How to make my engine last 400,000 miles or more?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaTyler_2002, Nov 25, 2019.
  1. Nov 25, 2019 at 7:55 AM
    1997tacomav6
    Denver
    An added note might be to get a scanguage.
    A scanguage will tell you the EXACT temperature of your motor.
    The dash temperature gauge does not.
    The block is made of cast iron
    The heads made of aluminum
    The heads being aluminum cool differently than cast iron.
    Aluminum is less tolerant to heat and warping from heat and less
    likely with cast iron at the same temperatures
    So running the engine hot or over heating it you can pop a head gasket easily =2500.00
    It’s imperative to NEVER let these engines run hot or overheat.
    3.4 motors are pretty common to have head gasket issues because of this.
    So make sure radiator and fan clutch are up to par
    CS_AR likes this.
  2. Nov 25, 2019 at 8:10 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Harder question to answer is how to NOT make it last to 400k.
  3. Nov 25, 2019 at 8:13 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Honestly, just follow Toyota's recommended service intervals and enjoy your truck. Many on here overthink maintenance and actually cause more problems monkeying around with something and replacing parts that aren't broken and/or they spend all their time stressing about something that "might" happen. Some trucks run perfect to 500k and other ones can't make it more than 150k. It's luck of the draw sometimes...Just fix it if something breaks. The forums are like WebMD, you look up headache symptoms and two hours later you're convinced you have terminal brain cancer and will need surgery next week.
    One of the guys I wheel with DD's 3.4 5 speed with 430k on it and has done nothing but oil changes and an alternator on the engine. At one point, the timing belt had 200k on it before he changed it. Sadly the rust will take the truck to the grave before the drivetrain does. Other guys get the motor a little warm once with 150k and pop a head gasket.
  4. Nov 25, 2019 at 5:58 PM
    JDouma82
    JDouma82 Active Member
    Justin
    04 black Double Cab Trd
    Bilstein 5100s w/ Eibach 3”springs Old Man Emu Dakar’s w/ Amal 33x12.50 Bfg Muds on Steelies 4.56 gears
    Since it’s a 3rz I’d say a good valve adjustment is recommended. That engine loves to burn exhaust valves. My previous Tacoma was a 98 3rz and I checked the valves every 20k,( I know overkill) but they needed to be adjusted.
    Also, use factory coolant.
    Depending on where you live Fluid film the crap out of that frame, undercarriage and everywhere else that rust loves to grow. I just re-did mine and I cleaned it before I reapplied new fluid film, the frame was a shiny black color underneath all that grime. Fluid film works great here in NJ.
  5. Nov 25, 2019 at 9:04 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    do you have pictures of the grime?
    i am not sure what that exactly looks like with time elapsed
  6. Nov 25, 2019 at 9:10 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So I've heard a couple different theories on valve adjustments-
    • Don't do it unless they're making noise (someone)
    • A valve adjustment, what's that? Do we do that? Let me call a mechanic (Dealer service writer)
    It's on my list of things to do once life settles down a hair.
  7. Nov 25, 2019 at 9:32 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Just adding a tidbit though I'm really not in the high mileage club... Fixing issues quickly is key to keeping your vehicle lasting a long time. Oil leaks eat rubber, Water leaks only get worse, headgaskets buring coolant etc. Fix them quick before they turn into larger issues.
    The 3.4L engine is about as easy on engine oil as they get. No timing chain, Low output per displacement, relatively low stressed, oil cooler etc. I wouldn't hesitate to do a 7,500 synthetic oil change interval myself.
    cruiserguy and GQ7227 like this.
  8. Nov 25, 2019 at 10:40 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I think coolant changes with Toyota Red to prevent coolant electrolysis is important for cast iron engines with aluminum heads.
    one4x4dad and cruiserguy like this.
