How to make a "CAI" into a Ram Air TCAI for 40$
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cheeto6182, Mar 26, 2010.
  1. Mar 26, 2010 at 9:26 AM
    Cheeto6182
    Cheeto6182 [OP] Cheeto
    Sean G
    Denver, Colorado
    05 Tacoma TRD Offroad DoubleCab
    JBA Headers, Custom Snorkel/Ram-Air Intake, Spal Electric Fan Conversion, TBS lol, Borla Exhaust, ToyTec Coilovers, Old Man Emu Rear Leafs, Bilstein 5100's, Alpine system (type R's), 4.56 Gearing, 285/75/R16, Bead Lock Rims, Bed Carpeting, SoftTopper, Ram Air intake Mod, URD MAF, Dash Dyno, One Piece Drive-Shaft Conversion, Bed Cubby Led Lights, 12,500 Lbs winch, Expediation bed racking system, Hella Lights, Custom front winch bumper
    I have an AirAid CAI that wasn't really a TCAI because the incoming air/filter was still within the engine compartment. After looking at a few ram air set ups I figured I could make mine for less money. For now I wanted to keep the stock air box because I have the URD MAF that is programmed for it. Eliminating that airbox required a re-tune.
    Tools
    1: Grinder
    2: Screwdriver
    3: Drill
    Parts
    1: 3 inch exhaust pipe (14.00$)
    2: One 3 inch air duct bracket from home depot (2.99$)
    3: One Spectra intake mounting plate from Checkers (5.99$)
    4: One Spectra intake tube coupler from Checkers (7.99$)
    5: Spray pain (2.99)
    6: One flexible duct from from home depot (5.00$)
    7: Six self tapping screws (2.00$)
    Procedure:
    1: Remove Grill
    2: Cut a square out of the sheet metal next to the radiator
    2: Take your flexible ducting and mock up where you want the pipe to go. This way you can take it to an exhaust shop and they can use it as a template for your permanent piping. When making your mock up put the grill back on so you can make sure it lines up with the middle slot on the grill.
    3: Go to an exhaust shop with a six pack of beer, bullshit with the one who looks like a beer drinker, talk about manly stuff, make a friend, go home with your custom shaped intake.
    4: Put the intake tube where it will go (if you haven't already cut the tube to size/length this is when you'll do it) and mock up your bracket and air duct plate. My bracket was too big for the pipe so I used some weather stripping I had around to snug up the fit. This turned out to be a plus because it eliminates any possible squeaking from the metal to metal contact on the pipe/bracket. Eventually I will put a nicer bracket in though.
    5: Cut out your scoop from the front of the pipe. I had the shop bend out the end of the tube so it would work like a slide for the air.
    6: Mark where your bracket and intake duct will go. I didn't have a hole cutter bit, this is why I got the air duct plate. It's easy to cut a square out with a grinder. For the bracket and duct plate screws I drilled a guide hole with the smallest bit I had so the self taping screws wouldn't walk on me when it came time to mount.
    7: Mount your air duct bracket and put your coupler on it. Mock up one more time to make sure everything is Kosher.
    8: Paint
    9: remount/assemble and replace grill
    Now I have a ram air true cold air intake. The downside to this set up is the AirAid is not a sealed box, but that can/will be changed soon. All it will take is some sheet metal.
    I'll also go to a plumbing supply store aka home depot and get a plug for the pipe so I can close it during bad weather and not suck up the elements.
  2. Mar 26, 2010 at 9:35 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    forgot the engine compartment one
  3. Mar 26, 2010 at 10:07 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    looks sweet man!! great idea and great job!!
  4. Mar 26, 2010 at 10:11 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Cool! Yeah you're going to want to have a cap for the rain. Thats why people are having a lot of problem with the URD true cold air intake.
    +Rep to you.
  5. Mar 26, 2010 at 10:45 AM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    great idea and great job fabricating
  6. Mar 26, 2010 at 11:01 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    In the name of science I went out and got a wireless thermostat with a remote sensor. I mounted the sensor on the wall away from the engine with some thick double sided foam tape that I am hoping provides some insulation from the metal so I measure the air temp and not the metal's. I cruised up and down the same stretch of street, first with the pipe clogged, then with it open. I'm not sure about the quality/accuracy of this thermostat but there is definitely a difference here. Check out the pics, the "out" temp is where the sensor is in the intake. The "in" temp in the temperature inside my truck with all windows down.
  7. Mar 26, 2010 at 11:10 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    Yea my issue with the URD CAI was the outside filter, I live in Boulder Colorado and there is a lot of snow mud in my grill after a long drive. During Winter this can just be closed =)
  8. Mar 26, 2010 at 8:16 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Looks great man!
  9. Mar 26, 2010 at 9:13 PM
    sp8ed2010
    sp8ed2010 Well-Known Member
    Dale
    Tempe AZ
    2010 prerunner trd or
    prob not the best idea for the colorado elements. Like the idea though and nice job.
  10. Apr 4, 2010 at 8:51 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    did you get the idea from empire performance and offroad? im in the process of my custom Cold Air Intake :D
  11. Apr 5, 2010 at 5:15 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    I was looking at getting the URD TCAI but didn't want snow and mud of Colorado winter roads getting directly to the air filter. I built a cover for it similar to the deck-plate mod so its not always open. The design just kinda evolved on its own lol Good luck with your CAI!
  12. Apr 5, 2010 at 6:05 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    Great job!. I am brainstorming, figuring a way to make a ram air for my hood scoop but having difficulty of trying to figure a way to prevent water from going in. I'll keep searching..
  13. Apr 5, 2010 at 6:13 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Be careful with this idea. Where the scoop is located on the stock sport hood is not a high air pressure area as the scoop is not high enough (or forward or back enough). If you plumb the scoop and keep the stock fender intake area plumbed, I would expect that the air will flow from the high pressure fender area OUT through the scoop. This will scavage intake air, not ram it.
    Again, just speaking from a thought concept here, haven't tried it myself.
  14. Apr 5, 2010 at 6:26 AM
    Wattapunk
    Uncle K
    TX
    After researching some forums here, looks like its not going to work. Due to tacoma's aerodynamics, air travels over the scoop. Oh well, maybe I can make the scoop blow bubbles..
  15. Apr 5, 2010 at 6:29 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Not to rain on your parade, but it's no Subaru. Same reason as stated above.
