How to lift my new taco
Discussion in 'Suspension' started by Tsenekos, Aug 27, 2009.
  1. Aug 27, 2009 at 2:28 PM
    Tsenekos
    Tsenekos [OP] Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    So Im back in the tacoma scene again with a 2005 dc trd offroad 4wd, I sold my sti and bought this. I had a 2000 4wd trd before and put a revtek kit on it with the 32" bfg km's and a ller canopy was really sweet.
    My question for you guys is this
    I want to lift my dc max 3" to level it out and get a bigger tire so here is my idea and would like some input from you guys pro cons etc?
    I was thinking off odering the Bilstein 5100's front and rear set as my truck has 50k on it so i thought get the rears too maybe the stock are getting soft,
    Set the fronts at 2.5" and do a add a leaf in the rear (not sure which one to level it all out with the fronts at full 2.5")
    A set of bfg at ko's 285/75/16
    will this work well? the truck will unfortunatly be mostly road driven with some off roading (I live on the prairies not much but farmers fields here)
    With the 5100's at 2.5" should I do a diff drop?? or is it fine?
    will the 285's fit ok (running the stock wheels)
    Is this a better set up than the rev tek? or should I go that route again??
    thanks alot guys sorry its long and if its been asked before but Im pretty excited to start wrenching on this taco.
  2. Aug 27, 2009 at 7:30 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    that is a better setup than revtek in my opinion, set the front 2.5 and you might not need an aal, if you do it might be a 1.5". change the rear shocks and you might not need a diff drop, buy it just in case and if you need it use it if not put it in a drawer. your new tires will fit, minor trimming may be needed but no big deal. you are on the right track.
  3. Aug 27, 2009 at 9:59 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    thanks bajamoon the more I read here the more Im steering way far away from a spacer lift, but now I came across the toy tek ultimate kit looks great but more bread too
  4. Aug 28, 2009 at 6:12 AM
    bajamoon
    STEVE
    Whittier
    the ultimate lift is nice too but it uses a 5100 shock in front, i would just go with the 5100's and if later you want a coilover just buy some nice king's or fox's
  5. Aug 28, 2009 at 8:00 AM
    Tsenekos
    Greg
    Edmonton, CANADA
    o really damn, are the wheel spacers hard on wheel bearings and what would i need 1/4" or more ??? thank you
  6. Aug 28, 2009 at 8:31 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    What is your wheel backspacing? If you have anything less than 4.74, you won't need spacers. I have 4.74 and i clear everything fine with my 285's.
  7. Aug 28, 2009 at 5:32 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    i got a 2.5 inch lift, and 285/75/16 with little 1/4" wheel spacers up front and i don't rub at all
  8. Aug 28, 2009 at 8:11 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah, the 2nd. gens are different then the 1st.
    I think he would even have to do some trimming with a 3" lift. But very little, I would do the 3" if I were you...
    And a 2" AAL in back with 5100's
    Just my 2cts.:)
  9. Aug 28, 2009 at 8:36 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    ya just running the stock 16" trd wheels...are the wheel spacers hard on the wheel bearings?
  10. Aug 28, 2009 at 8:38 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    im thinking the billy's 5100's all around set at full 2.5 with a add a leaf 1.5 in the rear and 265/75/16 goodyear dura tracs they are a 32" should work fine....right guys and thanks for all the help on this
  11. Aug 29, 2009 at 9:03 AM
    Tsenekos
    Greg
    Edmonton, CANADA
    ya I agree looks great and pretty common here, I also had a thought would running a small top plate spacer to gain 3/4 to 1 inch and then set the 5100's at 1.5 or 1.75 be benificial in anyway because I wouls be gaining that inch in downward travel on the 5100's ?????:confused:
  12. Aug 29, 2009 at 9:38 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    if your concerned about suspension travel then stay away from the old spacers all they do is limit travel. you'd be better off setting the 5100's at the 2.5 setting
