How to obtain a desired lift?
Discussion in 'Suspension' started by Veccster, Mar 5, 2009.
  1. Mar 5, 2009 at 9:15 AM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    I have a 2009 DCSB TRDsport and would like a little lift. I do not off-road but don't want to hear my mud flaps dragging any more.
    I have stock TRD Sport tires and rims. I was thinking of a 2-2.5" lift. I am getting the rear 4 leaf pack that is associated with the TSB. After it settles, I figure this will add a 0.5" of lift.
    I will probably get the 5100's for the front. Should I get a block for the back or the 5100's? What sizes do blocks come in? If I aal, it may make the back too firm since I will already have the 4 leaf pack.
    What are other ideas for my situation? I do not plan to off-road at this point.
  2. Mar 5, 2009 at 9:20 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
  3. Mar 5, 2009 at 9:37 AM
    Veccster
    Eric
    2009 DC V6 TRDsport
    Thanks. Mud flaps are staying on as I like the look of them. The lift is just because the taco looks so damn good with a bit of lift.
    I'm afraid of the standard 3" lift since I don't off-road and am keeping my stock tires (for now). I would be happier with 2".
    I have a mechanic in the family that will be installing everything. That should not be a problem.
  4. Mar 5, 2009 at 10:11 AM
    cbcs1987
    cbcs1987 Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
    If you only want 2" There is nothing better to do that get the 5100's and set them at the desired height. I'm not sure what your best option for the rear is because im not to familiar with the tsb
  5. Mar 5, 2009 at 10:31 AM
    Veccster
    Eric
    2009 DC V6 TRDsport
    I am doing the 5100's up front.
    For the rear, I may add a 1" block. I don't wheel and I think 1" is small enough to not be a problem.
    I don't mind spending a bit more for an AAL but don't want too stiff of a ride. Many trucks run blocks and have no issues. 1" is pretty small.
