how to make my truck idle at 1 rpm..
Discussion in '1st Gen. Tacomas (1995-2004)' started by cwitters86, Feb 9, 2010.
  1. Feb 9, 2010 at 4:51 PM
    cwitters86
    cwitters86 [OP] Member
    seattle
    01 prerunner sr5
    so the tacoma i just purchased isnt exactly idling at 1 rpm when at a complete stop or in park, instead its off and i want to know what needs to be done to fix it.
    it idles likes this
    -------2
    -------1 <-------should be there!
    --- <--------------------idles right there? weird
    -------0
  2. Feb 9, 2010 at 4:53 PM
    cwitters86
    seattle
    01 prerunner sr5
    its a 01 prerunner tacoma v6 if that makes any difference =)
  3. Feb 9, 2010 at 4:54 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    the numbers relate to 1000
    I don't believe it is supposed to idle @ 1000
  4. Feb 9, 2010 at 4:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Why so dead set on your truck idling at 1K? When I still had my truck it idled at about 800.
  5. Feb 9, 2010 at 4:56 PM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    You don't want it idling too high bud. As long as it ain't dying you'll be alright. :thumbsup:
  6. Feb 9, 2010 at 4:57 PM
    cwitters86
    seattle
    01 prerunner sr5
    ok, thanks taco
  7. Feb 9, 2010 at 4:59 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    No problem. If I remember correctly, you actually want to idle as low as possible. I'm guessing bc the engine would run cooler, use less gas, and what not.
  8. Feb 9, 2010 at 4:59 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Welcome to TW btw :D
  9. Feb 9, 2010 at 5:03 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Should be a difference in idling when in park and when at a stop. (Presuming you are an Auto). Park should produce higher idling than stopped in Drive by about 200 rpm.
  10. Feb 9, 2010 at 5:24 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (190k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ K&N air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    Welcome to TW! Based on the creative graphic I would say you're looking pretty good. If I recall correctly, my 3.4L has been idling between 500 & 750 (when warm) for it's whole life.
  11. Feb 9, 2010 at 5:32 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    yea you def want it as low as possible with out studdering, stalling or shaking. Where you are at now looks completely normal.
    A higher Idle would be pushing you while you are stopped at a redlight (if you are auto)
  12. Feb 9, 2010 at 5:34 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    I believe 700-800 RPM is the ideal rate.
  13. Feb 9, 2010 at 7:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah, mines a little high, about 5K last I checked- OOOPS !! my gas pedal is stuck WFO !!......
  14. Feb 9, 2010 at 7:50 PM
    JAG
    JAG Well-Known Member
    Tell you what made my idling go down... I used seafoam! That stuff is great for rough and weird idling trucks... I know it sounds crazy but it works... I have an 06 tacoma and just used it like two weeks ago... its great! Get some and following the instructions. Pour some in the gas tank... let some suck through the vacuum or induction line, and add it to your oil when your just about ready for it to be changed! It works wonders.
  15. Feb 9, 2010 at 8:02 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    my 01 has idled at 500 its whole life
  16. Feb 9, 2010 at 8:50 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Same with him, unless the ac is on then its around 800-900
  17. Feb 10, 2010 at 8:05 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner
    i believe the service manual specs 650-800rpm but if it has some miles the idle control may need to be cleaned
  18. Feb 10, 2010 at 3:34 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i idle a 700 rpm about
  19. Feb 10, 2010 at 5:02 PM
    sep
    sep Member
    San Luis Obispo, CA
    2003 Prerunner
    they messed with my idle after i got it smogged. almost stutters at lights, could be something related. 4 banger btw
  20. Feb 10, 2010 at 6:34 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    I idle from 500 rpm to 1800... your fine.....
    Check for vacuum leaks..
