How to make 12V on actually turn lights off
Discussion in 'Lighting' started by Elvota, Sep 30, 2021.
  1. Sep 30, 2021 at 10:03 PM
    Elvota
    Elvota [OP] Well-Known Member
    2006 Tacoma TRD
    I know this will be confusing to describe... hopefully my diagram will help. I have not shown fuses and battery just to keep it simple.
    I have primary LED's that energize with ignition switch on.
    I have a second set of LED's that energize only with a switch on the dash.
    I would like to be able to flip the switch on the dash and turn on the secondary LED's while simultaneously turning off the primary LED's.
    So...
    Dash switch on: primary LED's off, secondary LED's on
    Dash switch off: primary LED's on, secondary LED's off
    What I can best describe that I am looking for is a relay that works in reverse. A relay that when energizes opens and shuts of 12v to the primary LED's.
    Is there such a relay? I doubt "relay" is the correct name for such a component... but a device that opens when 12v is applied.
    I am lacking the terminology to even Google what I might need or to find a solution.
    Thanks...
  2. Sep 30, 2021 at 10:07 PM
    ascendr
    ascendr Active Member
    Terminal 30 to 12v ign (high current), 87a to primary, 87 to secondary. 85 to ign through switch ( low current) , 86 to ground
    Elvota[OP] likes this.
  3. Sep 30, 2021 at 10:13 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    That's how I'd do it (except I would do 86 to switch, 85 to ground if you are using a relay with a diode parallel to the coil). What you are look for is usually referred to as a Single Pole, Double Throw (SPDT) or NO/NC. Do these need to be waterproof?
  4. Sep 30, 2021 at 10:21 PM
    Puppypunter
    Johnny
    2019 Black SR
  5. Oct 1, 2021 at 6:31 AM
    Elvota
    2006 Tacoma TRD
    Thanks for the quick responses... was hoping it was something relatively simple.
    I will give your suggestions a try.
  6. Oct 1, 2021 at 7:24 PM
    TheScirocco
    TheScirocco Member
    Peter
    Rustfree 1998 Tacoma SR5 RWD 5 speed
    K&N panel filter.
    It is pretty simple... The 5 terminal relays have an output, that switches the 5th terminal off, when its energized, and on when power is off. i.e. it does the opposite of a regular 4 wire relay.
    Elvota[QUOTED][OP] likes this.
  7. Oct 2, 2021 at 12:48 PM
    caribe makaira
    Caribbean, Puerto Rico
