How to prep a house for sitting vacant?
Discussion in 'Garage / Workshop' started by Flowin, Oct 27, 2014.
  1. Oct 27, 2014 at 9:41 AM
    Flowin
    Flowin [OP] Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    I'm moving to NC on Friday. House will sit vacant until it sells.
    Some info upfront:
    It's an end unit townhouse; build in 2010 so fairly new appliances. Gasheat, range, dryer and water heater.
    Here’s my plan:
    - Set thermostat to 62 degrees to keep the pipes from freezing (if it has to sit over the winter) and to make sure it’s still an OK temp to show the house
    - Turn off the main water supply, there’s a lever in the utility room.
    - Turn off (gas) water heater
    - Open blinds so light can come in and put air freshener in the rooms so it doesn’t smell since nobody is letting fresh air in
    The rest I think I will leave as is!?
    Is there anything I may have missed? Should or shouldn’t do?
  2. Oct 28, 2014 at 8:50 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Arrange to have the mail/paper picked up so it doesn't look like the house has been vacant.
    If you have a neighbor you can trust, let them know the house is going to be vacant. Hopefully they will call you or the police if people start showing up.
  3. Oct 28, 2014 at 8:54 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    put drier sheets in cabinets and closets dressers whatever,keeps mice out.
  4. Oct 28, 2014 at 9:05 AM
    W Bishop
    W Bishop Stupid should be painful!
    Stone
    South Fulton Tn
    2013 Tacoma 4X4 Reg Cab
    ToyTec coil over kit, Sliver Coils, Bilstein 5100 front & rear, Light Racing SPC UCA. Painted to match Coils, OEM Tacoma 4 leaf pack, Undercover, AFE Pro Dry air filter, Painted grill surround, FJ Cruiser Trail 17" wheels, Rubber bed mat, fog lights and sliders.
    I would add some antifreeze to the p-traps and the toilet just in case the power went off. I would find the main cut off for the water and turn it off there instead in the unit. That way if a problem does happen with a freeze they will no water in the unit at all.
    I figure if he is moving he will have no paper or mail running. ??????
  5. Oct 28, 2014 at 9:07 AM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    Drain the pipes and you should be able to turn heat down even more. Very easy process. Paying for heat when your not in the house sucks!
  6. Oct 28, 2014 at 4:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It doesn't matter how much you prepare.... I would highly recommend having someone visit the home/inside periodically, just in case.
    Talk to your realtor.... they'll know what things you should or shouldn't do while a house sits. They can even help 'watch' it for you. Afterall, they're supposed to help you sell it.
  7. Oct 28, 2014 at 4:27 PM
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    Cover the toilet bowl with cellophane wrap. It keeps the water in the bowl from evaporating and sewer gas coming out.
    If you put antifreeze in the toilet bowl, don't use the yellow stuff!!! There is RV antifreeze that is good for this that is pink.
  8. Oct 28, 2014 at 8:19 PM
    Flowin
    Acworth, Georgia
    Thanks for the replies, I will pay my dog walker to check the remaining mail and house once a week...it's $10 a week..don't think that's too bad (I changed most addresses and did the mail forwarding thing starting tomorrow...)
    Hope it sells by the end if the year...
  9. Oct 28, 2014 at 8:51 PM
    SpoilsofWar
    SpoilsofWar Well-Known Member
    Wilmington NC
    2014 DCLB 4x4 TRD Sport Super Charged
    What part of nc you moving to?
