How to manually operate throttle under the hood?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fooman, Dec 15, 2014.
  1. Dec 15, 2014 at 4:43 PM
    fooman
    fooman [OP] Active Member
    14 PreRunner SR
    I'm trying to identify a whistle noise that seems to be coming from under the hood and I want to work the throttle manually. Is there a way to do this from under the hood? I've searched the forums but can't find the answer. Thanks for any help! It's a 2014 with 2.7 engine.
  2. Dec 15, 2014 at 4:47 PM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    To my knowledge, you can't.
    2nd gens has a "drive by wire" system. Pedal is connected to a sensor that goes to the ECU then that goes to the throttle position sensor, thus giving you gas.
    Tried my best to explain it, oh well.
  3. Dec 15, 2014 at 4:50 PM
    LegitGreenTaco
    LegitGreenTaco Photosynthesis.
    2002 Regular cab base A/C fixed now.
    Westin lights, Westin Light bar holder, New front bumper, Custom floor matts, Steering wheel cover, board in bed to keep groceries from rolling around, new radio, New flat bed cover.
    Dont think you can not many cars/truck/vans/things have manual throttle body. I recommend having having a friend press the throttle and you try to locate it under the hood. That is the best I can do to help sorry to not be more help
  4. Dec 15, 2014 at 4:58 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    You can't. It's wires to the throttle body not a cable.
  5. Dec 15, 2014 at 5:47 PM
    Spidious
    Spidious 2006 Tacoma SR5
    Fred
    Champaign, IL
    2006 Tacoma SR5
    Forward & reverse camera monitoring Bed Mat Tyger Black Tonneau Cover Tyger Sport Bar, 36" led light bar Hikity Android Car Radio Pro grill with lights Sport hood Cold air intake Sprint Booster throttle controller Flip down bed extender 265/75R15 tires 2"spacers New led tail lights Internal/external thermometer Chrome Bullbar Chrome step tubes LED F&R led turn lights
    Only way to control the throttle is with a scanner..
  6. Dec 16, 2014 at 6:55 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you attach to the data port in the engine bay with a techstream and run it that way
  7. Dec 16, 2014 at 7:56 AM
    fooman
    14 PreRunner SR
    That's what I was afraid of, and I don't have a Techstream. Looks like I need to recruit a helper! Thanks everyone for your input.
