How to light up a momentary switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ROBSTOY, Dec 11, 2013.
  1. Dec 11, 2013 at 10:29 AM
    ROBSTOY
    ROBSTOY [OP] Active Member
    Rob
    Ohio
    2014 SR PKG
    Debadged, Painted "T" emblem
    For all of you electrical geniuses... I am looking to change my garage opener mod to use an illuminated momentary switch. I would like to have the switch light up when the head-lights are on (in other words when it's dark outside). As the switch is only connected directly to the opener, is it possible to illuminate using a connection from the truck? If so...how?
  2. Dec 11, 2013 at 10:31 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    is there already bulb behind the switch to light it up?
  3. Dec 11, 2013 at 10:35 AM
    ROBSTOY
    Rob
    Ohio
    2014 SR PKG
    Yes. The switch is lighted.
  4. Dec 11, 2013 at 10:36 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    and right now, it only illuminates when pressing the button? so i'm guessing there are 3 posts on the back:
    power in
    power out
    bulb ground
    yes?
  5. Dec 11, 2013 at 10:37 AM
    Large
    Large Red
    A picture would help tremendously. But to answer the inquiry, you would need a 12v hot wire from the headlamp wiring or relay, tie directly to the wiring.
  6. Dec 11, 2013 at 10:46 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Your garage door probably uses a different voltage to the lights. You would need to figure out that voltage, tie into a lighting circuit in parallel and drop the voltage with a resistor.
  7. Dec 11, 2013 at 10:55 AM
    ROBSTOY
    Rob
    Ohio
    2014 SR PKG
    i mispoke...the switch does not have a bulb. i would have to change the switch to one that is lighted!
  8. Dec 11, 2013 at 10:56 AM
    ROBSTOY
    Rob
    Ohio
    2014 SR PKG
    Off topic...I love the Gif file you use! I will have to try that sometime!!
  9. Dec 11, 2013 at 10:56 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Yea after some searching i dont think a three pole switch can be illuminated all the time because you cant switch power and ground.
  10. Dec 11, 2013 at 12:08 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    Check out www.otrattw.com for switches. they can do custom switches too (see THIS PAGE for an example garage door switch).
    You'll need a momentary on/off with independent LED. Contact the guys at OTRATTW for details -- they can set ya up!
