How to mount rear remote resi – 1st Gen
Discussion in 'Suspension' started by Digiratus, Mar 11, 2011.
  1. Mar 11, 2011 at 11:24 AM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I can mount them piggyback style, the shocks come with little rubber spacers and clamps to do that. But I would prefer to mount the resi on the frame. I was curious about how others have mounted theirs.
    The shock mounts are in the stock location so I’m thinking if I want to mount these on the frame I’ll have to do it on the inside of the frame rail but not certain about this.
    [FONT=&quot]How have you mounted your remote reservoirs to your frame rail?
    [/FONT]
  2. Mar 12, 2011 at 9:29 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Any of you guys got ideas or suggestions?
  3. Mar 13, 2011 at 11:01 AM
    munkel
    munkel fka unregistered lurker...
    PDX
    2004 Dbl Cab V6 4WD Tacoma
    Icon Suspension, 285/75/16 BFG MT's, Steeeckers, Custom Bed Mounted Tool Storage, Wilderness Trail rack, SoftTopper, K&N CAI, Hella Aux lights, PIAA Fogs, Warn M8000, Elite Front Bumper, BAMF sliders, All-Pro leafs and shackles
    I piggybacked mine, the braided line on my icons was very tight to do the piggyback though.
  4. Mar 13, 2011 at 9:07 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the feedback on your ICONs Munkel. Seems like the ICON kit comes with some sort of mounting braket, is it a piggyback only mount?
  5. Mar 13, 2011 at 9:31 PM
    munkel
    PDX
    the mount for the icons is exactly the same as those Fox's, just the rubber pieces and some hose clamps. I really didn't like bending the line so much to piggyback but I couldn't figure anything else out at the time. Adrian from Icon told me to loop the line over the top of the shock if that makes sense.
  6. Mar 13, 2011 at 10:14 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you loop it like the Fox shock in this pic?
  7. Mar 13, 2011 at 10:30 PM
    munkel
    PDX
    no, that looks better than what I do for flow though, I looped directly over the top of the shock....the icons I had made it real hard to mount to the body compared to the new ones they have now. pic of mine below... before I mounted them, no pics mounted.
  8. Mar 13, 2011 at 10:41 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, it looks like the way the line comes out of the shock is slightly different between the two brands. It also looks as though the connecting line might be a bit longer on the Fox too. Not really sure on that point.
  9. Mar 13, 2011 at 10:42 PM
    munkel
    PDX
    I think it is, mine were a real bitch, I think the fox's will be easier to piggyback or remote mount.
  10. Mar 13, 2011 at 11:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I think some of my misunderstanding about the ICONs stems from this pic. It shows a very interesting frame mounting bracket. Thats why I was surprised when you mounted piggyback. But you didn't get one of those brackets. Upon a closer look, this is a 2nd gen shock.
  11. Mar 14, 2011 at 1:50 PM
    munkel
    PDX
    I might try and score a few of those brackets if they would work with 1st gen shocks, I do not like the line being so tight on mine with the piggyback....
  12. Mar 14, 2011 at 9:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Are you going to hit up ICON for some? They must have them, why else would they be in that pic.
  13. Mar 14, 2011 at 10:10 PM
    munkel
    PDX
    I'm sure they have them just not sure they will fit my resi's. I may try and find out.
  14. Mar 15, 2011 at 3:35 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I am not certain but aren't they 2" in diameter. Pretty sure that part is the same for 1st and 2nd gen versions of their shocks.
  15. Mar 12, 2024 at 1:41 AM
    PaulyFromLA
    PaulyFromLA Member
    Pauly
    1st gen tacomas
    Ones a camper, ones oem, ones a flatbed
    Is it possible to mount the remote reservoir on the frame by the wheel? Ive never seen it on a 1st gen taco. thx for the reply
