How to level 4" Camburg spindles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajan246, Feb 3, 2012.
  1. Feb 3, 2012 at 10:03 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    They are maxtrac, 450$...I believe you can get them for 550 now.
  2. Feb 3, 2012 at 10:06 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    just to show u an idea, all pro expos in the rear, coils and lift spindle up front...
  3. Feb 3, 2012 at 10:09 PM
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Actually i dont know, lol. Before i had my spindles, i had billies set at 2.5" and 285s. I rubbed a lot with that set up, so i cut out a lot of the plastic and did the cab mount chop so i could fully stuff my tires. So im not really sure whether you would rub or not with spindles and 285s.
  4. Feb 3, 2012 at 10:13 PM
    ajan246
    ajan246 [OP] Well-Known Member
    Orange County, CA
    2012 Access PreRunner V6 2WD
    good lord.... i thought deciding on a lift was hard enough... trying to understand wheels/tires... :annoyed:
    I'm gonna search for some sort of comprehensive wheel/tire guide. This is making my head hurt.
  5. Feb 3, 2012 at 10:15 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Talk to member KPT on here, he is the resident wheel and tire guru. Out of curiosity what do you want to know? I can help with most stuff.
  6. Feb 3, 2012 at 10:17 PM
    kinkrider101
    santa barbara
    wheels and tires
    Just get a 16x8 or 17x8 with 4.5" bs with a 285 and call it a day haha.
  7. Feb 3, 2012 at 10:20 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    ^This, lol
  8. Feb 3, 2012 at 10:27 PM
    ajan246
    Orange County, CA
    lol too easy!! what about all my other options!! who knows what else is out there!!...
  9. Feb 3, 2012 at 10:32 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I do, whatever you are willing to pay for. Jk, im sure if you hunt enough you can figure it out, it just depends whether or not you have the self control to hold out until you find the perfect set up:D
  10. Feb 3, 2012 at 10:37 PM
    ajan246
    Orange County, CA
    I just wanna see endless pics of setups... people never put enough description in their posts. You find some truck that looks PERFECT and the dude's only comment is "my truck"
    bastards.
  11. Feb 3, 2012 at 10:49 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Ahahahahahahah, i know exactly what you mean. Suprisingly enough, i actually keep mine up to date for the most part, but thats because im too lazy to make a build thread, lol. Thats the easiest way to find what your looking for, just go through the 2nd gen build threads section. Also this my help: http://www.tacomaworld.com/forum/suspension/83016-lets-see-your-spindle-lifts.html
  12. Feb 3, 2012 at 11:01 PM
    ajan246
    Orange County, CA
    sick man. i'll sub to your pages. watch out for me bro... i'm getting this truck and i work in IT and dont do sh** at work except sit on the computer and browse the forums. i've already said goodbye to all my monies. :sorry:
  13. Feb 3, 2012 at 11:12 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Ill see you around then huh, lol. My roommate works in the IT department here at school and all he does is play on the computer all day. I have my money spent before i even make it, lol. This site is an incureable disease.
  14. Feb 23, 2012 at 12:01 AM
    milo39
    milo39 Well-Known Member
    myles
    downey,ca
    07 doublecab prerunner trd off road
    how far does the tire stick out with 16x8 4.5 bs and camburg spindles? i kind of like the wide stance for front and sticking out a little in the back. how does 4.5 fit in the back also? i like that beefy look.
    tire and rim size is a headach!
  15. Apr 12, 2012 at 6:33 AM
    #35
    tony92629
    tony92629 Well-Known Member
    Tony
    Dana Point
    2010 White Tacoma Prerunner
    5100's all the way around. Front set at .85. Camburg Spindles. Camburg Uniball 1.25 UCA's. Total Chaos LCA skid plates. Custom Deaver 10 pack rear leaf spring. BFG AT KO's 285/70/17, Weathertech floor liners, Wet Okoles. Midland CB/PA, Firestick.
    Camburg spindles - 5100's set at .85 - stock springs. Spidertrax spacers in the front. 3" Deavers in the rear. Needed to add a shim to straighten out the drive train (slight vibration before shim). 285/70/17's. Slight rub with my 250 pound girl friend in the front seat...Need to fix that. Perfectly level and better than stock ride - Could not be happier with the set up.
  16. Apr 12, 2012 at 6:41 AM
    #36
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  17. Apr 12, 2012 at 8:42 AM
    #37
    dewilmoth
    dewilmoth Member
    Jacksonville, FL
    I love it with the stock wheels. I like them better than 99% of aftermarket wheels.
    What's the minimum thickness spacer you can use and still clear the spindles with the stock wheels on your setup? I think I may copy your lift.
  18. Apr 13, 2012 at 5:59 AM
    #38
    tony92629
    Tony
    Dana Point
    The stock rims work without a spacer with less than a quarter inch of clearance from the spindles. The balancing weight on the rim was moved to the inside to avoid it from hitting the spindle...that's how close it was. I like the wider stance look with the spacers.
  19. Apr 13, 2012 at 8:54 AM
    #39
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    The stock rims will work without a spacer, but the tire will rub the spindle.
  20. Apr 15, 2012 at 7:26 AM
    #40
    tony92629
    Tony
    Dana Point
    Mine didn't when I wasn't running spacers. Even with the 285/70/17's. It was close, but they didn't rub.