  9. Nov 25, 2019 at 10:42 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Hmm. I’ve got 800ish k on my 06 corolla (estimate, odo is stuck at 299,999, has been since 2010) I’ve done the bare minimum.. 20k oil changes, no fluids... it just doesn’t die.
    Your truck with a proper diet has no reason to not make it to 400k. Unless of course you beat on it. No car like that
    davidstacoma likes this.
  10. Nov 25, 2019 at 10:43 PM
    Empty_Lord
    Dan
    I’ve ran Toyota pink SLLC in all the trucks with no I’ll effect. And it’s easier to get your hands on these days
  11. Nov 26, 2019 at 7:09 AM
    JDouma82
    Justin
    They don’t make noise when they are too tight, they just burn. Then you end up with a very expensive repair.
    CS_AR likes this.
  12. Nov 26, 2019 at 7:16 AM
    0xDEADBEEF
    That was the thing that made me suspicious. " Slappy valves are happy valves" is the phrase I've heard for other shim and buckets setups.
    cruiserguy likes this.
  13. Nov 26, 2019 at 7:30 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Last two 300K + normal maintenance no special anything whatever oil was on sale, Fram filters you all the stuff everyone says you shouldn't use. Zero issues both the old ones, just were too rusty to continue I pity the last guy that bought my 97 2.7 the engine ran like new but every nut and bolt on that engine alt you name it were so rusty it's doubtful they would ever come off and he wanted was the engine. Same story with the 2011 SR5 it's a youngster only 150K+.
    Makes for retarded valve timing.
    0xDEADBEEF[QUOTED] likes this.
  14. Nov 26, 2019 at 1:03 PM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Yup....
    Synthetic oils biggest advantage is it’s ability to extend breakdown period. Since OP is not taking advantage of it, a good quality standard non synthetic oil imo, would work just as well if 3000 is the oil change period. Before synthetics were the norm, there still a lot of high mileage cars
  15. Nov 26, 2019 at 1:24 PM
    #35
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    There is merit to changing your oil at 5K. It give you the chance to look the vehicle over you know things like greasing the U joints checking, tire pressure, looking at the belts, checking for leaks,washer fluid you know dumb things like that. The oil I use is whatever is on sale (no mystery oil just brand name stuff) at half the price as Syn. so it's a wash every other oil change. If Toyota calls for syn use it mine does not. Been driving for 57 years and worked on vehicles for 38 of those year never yet lost an engine unless it already was on it's way out when I got it.
    2002Tacoma4x4 and GQ7227 like this.
  16. Nov 27, 2019 at 6:06 AM
    #36
    GQ7227
    GQ7227 mw survivor
    J A Y
    my late '70s Toyota cars would seriously beg to differ!
    could barely squeak 130k out of those 2 before had to take 'em to the pasture and put them out of their misery :(
  17. Nov 27, 2019 at 6:49 AM
    #37
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes every thing has improved greatly since the 70's, smaller engines more HP better electronics better engine management and better oils not just syn oils, oil in general this is why oil life has been extended to 5k. Oil never wears out it just gets contaminated, water,gasoline,combustion by products. The newer additives in all oils are a big part of that. Just remember an engine has no feelings so using a syn. oil can not make it "feel better" if it does not call for it it doesn't need it.
    cruiserguy and GQ7227[QUOTED] like this.
  18. Nov 27, 2019 at 6:57 AM
    #38
    GQ7227
    GQ7227 mw survivor
    J A Y
    has the oil filter technologies also been improved to handle more than 3k or 5k change intervals?
  19. Nov 27, 2019 at 9:30 AM
    #39
    OneWheelPeel
    Phoenix, AZ
    Wut?
    Dagosa, crazytacoman and cruiserguy like this.
  20. Nov 27, 2019 at 10:19 AM
    #40
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    325k on my 3.4. Oil changes and kept up on maintenance when needed. Nothing major though, valve cover gaskets, timing belt etc.
    Dagosa and GQ7227 like this.
