How to know my Tranny was Flushed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 13, 2012.
  1. Jan 13, 2012 at 5:58 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    So for the first time ever I gotta take my track to the local dealership to get the tranny flushed. Is there any way to ensure that it gets done other than watching the whole process?
  2. Jan 13, 2012 at 5:59 AM
    jeremy_283
    Is there a way to look at the fluid?
  3. Jan 13, 2012 at 6:01 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You would have to pop the drain plug open.
  4. Jan 13, 2012 at 6:02 AM
    Brunes
    Brunes abides.
    Rotorhead
    Put torque stripes on the drain and fill bolts...
  5. Jan 13, 2012 at 6:04 AM
    jeremy_283
    From the way it sounds they just hook up a machine to two hoses and there are no drain or fill plugs removed...
  6. Jan 13, 2012 at 6:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    Hrrmmmm...In that case put a cap or something on there so you can tell if they've touched the connections??
  7. Jan 13, 2012 at 6:12 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    They should still have to remove the drain plug. That machine is used to flush the torque converter but I believe the transmission still needs to be drained. Either way, there is a check plug that would need to be pulled to ensure the transmission fluid is at the proper level.
  8. Jan 13, 2012 at 6:14 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes?
    <-- needs more coffee
  9. Jan 13, 2012 at 7:11 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
  10. Jan 13, 2012 at 7:13 AM
    Pugga
    Massachusetts
    F-150 Mod
  11. Jan 13, 2012 at 7:36 AM
    jeremy_283
    That's a drain and refill :facepalm:not a flush, a flush is suppose to clean out all the crud and muck and from what I understand a drain and refill does not do it as good as a flush.
  12. Jan 13, 2012 at 7:38 AM
    ruggedT
    ruggedT The Sticker Guy Vendor
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Just do a drain/fill every 15-20k. Skip the whole flushing mess.
    I just did my 3rd over christmas. 85k
  13. Jan 13, 2012 at 7:41 AM
    jeremy_283
    just to think about it. are dealerships more reputable then jiffy lube and stuff probably?
  14. Jan 13, 2012 at 7:44 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Flushing just cycles crap through the system.
  15. Jan 13, 2012 at 7:51 AM
    jeremy_283
  16. Jan 13, 2012 at 7:52 AM
    Pugga
    Massachusetts
    F-150 Mod
    Obviously that's a drain and refill... If you want to do a full flush, search, there's a DIY for that also. A drain and refill is better than nothing and will still got a lot of the contaminants out of the system. If you're overly concerned, do the drain and refill 10,000 miles sooner. Regardless, you'll know it was done, you'll know you have fresh fluid.
  17. Jan 13, 2012 at 7:53 AM
    jeremy_283
  18. Jan 13, 2012 at 7:57 AM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Stealership, Shittylube, etc., will not be using pump inlet method. A flush won't hurt anything (definitely not trying to be against it), but more of just a DIY drain n fill kind of guy...then again both trucks as pictured below are stick :rolleyes:
  19. Jan 13, 2012 at 8:06 AM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    And I supposed your the be all, end all authority?
  20. Jan 13, 2012 at 8:33 AM
    jeremy_283
    he does have 26,XXX posts :p :rolleyes:
