How to: Paint HVAC controls
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spithead051, Mar 3, 2012.
  1. Mar 3, 2012 at 7:54 PM
    spithead051
    spithead051 [OP] Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    So this idea came into my head after seeing the interior of some 2012 Tacomas and after Razorecko showed off his painted center console http://www.tacomaworld.com/forum/2nd-gen-tacomas/199234-re-did-my-shifter-console.html.
    After seeing (and performing) his mod I decided to work my way up the radio/HVAC stack and paint the rest of them black to match and figured I could make a small contribution to this great community.
    Here's what you'll need:
    - One or two small flat-head screwdrivers
    - One Phillips head screwdriver
    - A can of spray paint in the color you want. I used VHT Wrinkle Black
    1. The first thing you need to do is remove the HVAC control unit from the center console. I didn't take a picture of this but you will need one or two small screwdrivers to pry at the top and bottom to carefully work the module out. It can be tricky so be careful not to damage your dash!
    2. Now that you have the module out you will need to separate knobs from the actual faceplate. There are four Philips screws that need to be removed and six tabs that will need to be undone with a small screwdriver. Here are two pictures of the screws and tabs:
    From the side with a view of the top:
    From the back of the panel with a view of the bottom four tabs:
    And here are the two parts separated:
    3. Now you just need to mask off the sides and bottom to make sure you don't get paint on the backside (or not if you don't care, I'm a bit OCD) and paint the faceplate. Here's mine while it is waiting to dry overnight:
    After that, just wait for the paint to dry, re-attach the faceplate to the knobs and install in the truck.
    Here are the pictures of the finished product:
    Faceplate before it is installed, the light makes it look silver
    Re-installed and back in place:
    Here is a picture of the console now, I am not painting the factory radio because I am getting an aftermarket one soon, I'll just paint the new kit:
    jimmacd25 likes this.
  2. Mar 3, 2012 at 7:58 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    subd.
  3. Mar 3, 2012 at 8:00 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    nice, now change the LED's lol
  4. Mar 3, 2012 at 8:00 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
  5. Mar 3, 2012 at 8:04 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Looks good man
  6. Mar 4, 2012 at 8:18 AM
    spithead051
    Patrick
    Fairfax, VA
    I'd love to change the LED color but they tinted the plastic instead of using orange LEDs. They use clear plastic for every other spot on the truck but not on the HVAC :confused:
    The only prep I did was some dish soap, rinsing and drying of the faceplate before painting. Since it is plastic I didn't see a point to priming like you should do with metal and that was the process I used on the center console and it has been fine for two months.
  7. Mar 4, 2012 at 8:43 AM
    AstroluxAtom
    AstroluxAtom Well-Known Member
    Sunnyvale, California
    '05 v6 4.0L DCSB Offroad Prerunner Debadged
    3" Pro-Comp lift kit, Pro-Comp Tires, Magnaflow exhaust dumped at rear axle.
  8. Mar 4, 2012 at 10:39 AM
    spithead051
    Patrick
    Fairfax, VA
    Pictures of the final product have been added. Feel free to ask any questions
  9. Mar 23, 2012 at 9:59 PM
    tbone11212
    tbone11212 Well-Known Member
    fayetteville NC
    07 Tacoma TRD 4x4
    Black Spyder Headlights Black LED Spyder Tail Lights Spyder Smoke Fog Lights HID Headlights and Fog Lights Black LED IPCW Third Brake Light De-badged plasti-dip power window panels plasti-dip center console modded A/C controls JVC 7inch double Din touch screen HD radio Extreme bull-bar color-matched billet grille Billet lower grille color-matched rear bumper 5% tinted windows LED fog lights added HID bulbs added for fog lights Fog light Mod high beam/ low beam mod LED bedlights LED under hood lights aux fuse box Image Dynamics front and rear speakers Blue accent lighting
  10. Mar 23, 2012 at 10:02 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Are those gummy vitamins? :D
    Looks nice, I like the black between the side gray bolsters. I'm adding this to my eventual To Do list.
  11. Mar 23, 2012 at 10:04 PM
    VanCity4x
    VanCity4x Well-Known Member
    AB
    05 Tacoma
    3link on tons
    Theres another thread on this. Somebody did it, I personaly dont think it turned out that good, light dosen't shine through right. Huge amount of work. Could buy a 2012 for $600 with stock white led's. Still looking for one from a wrecker, lowest I could get was $400.
