How to override 3rd gear not shifting when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by UtahTacoma02, Sep 26, 2017.
  1. Sep 26, 2017 at 5:56 PM
    UtahTacoma02
    UtahTacoma02 [OP] Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    My auto transmission (for 3.4 v6) will only shift into 3rd when the engine gets to a certain temp. I have heard this is common because there is a sensor that allows 3rd gear to shift once the transmission is at a safe temp. Is there any way to override this? I don't drive hard at all especially when it is cold. I live and work off a busy road so whenever I pull out on the street I have to stay in 2nd while people ride my rear until it's up to temp. I do let it idle at times to warm up before I start rolling but sometimes I just need to get on the road. Any help would be appreciated.
  2. Sep 26, 2017 at 9:12 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Honestly, since it has the sensors and electronics you're better off leaving it alone and staying in the right lane until a few minutes pass. That's usually how long it takes to get flowing better if you just jump in and drive off.
  3. Sep 26, 2017 at 9:18 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    How about simply letting her warm up a bit more before you drive onto that busy road?
  4. Sep 26, 2017 at 9:19 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    There's good reasons for those sensors, maybe put in a remote start? So you can get it warm while you grab your keys and coffee
    lukester78 likes this.
  5. Sep 26, 2017 at 9:20 PM
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Come on now... we can all understand some times we just don't have time for that
    mechanicjon and UtahTacoma02[OP] like this.
  6. Sep 26, 2017 at 9:27 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    You make allowances. I never had this problem.
  7. Sep 26, 2017 at 10:16 PM
    3rYODA
    Santa Clarita, CA
    2015 white 4x4 TRD
    Well even working in a union where there's all the time in the world I still dont have time for that shit hahaha I used to start my truck and smoke a joint before I left when I drove a pre runner, was annoying as fuck, I get it, some of us work hard and we want our shit to work the way we want
  8. Sep 27, 2017 at 8:18 AM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    Remote start sounds like a good option for ya, hit it when you wake up/get outta the shower/whatever and just leave the doors locked till you get out there. Added bonus of a warm cab when you get in
    3rYODA likes this.
  9. Sep 27, 2017 at 1:07 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    Mine does the same thing I found that if you give it a bit of gas and get the rpms up over 2500 3rd will kick in.
  10. Sep 27, 2017 at 8:36 PM
    UtahTacoma02
    Dave
    SLC
    I agree, best not to mess with the sensors. That would be last resort.
    I still do this when I have time or on those cold cold mornings, but sometimes I'm late for bingo. :burnrubber:
    I may look into this thanks. A warm cab is always nice in the winter.
    Good to know thanks, I will give that a try and see what happens.
    Ridgerunner[QUOTED] likes this.
  11. Sep 27, 2017 at 8:46 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I had one installed around 5 years ago. So nice to start it while I get my shoes and coat on. then walk down from my Apt. and it's at least running for around a minute or two by the time I get in so I can drive off. still will take a minute or two to get the fluid warm enough. although I agree with @magog45 that a little extra rpms will help warm faster and let it shift
  12. Sep 27, 2017 at 9:26 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I’ve had this happen on several occations. If, like others have said, you drive it before it gets warmed up, it will hold off shifting (it doesn’t prevent it from shifting, it just delays it slightly).
    It’s by design, as it is trying to warm the engine up.
    But quite honestly it does it like once, and typically by the next stop light it’s warmed up sufficiently and doesn’t do it again. Not a big deal, really.
    So you have a choice, either deal with it and recognize you are driving it before sufficiently warmed up, or simply give it a minute, and let it idle a bit before driving off. I personally wouldn’t get a remote start *just* for this reason...
    Seriously, 60 seconds is all it really takes. Obviously winter takes longer, but I always let it warm up if nothing else but for the comfort factor of not freezing my ha ds to the wheel.
  13. Sep 27, 2017 at 9:33 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Its mostly for emissions. To get the CAT up to temp sooner to burn off the un combusted fuel of a cold start.
  14. Sep 28, 2017 at 2:32 AM
    gearcruncher
    Canadain bumper technician
  15. Sep 28, 2017 at 7:56 AM
    lukester78
    Luke
    You gave a second reason for remote start in your own post :D
    Seriously though, there's days that I have to scrape 10" of snow off my truck before I get to the ice that built up before the snow started. So a remote start would be great for kicking on the defroster and warming everything up a bit, plus help warm the engine before you drive it. Seems like enough of a reason for me at least, though I have yet to pull the trigger on a system
  16. Sep 28, 2017 at 8:35 AM
    jbrandt
    Justin
    What I meant by that, is that I wouldn't get a remote start *just* to not have the truck delay shifting to 3rd gear when it's cold (engine temp, not weather), as was the OP's issue.
    There are, of course, other reasons to have a remote start that make more sense.
  17. Sep 29, 2017 at 1:24 AM
    UtahTacoma02
    Dave
    SLC
    Yeah, mine is the same. It will delay it slightly and once it is able to shift it won't happen again during warm up.
    That makes sense thanks
    That link is gold thanks!! Yes it will hold in 2nd gear until temps are up enough for it to shift into 3rd. My cooling system works as it should. I haven't changed the thermostat since owning it so not sure on that. It could be the original still and a new one could make a difference.
  18. Sep 29, 2017 at 5:20 PM
    UtahTacoma02
    Dave
    SLC
    I brought the rpm's to about 2800 this morning and it shifted to 3rd when cold. I just never took it that high cold thinking it would continue to increase the rpm's and not shift. That may be what i can do when I'm in a hurry. Thanks again for the tip.
  19. Sep 29, 2017 at 7:04 PM
    gearcruncher
    Transmissions do not normally hold second gear when cold unless you have an issue .
    When you select drive in the morning , this is considered first gear , the transmission then upshifts to second , then 3rd and once the truck is warm enough , it will select 4th .
    If the transmission is hanging in 2nd gear when cold , then you have to look deeper into the issue . Catch the problem before it gets costly .
    Because the transmission is completely computer controlled , I would check the transmission for trouble codes to begin
  20. Sep 30, 2017 at 8:10 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    mine has done this since day one of purchase. so there must be an inherent flaw in the A340. I've usually driven around a minute and then it shifts right into 3rd. if it's warm or hot out no problems, but during the cooler months it holds off getting to 3rd until the fluid is warmer/flowing better
    UtahTacoma02[OP] likes this.
