How to prime 3rd gen windshield spray jet pump?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Searles, Aug 10, 2021.
  1. Dec 25, 2022 at 6:59 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    how come? A little bit wouldn’t hurt, I use only water cause windshield fluid is a grift, I’m sure a splash of some anti freeze in the reservoir wouldn’t hurt
  2. Dec 25, 2022 at 7:00 PM
    eurowner
    eurowner Duke Sky
    Scoty
    How about You do it and report back how well that worked for you.
  3. Dec 25, 2022 at 7:02 PM
    AmateurTaco1313
    ROK
    Enough for now
    done, don’t tempt me with an easy experiment that doesn’t affect the truck whatsoever
    Skydvrr likes this.
  4. Dec 25, 2022 at 7:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I had a guy come in with a prius that put vinegar in the reservoir thinking it would unclog the lines. The vinegar ate both pumps, he was super pissed lol
    soundman98, eurowner and wilcam47 like this.
  5. Dec 25, 2022 at 7:33 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Some parts of the world actually get cold and require windshield washer fluid that doesn’t freeze. That has nothing to do with an ice scraper. Shocker I know.
  6. Dec 25, 2022 at 7:39 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
  7. Dec 25, 2022 at 7:40 PM
    AmateurTaco1313
    ROK
    Enough for now
    take a joke guys it’s not that serious goddamn
  8. Dec 25, 2022 at 7:40 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Use 93 octane most of the time it's cheaper than washer fluid.
    hiPSI, soundman98, Skydvrr and 4 others like this.
  9. Dec 26, 2022 at 6:01 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    That sounds like BS cause I use Vinegar/water mix all Summer with a dab of dish soap and it never affected the pumps or any other component of the windshield. just saying
    Skydvrr likes this.
  10. Dec 26, 2022 at 6:03 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Need a little pilot light on the nozzles to get the full ice melt effect.
  11. Dec 26, 2022 at 7:00 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Guy told me he put vinegar in. I found both pumps dead, replaced them and it was fixed
    Did I miss something? Should I call the guy back right now and get you on the phone with him so you can explain what really happened?
  12. Dec 26, 2022 at 7:05 AM
    Nirango kid
    Gilles
    Ontario
    Sorry but still sounds like BS cause I have been using the Vinegar/water solution for years and honestly never had problems. Maybe pure vinegar would dry up the pumps not sure but I would never use pure vinegar. just saying
  13. Dec 26, 2022 at 7:16 AM
    Nirango kid
    Gilles
    Ontario
    I also want you to know that pure vinegar will dry up diaphragms in the pump and also builds up what they call clay. My mixture vinegar/water/dab of soap it lubricates, cleans the diaphragms. Does this make sense if so mention it to your friend if not then what can I say other than it works for me and cheaper than windshield washer fluid. just saying.
  14. Dec 26, 2022 at 7:20 AM
    Buck Henry
    I guess, but a gallon jug of that stuff is like $3.00 bucks! But I do applaud your frugalness. :)
    Skydvrr and eurowner like this.
  15. Dec 26, 2022 at 7:23 AM
    #35
    Nirango kid
    Gilles
    Ontario
    Vinegar is 2.49 ,water is free :) and make almost 2 jugs of washer.
    AmateurTaco1313 likes this.
  16. Dec 27, 2022 at 9:53 AM
    #36
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    So another question regarding washer pumps, up here in PA it got to single digits below zero and now my washer isn’t spraying and checked today and I can squeeze the lines and fluid came out of the sprayers and the lines were fine but now I am not hearing the pump come on? Is there a way to jump the pump to see if it went bad? And are they still mounted under the cowl?, any wiring diagrams of instructions would be great? Don’t want to go to the dealer for this and can do it myself, just not sure of the wiring? Thanks
    wilcam47 likes this.
  17. Dec 27, 2022 at 10:03 AM
    #37
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Bottom of the washer tank i believe
    kgilly[QUOTED] and Skydvrr like this.
  18. Dec 27, 2022 at 10:03 AM
    #38
    eurowner
    eurowner Duke Sky
    Scoty
    https://parts.camelbacktoyota.com/v...3-5l-v6-gas/body--wiper-and-washer-components
    Pump, #11 is in the tank behind and below the passenger side headlight assembly
    kgilly[QUOTED] likes this.
  19. Dec 27, 2022 at 3:05 PM
    #39
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    kgilly likes this.
  20. Dec 27, 2022 at 7:03 PM
    #40
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Thanks so much guys, it turned out to be a bad fuse that had such a small split I needed a microscope to see it after I tested the plug. Thanks again all good to go.
