How to know if you have the towing package?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDstingray, Jun 11, 2020.
  1. Jun 13, 2020 at 5:55 AM
    #41
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Oops, screen grabbed the wrong one! Haha.
  2. Jul 27, 2020 at 2:09 PM
    #42
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Hello all, towing newbie here.... will appreciate your response.
    I have a 2016 TRD OR with Tow Package. Does my set up include an "electric brake controller"? I ask because i am about to rent a trailer, and the owner is insisting that i have this. The trailer is a 2017 Keystone Springdale 189FLWE trailer, 21 feet.
  3. Jul 27, 2020 at 2:14 PM
    #43
    41magmag41
    41magmag41 Well-Known Member
    jim
    New Hamshiire
    tacoma double cab TRD 4 x 4
    trailer control not an option aftermarket addition. But the truck has the wiring for one just plug and play basicly
  4. Jul 27, 2020 at 2:43 PM
    #44
    TRDstingray
    TRDstingray [OP] Active Member
    2016 TRD off road
    It does not have the controller.
    I got this one
    https://www.amazon.com/dp/B000P17NXQ/ref=cm_sw_r_cp_apa_i_EL0hFbPP80893
    I also got the wiring harness to plug and play behind the driver kick panel. Though to find! But it is hiding behind there!
    https://www.amazon.com/dp/B0781KTCPT/ref=cm_sw_r_cp_apa_i_IP0hFbB0PYRJ0
    vuTron[QUOTED] likes this.
  5. Jul 27, 2020 at 2:46 PM
    #45
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
    Having the tow package means Toyota pre-wired the controller harness but you still have to provide the actual brake controller unit & calibrate it once your trailer is hooked up. On a 21ft trailer, not using a brake controller would be a massive safety risk.
  6. Jul 27, 2020 at 3:00 PM
    #46
    PawelB
    PawelB Amor patriae nostra lex
    Edmonton, AB
    2020 TRD OR, DC-SB, AT
  7. Jul 27, 2020 at 4:01 PM
    #47
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Towing package has been standard on all 2016-2020 Tacoma V6's in Canada. It was optional on 2016-2017 Tacoma V6's in the USA and standard on 2018-2020's. 4-Cylinder models do not have an available towing package.
    As for how to tell if the vehicle has the towing package, there are a few ways. Other than just looking it up, you can tell physically on the truck in the following ways:
    1. Is it a V6? Only V6's had an available towing package.
    2. Does it have a factory hitch? Without experience you may or may not be able to tell, but for 2016+ Toyota only offers a hitch for the Tacoma from the factory, not as a dealer-installed accessory.
    3. Does it have the factory 4/7-pin connector in the bumper? It is possible that someone adds this when using an aftermarket hitch, but it's less likely.
    4. Does it have the 130A alternator with the part number 27060-0P350 on the label? Again it is possible someone swapped this out from the non-towing package 100A alternator.
    5. Does it have an engine oil cooler? This was posted earlier in the thread, and is only on trucks with the towing package.
    6. Does it have the power steering cooler? This is a section of finned tubing mounted near the bottom of the rad support. It is unlikely someone would add this to a truck.
    7. If it is an automatic, does it have the auxiliary air-liquid transmission cooler mounted in front of the radiator on the LH side? Many people add transmission coolers to their trucks, so look for a factory one with part number 32920-04040 printed on it. (Note: 2020 trucks produced from 03/2020 no longer have this external cooler, but only use the internal ATF cooler in the radiator). It is unlikely someone would have added the factory cooler to their truck, most prefer to go aftermarket for larger coolers at a lower cost.
    Jeff
  8. Jul 28, 2020 at 8:52 PM
    #48
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    TSC is a button inside the cab, it should be up on the headliner near the interior lights.
  9. Jul 29, 2020 at 5:39 AM
    #49
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
