how to make hard boiled eggs
Discussion in 'Food Talk' started by brutalguyracing, Dec 13, 2010.
  1. Dec 13, 2010 at 7:46 AM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    how to make good easy peelin hard boiled eggs???
  2. Dec 13, 2010 at 7:47 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    boil for 20 minutes. Soak in cold water afterwards.
  3. Dec 13, 2010 at 7:49 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Old eggs peel easier. The fresher the eggs, the tougher it is to get the shell off.
  4. Dec 13, 2010 at 7:52 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    you mean boil the water dump eggs in ....for 20 mins.....
    old eggs is not a problem
  5. Dec 13, 2010 at 7:52 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, but put them in lightly so you don't break them.
  6. Dec 13, 2010 at 7:53 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I was always told to add salt in water:confused: Not sure how that helps.
  7. Dec 13, 2010 at 7:53 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ok doing that in 5 mins.....
  8. Dec 13, 2010 at 7:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Get a pan of water using hot tap water. Put pan on the stove and put the stove on high....put the eggs in the pan immediately. When the water starts boiling, start the timer. I just did a dozen of eggs for about 15 minutes.
    At that point, I remove from heat. Using a spoon, I'll put each egg (individually) under really cold tap water for about 30 seconds each.
    I think the key is the HOT - to - COLD transfer that helps them crack open easier.
    That's how I do it....
  9. Dec 13, 2010 at 7:54 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That just lowers the boiling point.
  10. Dec 13, 2010 at 7:56 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :thumbsup:
  11. Dec 13, 2010 at 7:59 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    good thread now we just need a smoothie thread
  12. Dec 13, 2010 at 8:03 AM
    mjp2
    NJ
    :p
  13. Dec 13, 2010 at 8:08 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    *seconds this idea*
  14. Dec 13, 2010 at 8:18 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    .........then blame me.....................again.
  15. Dec 13, 2010 at 8:22 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    what??
    here is how you boil and egg to "hard boil". cold water, put the eggs in, turn the stove on high. once the water boils, shut the stove off, and cover the pot. wait 20 minutes. then dump them in a bowl of ice water. your eggs will be perfect. there wont be that grey layer of egg yolk.
    crazy to boil water and then add eggs..too many elements of danger.
    and yes, really fresh eggs are gonna be difficult to peel. i dont boil my chicken eggs.
  16. Dec 13, 2010 at 8:27 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Anyone know which motor oil is better???
  17. Dec 13, 2010 at 8:47 AM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    Actually adding salt to water increases the boiling point...it lowers the freezing point, hence why it's dumped on roadways. :cool:
  18. Dec 13, 2010 at 8:47 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    Uhh it raises it. But not by any significant amount, so it's kind of useless unless you're trying to season your shells.
  19. Dec 13, 2010 at 8:56 AM
    Buzz
    Buzz Active Member
    I use an electric kettle.
    Put the eggs in with cold water. Turn on the kettle. The kettle turns itself off when the water boils. I'll let the eggs sit while the water cools down, but at least 20 minutes. Perfectly boiled eggs every time.
    The kettle is also great to get quickly boiling water for pasta or rice.
  20. Dec 13, 2010 at 9:02 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    .............by .5°C per 58 grams.........:burnrubber:
