How to make first gen brakes even better?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tekneek, Apr 27, 2019.
  1. Apr 27, 2019 at 9:27 AM
    Tekneek
    Tekneek [OP] Well-Known Member
    Spacers, list, deck plate mod, tundra brake upgrade
    hi, just bought an ‘01 prerunner. Previous owner did the tundra brake upgrades and the truck still feels like I could do with snappier braking. Anything else I can do to upgrade the brakes on this thing? Previous owner mentioned I should look into upgrading the master cylinder?
    It’s got those metal front bumpers and some skid plates and 35 inch tires. So I know it’s not gonna brake like a Ferrari but I was wondering if y’all can help me think of ways based on what you did to make this truck brake a lot faster
  2. Apr 27, 2019 at 9:31 AM
    1997tacomav6
    Denver
    Stainless steel brake lines front and reat big difference and new brake fluid and better brake pads like EBC or Hawks
    , slotted rotors
    Tekneek[OP] likes this.
  3. Apr 27, 2019 at 9:40 AM
    Tekneek
    Thanks for the quick reply. Do you think these upgrades will help it stop on a dime? Cuz that’s what I’m hoping to get. Also what can I expect to pay for an upgrade to steel lines and new pads? Gonna have someone else do it haha
  4. Apr 27, 2019 at 9:47 AM
    1997tacomav6
    Denver
    I didn't go with the Tundra upgrade,
    But with the stock setup I did these 3 things and there was a huge difference.
    My truck stops on a dime but its not a heavy truck
    Stainless steel lines front and rear from LC 125 or so
    EBC pads green stuff 7000 125.00
    Drilled slotted high carbon rotors 150.00
    Dont know about installing prices
    Luv my yota and Tekneek[OP] like this.
  5. Apr 27, 2019 at 10:05 AM
    1997tacomav6
    Denver
    If you do these on top of the tundra uograde I would imagine a big difference
  6. Apr 27, 2019 at 10:06 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Rear disc conversion is also an option.
  7. Apr 27, 2019 at 10:08 AM
    Tekneek
  8. Apr 27, 2019 at 10:09 AM
    Tekneek
    No ones mentioned a master cylinder upgrade. I assume this doesn’t make a big difference?
    1997tacomav6 likes this.
  9. Apr 27, 2019 at 10:52 AM
    Tekneek
    How does this look to meet all this?
    FRONT Powder Coated Red [2] Calipers + [2] Rotors + Quiet Low Dust [4] Ceramic Pads Performance Kit
    https://www.amazon.com/dp/B00EOBMFAY/ref=cm_sw_r_cp_api_i_QyjXCbQBQ1K8Y
    This with the LCE stainless steel lines?
  10. Apr 27, 2019 at 1:55 PM
    1997tacomav6
    Denver
    I don’t know anything about those pads,
    As long as rotors are high carbon that’s good
  11. May 5, 2019 at 11:39 AM
    Cjcape
    Cjcape Well-Known Member
    2016 trd dcsb sport manual(For Sale), '98 4runner SR5 sport
    You looking for more assist? Can you lock up the brakes/abs? If so, ...
    If you are towing heavier loads then the Tundra larger rotors gives more thermal mass, less fade.
  12. May 5, 2019 at 3:35 PM
    jagsmaniac
    jagsmaniac New Member
    2003 Tacoma double cab, 2wd, V6
    Stock
    Does anyone know what the Tundra brake upgrade adds in weight?
  13. May 5, 2019 at 3:44 PM
    Tekneek
    I’m not sure. I just bought the truck and I don’t know, although the previous owner says he could lock it up when he brakes so I guess that’s a yes? Looking to see if I can add even more stopping power though. Doing the SS brake lines but any other ideas would be awesome.
  14. May 5, 2019 at 3:49 PM
    Winkle99
    Winkle99 Don't Look Back
    David
    CO
    99 XCab 3.4 Manual 4x4 TRD SR5
    Check this post for weight details:
    1997tacomav6 and Wulf like this.
