How To: Mount 2 Hella 700FF's Behind 2ng Gen grills ONLY $13
Discussion in 'Lighting' started by wrxRome, Jul 15, 2012.
  1. Jul 15, 2012 at 9:12 PM
    wrxRome
    wrxRome [OP] Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    So, i recently aquired 2 hella 700's from a buddy of mine and wanted to mount them behind my grill. It only cost me $13 dollars from Lowes.
    I bought a peice of 1/8x2x2" (3ft long, shortest size they had) and cut to 26" long
    Went to my friends house to borrow his plasma cutter (don't have to use PC, nut its alot faster)
    First i took the grill off and un bolted the 2 A/C condensor mounts here
    then remove the guard by the hood latch with 2 10mm bolts.
    Next measure and cut out the notch that the angle iron will have to be removed
    I used a plasma cutter, but if one isnt available you could use cut-off wheels/ hacksaw (goodluck) or something else.
    after all cutting is done drill the holes for the A/C condensor bolts and the bolts for the hellas (keep in mind of the location of the grill mounts (dont ask :anonymous: ) if you want them on the outer sides of the grill mounts, be cautious of the (im guessing trans cooler) on the driver side. this is the reason why i did mine on the inner of the grill mounts. the lights will touch the hose on the trans cooler fyi.
    then paint with whatever you want. I had left over high temp paint from my satoshi so i used that.
    mounted and painted
    then reinstall your grill and wire lights accordingly to your liking and enjoy!
    Edit: reason why they are mounted higher than in first pic is because they hang to low if you use a bar like the one pictured first. this way raises them up to revel the full light
  2. Jul 15, 2012 at 9:15 PM
    IndigoTac07
    IndigoTac07 Tortoise*
    AJ
    Houston
    '07 Tacoma
    I'm getting one fo free though as prototype #2 right? :p
    Nice right up! Will have to do this if I ever get lights :rolleyes:
  3. Jul 15, 2012 at 9:17 PM
    wrxRome
    Brandon
    lol ill have to think about that
    SIKE! lol
  4. Jul 15, 2012 at 9:17 PM
    IndigoTac07
    AJ
    Houston
    '07 Tacoma
    :pout:
  5. Jul 15, 2012 at 9:18 PM
    wrxRome
    Brandon
    however, they are not wired yet, lol waiting to order my carling switches
  6. Jul 15, 2012 at 9:21 PM
    IndigoTac07
    AJ
    Houston
    '07 Tacoma
    Get it done!!!
  7. Jul 15, 2012 at 9:22 PM
    wrxRome
    Brandon
    probably soon
  8. Jul 15, 2012 at 9:22 PM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    got pics of looking through satoshi to see how high the lights are in comparison?
  9. Jul 15, 2012 at 9:24 PM
    wrxRome
    Brandon
    lol yeah, seems i missed it
  10. Jul 15, 2012 at 10:00 PM
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    ive been looking for a method to mount a bar without hacking away at the truck like most methods use. exactly what i was looking for. thanks! :cheers:
  11. Jul 15, 2012 at 10:02 PM
    wrxRome
    Brandon
    no problem.
  12. Jul 16, 2012 at 1:29 PM
    azntha1one
    azntha1one Well-Known Member
    Sean
    Long Beach
    06 Prerunner
    A few
  13. Jul 24, 2012 at 6:32 PM
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    did you have issues with the hood latch hitting the front of the bar? i'm midway through making it and i'm having to grind down a small section so that it can move freely.
    great idea though, saving me a boat load over buying one premade
  14. Jul 24, 2012 at 6:39 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Those look great.
  15. Jul 24, 2012 at 6:48 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Awesome idea!
  16. Jul 24, 2012 at 9:37 PM
    wrxRome
    Brandon
    i bent mine up by hand a tad, since you cant access it anyway with a satoshi, or you can cut that box a little longer
