thanks, I’ll check it out!
  3. Feb 14, 2023 at 5:19 PM
    #43
    Norcalfire75
    Norcalfire75 Prerunner Taco
    Sonoma County
    2003 Tacoma Prerunner TRD Off-road
    I bought my truck in 2020 and The previous owner gave me 2 viper remotes but said he never used the system. I looked and my truck has the Unit behind the kick plate. I am looking to order the OEM Toyota fob but i am wondering if the existing viper system will interfere? I dont use the viper system. If I go through the setup process and erase all keys and add the new OEM one that should work right? Thanks for the help!
  4. Feb 14, 2023 at 6:17 PM
    #44
    nchiker1
    Honestly man, I don’t know anything about the viper system. But I’d bet if you have the unit the new key fob should set up just fine.
    Norcalfire75[QUOTED] likes this.
  5. Feb 14, 2023 at 6:26 PM
    #45
    Madjik_Man
    Colorado Front Range
    My 2004 had a viper crap system installed by the previous broheim owner. It eventually drained my brand new AGM battery to death. Then once I was able to condition the AGM battery back to life, the viper crap system never reset itself.... or worked again.
    I haven't uninstalled it from the circuitry either.
    Then I found the OEM key fobs for keyless entry that came with the truck. Tested them out and they lock and unlock the doors just fine. Even with the viper crap system still hooked up.
    nchiker1[OP] likes this.
  6. Feb 14, 2023 at 7:17 PM
    #46
    Norcalfire75
    Sonoma County
    Awesome man! This is the exact same boat I’m in, Thanks for the reply I appreciate it! I dont plan on uninstalling the viper system because it doesn’t do anything just like yours, would be more of a headache to remove it all and chase down the wires.
  7. Feb 25, 2023 at 6:37 PM
    #47
    Norcalfire75
    Sonoma County
    After about 1 week with the OEM fob programmed to my truck I am having some issues. While sleeping last night at about 2am my horn began to sound, full blast straight through, not beeping or sounding like an alarm. I could not silence it at all and eventually had to disconnect my battery. Around 8am I reconnected the battery and at around 10am the horn started going again. The only change to the truck recently has been the addition of the new remote. I cannot figure out why the horn would sound like this. I think I’m going to try deleting the Fob from the system and see if the horn sounds in the middle of the night again. Any tips or ideas are greatly appreciated!
  8. Mar 27, 2023 at 7:00 PM
    #48
    nchiker1
    Any chance the new fob could have the panic/alarm button stuck? Or some short in that button?
  9. Apr 3, 2023 at 10:24 AM
    #49
    umpire3
    umpire3 Well-Known Member
    Robert
    2004 Tacoma 4-door, V6
    Tried 4 FOB's and OP's instructions and couldn't get it to work on my '04 DC SR5.
  10. Apr 3, 2023 at 1:42 PM
    #50
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    I have tried throughout the years to disable the auto lock feature but never successful. Anyone have the same issue?
  11. Apr 18, 2023 at 2:37 PM
    #51
    nchiker1
    Did you check to see if you have the RS3200 receiver?
  12. Apr 18, 2023 at 2:39 PM
    #52
    nchiker1
    Nope, never had an issue. Mine only auto-locks when unlock it with the fob and then don't open a door for a minute or two.
  13. Apr 18, 2023 at 2:44 PM
    #53
    umpire3
    Robert
    I had two FOB's that worked. The unlock micro buttons on the circuit boards broke off.
    nchiker1[QUOTED][OP] likes this.
  14. Apr 19, 2023 at 12:31 PM
    #54
    nchiker1
    Cool, so you got it up and running?
  15. Apr 19, 2023 at 1:16 PM
    #55
    umpire3
    Robert
    The two original FOB's only locked the truck. Using OP's procedures, I erased all the programs. Now, nothing works.
  16. Apr 20, 2023 at 9:52 AM
    #56
    nchiker1
    Why? Cause your circuit boards are busted?
  17. Apr 20, 2023 at 11:46 AM
    #57
    umpire3
    Robert
    The mirco swithes and all other components are surface mounted and soldered to the board. The board itself is in one piece.
  18. May 19, 2023 at 4:42 PM
    #58
    umpire3
    Robert
    I was able to solder the micro switches back on the board. Using OP's instructions I got the FOB to work. Additionally, I ordered OP's recommened FOB an got it to work.
  19. May 20, 2023 at 7:51 PM
    #59
    Vtoytac
    Vtoytac Member
    2004 Red Tacoma
    Wow, I just ordered my fobs from Amazon, and when I got them I went on YouTube and programmed them myself. I had a Toyota security receiver on my dash, under the radio. The manual said that they came with the electric windows and mirrors package. The manual also tells you what the fobs frequency is to order the right fob.
  20. May 21, 2023 at 12:48 AM
    #60
    Nessal
    Texas/Bay Area
    By any chance does anyone know what frequency the remote transmit at?
    NM, it's 303.89 for anyone wondering.
