How to measure leveling for kit
Discussion in 'Suspension' started by TexasRimfireNut, Dec 28, 2022.
  1. Dec 28, 2022 at 3:49 PM
    TexasRimfireNut
    TexasRimfireNut [OP] Member
    Dan
    2021 Tacoma TRD Off-Road
    None so far
    Gentlemen,
    If I want to level my 2021 Tacoma TRD 4x4 so its level, how do I figure out what size leveling kit I need for the front? IS there a certain size or is there a reliable way to measure to make sure I get it level? I really wouldn't care for it being nose high. I was told it should be something like 1&7/8 low in the front but I haven't been able to verify.
    Also, 95% of the time this is a street rod. I do go off road out in the pasture, camping, up in the mountains on dirt roads and etc. but I don't really do anything serious off road. So would the leveling kit be appropriate instead of an actual lift kit?
    Thanks for any help.
  2. Dec 28, 2022 at 4:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Dec 28, 2022 at 4:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    First make sure that all the tires have the same air pressure.
    Next, measure from the center of the wheel (hub) up to the center of the fender well.
    - The drivers side is often .25”-.5” lower. This is normal. -
    Now, look at the measurements you took.
    Subtract the front height from the back height.
    (Rear measurement - Front measurement = Lift amount)
    TexasRimfireNut[OP] likes this.
  4. Dec 28, 2022 at 4:17 PM
    Bishop84
    Bishop84 Well-Known Member
    With 3rd gens all the spacer leveling kits always end up nose high. Even if it starts dead level, the leaf springs sag over time. Most leveling kits are F 3" R 2" or F 2" R 0-1". Not ideal, but they work.
    Ideally you'd measure then install 5100's at he clip height to match the desired ride height. Leaving 1/2" rake. 5100's act a lot better than oem on non-paved roads.
  5. Dec 28, 2022 at 4:24 PM
    TnShooter
    Deogee
    STOCK
    I actually prefer some rake and need it.
    I tow and haul stuff quite often, blinding oncoming traffic with my headlights isn’t nice.
    I think a man can do anything they want with their own truck.
    But I prefer the look of a truck with some rake to it.
    TexasRimfireNut[OP] and atc250r like this.
  6. Dec 28, 2022 at 4:25 PM
    TexasRimfireNut
    Dan
    None so far
    Thanks Gentlemen, much appreciated. Good to know on the leaf spring sag. Will give those measurements a try as well.
    eurowner likes this.
  7. Dec 28, 2022 at 4:27 PM
    Bishop84
    Yup. I like loading my shit and the truck staying better than level.
