How to operate a snow plow on a 2024 Toyota Tacoma TRD Sport.
Discussion in 'General Tacoma Talk' started by Leon M, Nov 21, 2024.
  1. Nov 21, 2024 at 10:37 AM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    Just thought I'd share what systems you need to turn off in order to operate a snow plow on the new 2024 Toyota Tacoma TRD Sport.
    So there are two parking sensor that need to be turned off, or your truck won't go anywhere. The brakes will lock up.
    Both are parking sensors. One is a P with a safety cone icon, and the other is the Parking Support Brake that also has a safety cone icon. So to make it easy.... Just turn off the two icons with safety cones. And you will be able to operate your plow as you did on older model.
  2. Nov 21, 2024 at 10:42 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I’m genuinely curious why people would want to plow with such a small truck.
    I used to have some land in Wyoming near a reservation and I had a military surplus Chevy truck (M1008) loaded up with rocks and cement for extra ballast and I still managed to completely trash the frame plowing the gravel road to my house.
    What kind of plowing are people doing with a Tacoma?
  3. Nov 21, 2024 at 10:51 AM
    not a charger
    not a charger Well-Known Member
    NE Ohio
    2023 silver Tacoma SR
    The kind that either can't move much snow, or the kind that will ruin the truck in short order.
    I plowed for years. Residential, commercial, and for the local township road department. Tacoma is a terrible choice for a plow vehicle, even to plow your own driveway.
  4. Nov 21, 2024 at 11:15 AM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    I plow with a SnowWay 22 series 2 plow.
    I started out many years ago with Dodge Ram... Thing sucked gas like crazy.... And had bearings falling out, transmission slipping. Starter died... All well before 1000000 mls. Then I went to a Tacoma.... I'm on my third one this year. I plowed with the last one for eight years and never had the slightest problem... Just kept the oil fresh . In fact it was in such good shape they gave me $17.500.00 on the trade in. I live on a horse ranch where we get lots of snow. I plow a combination of paved and gravel surfaces.The Tacoma has never so much as gotten stuck in the heaviest of snows. And it's much more maneuverable than a larger truck. Quite frankly... I don't know why guys pay for all that extra gas and maintenance on a large truck when they don't have to.
    petethemeat, wiljayhi, vssman and 2 others like this.
  5. Nov 21, 2024 at 11:24 AM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    Obviously you never tried it... because if your were speaking from experience you would know that statement is wrong.
  6. Nov 21, 2024 at 11:45 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    I think it is totally reasonable for those things to happen before 1,000,000 miles. I doubt a Tacoma would do any better.
    Vitamins, Evostaco and SH10151 like this.
  7. Nov 21, 2024 at 12:00 PM
    545 Well-Known Member
    2015 Access Cab
    I’ve plowed with a superduty and wanted more weight and traction
    I’ve seen small trucks and jeeps struggle
    SH10151 likes this.
  8. Nov 21, 2024 at 12:44 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I have never questioned if you can plow with a Tacoma, I was just surprised that someone wouldn’t totally destroy it.
    I’m curious what heavy snow means, and I’ve run into rocks and other things on gravel roads that warped and cracked my frame.
  9. Nov 21, 2024 at 1:35 PM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    Look guys....hate on Tacoma's all you want.
    As a stated before...I plowed with a Tacoma for 8 years and NEVER had any problems....no bent or cracked frames...no transmission problems...no traction problems. Plowed plenty deep snow over 12 inches and never got stuck ...never overheated.... nothing....just kept the oil changed.... That's it. And the truck was in great condition when I traded it in .
    So say what you want....but I actually experienced it...it's not a concept...it's fact. And I will continue to plow with a Tacoma simply because I know it will do the job.
    JJ Diablo, Jim727386 and vssman like this.
  10. Nov 22, 2024 at 6:18 AM
    1994SR54x4
    1994SR54x4 Well-Known Member
    Don't wreck a brand-new truck! Get a snowblower and carry it around if needed. I carried a Honda HS-50 around the Truckee, CA (Lake Tahoe) area in my 1994 SR5 4x4 for several years. I bought the snow blower in 1982, and I still have it. It still starts on the second or third pull of the rope.
  11. Nov 22, 2024 at 7:11 AM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    Ha....I just passed on my old Honda snow blower to my son-in-law. Got a new one with heated hand grips, and I don't have to stop and shift it all the time... I appreciate the creature comforts as I get older.
    Don't worry ... I won't wreck my new truck... The last one held up just fine.
  12. Nov 29, 2024 at 6:18 AM
    phagen28
    phagen28 New Member
    Paul
    Tacoma
    wondering tho what is required to be removed from the front in order to install a Homesteader plow on the 2024 Tacoma.I currently have in on a 2015 and am looking to upgrade the truck and transfer the plow set up. can this be done? thanks
    batacoma likes this.
  13. Nov 29, 2024 at 6:32 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I plowed with my 88 SR-5, my 97 SR-5 V6, and my 01’ TRD OR. Never had any clutch issues, drive line, or otherwise. Beat the piss out of them all and they held up with less problems than my full size trucks had.
    You NEED ballast. Use low range, plenty of pushing power (the little 22RE in the 88 struggled a bit in wet stuff)with a 6.5 or 7” blade. I could plow just about anything I attempted and was far superior for plowing in tight spaces and driveways than the full-size Ram and Chevy we used.
    It’s like any tool in your possession, you have to use it correctly.
    Steves104x4 likes this.
  14. Nov 29, 2024 at 7:12 AM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    They removed the skid plate and part of the skirt on the bottom. I didn't know about homesteader plows. But I had my SnowWay plow transfered from my 2017 to 2024 and that required a different bracket for the frame.
  15. Nov 29, 2024 at 7:39 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    @Leon M not that I will ever have to plow any snow around here, how about some pictures of your old Tacoma and new Tacoma with your plow setup?
  16. Nov 29, 2024 at 8:22 AM
    Leon M
    Leon M [OP] Member
    Leon
    2024 Tacoma TRD
    Sorry I don't have any of the 2017. But my profile pic is the 2024 with plow.
  17. Nov 29, 2024 at 10:12 AM
    Jenney72chevy
    Jenney72chevy New Member
    Would you mind taking a pic of the plow mount they used and how they tied it in. I'm modifying my old one to fit now. I have been waiting for a bolt on one to be offered but it's looking like it won't happen before winter. Thank you.
  18. Nov 29, 2024 at 10:21 AM
    21TRDPro
    21TRDPro Well-Known Member
    2021 Tacoma TRDPro
    I use a shovel. Never had to fill it with gas, change bearings and my frame is in great shape!:boink:
  19. Nov 29, 2024 at 10:30 AM
    21TRDPro
    2021 Tacoma TRDPro
    Had help with a Kubota w/ front mount blower , FEL and rear blade. Makes me look like hero!
    Williston likes this.
  20. Nov 29, 2024 at 10:31 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I'd be concerned with the intercooler on any gas truck. Obviously not an issue on the 15, I can't recall seeing any turbo gas trucks with a front mounted plow, at least not an ecoboost or turbomax. I've seen lots of turbo diesels with front mounted plows I presume that aren't any issues of interference between the plow and turbo system. I belive the intercooler is mounted up high enough that a plow attachment wouldn't block that.
