How to lower for disability needs
Discussion in '1st Gen. Tacomas (1995-2004)' started by ircaptbob, Mar 25, 2012.
  1. Mar 25, 2012 at 9:29 AM
    ircaptbob
    ircaptbob [OP] New Member
    Bob
    Buford, GA
    03 Tacoma
    I need ya’lls advice from a different perspective. I’m your normal truck loving, outdoors guy who happened to pick up a disease called IBM (Inclusion Body Myositis). My autoimmune system attacks my muscles, making it increasing difficult to climb steps or get up from a standard chair. One of my guilty pleasures is being able to still drive myself. So I sold my F150 and got a ’03 Tacoma DoubleCab, with the off road package. The goal being that the Tacoma is easier to drive and get in and out of with the exception that it is a little too tall… most days it is ok, but on “tired” days I just can’t climb in.
    So I see all the posts about lifting Tacoma’s and with all the experience and brainpower out there can anyone give me some advice or direction on how to lower a few inches? As far as I know everything is stock except the wheels, but they are stock size. If I can’t figure something out, I’m going to have to sell it and buy something else. Thanks in advance for the help, you guys are the best, Bob
  2. Mar 25, 2012 at 12:56 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Hi Bob, there are kits out there for lowering just like there is for a lift, shorter coil springs for the front & for the back budget wise, you could take off the overload spring (if you don't do any heavy hauling) which by itself would lower the back by at least 1/2", it doesn't sound like much but you'd be surprised by the difference, I'm a "lift" guy myself but there are members here that have done alot of lowered trucks that hopefully chime in with other ideas, welcome to TW & good luck....:)
  3. Mar 25, 2012 at 1:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  4. Mar 25, 2012 at 3:48 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    just wondering, would it be easier to get/fab some sort of drop down step that would go about half way to the ground then fold back up instead of dealing with lowering the truck? .
  5. Mar 25, 2012 at 3:53 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    Drop to 235/75/16 tires for a lower profile?
  6. Mar 25, 2012 at 3:54 PM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    He mentioned something about climbing steps being a problem.
  7. Mar 25, 2012 at 3:59 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Cooper Discoverer ATP 285/50, Bilstein 5100's all around, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, Clazzio seat covers, BHLM with removed turn lens, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    I feel your pain, Bob. I have osteoarthritis in my hips. In fact, I just had my first of two hip replacements about 6 weeks ago. Like yourself, I was having difficulties getting into the truck. I decided to pick up a set of step bars. Once installed, I found it much easier to get in. I liked the look of the OEM units, but they tend to hug the body on the 2nd gens. So I went aftermarket with a set of Westins. Shop around and you might find some that sit pretty low. It definitely helped in my case. I hope it helps for you too. :thumbsup:
    BTW, in case you're wondering how I got in on the "bad" days? I backed my butt up to the seat, grabbed the "oh shit" handle and the seat, put both feet on the step and pushed up. It looks funny, but it works.
  8. Mar 25, 2012 at 4:05 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Wouldn't be significant. It's only a little under 1/2" difference in vehicle height, but with the diameter being over 3/4" smaller it would look bad on the stock suspension, and it would increase the already-off speedometer error by another 3mph at 70.
  9. Mar 26, 2012 at 1:21 PM
    ircaptbob
    Bob
    Buford, GA
    03 Tacoma
    Hey guys, thanks for the advice. Generaly speaking, steps don't work for me any longer but the step bar may give me that "push" I need as CRU described. I've been a butt backer for a while now. Enjoy life, it is hell getting old!
  10. Apr 5, 2012 at 12:00 PM
    ircaptbob
    Bob
    Buford, GA
    03 Tacoma
    So doing my shopping for a lowering kit, being told that a pre-runner suspension is the same as a 4runner. So basically there is not any “easy” way or kit to lower a pre-runner. Any thoughts out there to help or confirm what I’m being told? Thanks, Bob
  11. Apr 5, 2012 at 4:25 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I think about the cheapest way would be to remove the shocks and coils and have someone cut about a half a turn off of the coils. Not sure how that would worl with the shocks, but it would sit lower. Maybe have to buy a shorter shock to make it work? Not really sure.
  12. Apr 5, 2012 at 5:18 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    no, there really is no easy way to lower this suspension. every now and then people will ask how to lower a prerunner to get a street look...and generally the lowered guys just say buy a 5 lug, because its not worth it to lower a prerunner
  13. Apr 5, 2012 at 7:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Prerunner is the same as 4WD... NOT the Toyota 4-Runner, which has coils on the rear.
