How to program a 2nd key?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sliverworm, Feb 14, 2009.
  1. Feb 14, 2009 at 3:30 PM
    sliverworm
    sliverworm [OP] Well-Known Member
    Austin, Texas
    06 PreRunner TRD Offroad
    Can anybody tell me and confirm a method of how to program a 2nd master key?
    I found this
    "Add Duplicate Key-
    Requires one working Toyota/Lexus Master Key.
    1. Make sure all doors and windows are closed.
    2. Insert Master key into the ignition cylinder.
    3. Cycle the ignition cylinder from ON to OFF, five times
    4. Open and close the drivers side door six times.
    5. Remove the Master key and insert the new duplicate keys.
    6. TURN THE IGNITION CYLINDER ON.
    7. The new key will be registered after 60 seconds. The theft
    light on the dashboard will go out, indicating that program-
    ming has been completed."
    On an old post, but tried it a few times and so far no luck, is there another way or can somebody confirm this is the proper way to program the KEY not the FOB, I already got that programmed..
  2. Feb 14, 2009 at 9:06 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 Tundra TRD OR, 05 GX470
    tacoma sold 11/13/13 GX470 has 2” Dobinsons IMS w/JBA UCA, Baja Designs S1 ditch lights, more to come!
    as far as i know you can't do it... the dealership has to.. and they know that, so they charge $80 to program it...
    if i am wrong, which i hope, someone PLEASE correct me...
  3. Feb 14, 2009 at 9:27 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    id like to know also. Cant hurt to know
  4. Feb 15, 2009 at 1:06 PM
    sliverworm
    Austin, Texas
  5. Feb 15, 2009 at 7:41 PM
    Pornstar
    Pornstar Member
    Calgary, The Great North
    06 TRD Sport, white
    Trexx Grillz, Westin Bull Guard, KC Fogs, TIAA Superbrights, Eyelids,
    The dealership has to do it. Same thing i wanted with my honda accord. if the key is chipped it has to go through a dealer.
  6. Feb 15, 2009 at 7:50 PM
    MotoTacoma
    Pencilveineeya
    gotta do what ya gotta do i guess...
  7. Feb 15, 2009 at 8:12 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    It only takes them a couple of minutes. Test it before you leave.
  8. Feb 15, 2009 at 11:01 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    When I got my wife an '02 Rav4, we had to take to the dealer to get a replacement key, and they quoted us $30 for the key and $50 for the programming...bought the key, took it out to the tech, and he programmed it, then said 'never mind the fee, no problem', so he did not mark it down on the sheet.
    Sometimes you just get a good guy working on your vehicle...
  9. Feb 16, 2009 at 10:58 AM
    sliverworm
    Austin, Texas
    yeah, my service guy at the dealership today said it would cost $100 bucks, but he could do it for me for $50.. I have already programmed the FOB and got the key cut, whats the big deal? it takes like less then 2 min to program.. why not free WTF?!
  10. Mar 13, 2009 at 4:20 PM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    i found this
    I If you are programming a black key from a black key, do this:
    1. Insert old black key into ignition. LEAVE THE IGNITION OFF THE ENTIRE TIME.
    2. Pump the gas five times
    3. Pump brake six times.
    4. Remove old black key from ignition.
    5. Put new black key in ignition.
    6. Pump gas one time.
    7. Let the truck sit like that until the security light quits blinking
    If it is a grey key, do exactly the same, but pump gas 4 times and brake 5 times.
  11. Mar 13, 2009 at 8:35 PM
    MotoTacoma
    Pencilveineeya
    hmm, any toyota techs in here that could offer any input??
    or anyone that has tried this?
  12. Mar 13, 2009 at 8:40 PM
    jtaco
    or where to get original bin files to program the ecu with or software to program it
  13. Mar 14, 2009 at 9:59 PM
    jtaco
    if u get a new ecu exact same model, do u have to program your keys that u already have to it or do they work on a seperate computer?
  14. May 12, 2014 at 7:21 PM
    pwint80
    pwint80 Member
    pat
    gulf coast florida
    07 tamcoma pre runner sr5 v6 std
    none yet
    this worked for me 2007 Tacoma pre runner v6 manual
    How to get a key blank
    I bought the key blank from a seller on Amazon and there was no small dot on the key blade at all but it works.Those found on ebay might also work.
    So just buy the cheapest one which says "for 03-09 4runner"
    Should be less than 20 bucks shipped.
    How to cut
    I at first went to walmart but they refused to cut it because I didn't buy the key blank from them. Home depot and lowe's did the same thing.
    So I asked a local locksmith and he did it for just 5 bucks. (just FYI those keys are made of brass, not steel, so most locksmiths would be able to cut them.)
    How to program
    Actually it's a super easy if you still have one master key that can start your 4runner. There was a pdf somewhere about how to do it on a Prado but
    its not very clear(it would ask you to remove the key from ignition 3 times without mentioning putting it back in at all) so I'll try to provide a clearer one here:
    1. Take the new key and one master key that can start your 4runner(old key) into the 4runner with you and close the driver's door.(immobilizer light should be blinking)
    2. Insert old key, remove old key, Insert old key, remove old key,
    Insert old key (immobilizer light should be off from the first insertion)
    3. open and close driver's door six times (immobilizer light should be off)
    Step 2 and 3 need to be done in less than 35 seconds(pdf says 35 seconds)
    4.remove the old key. (immobilizer light should come on(steady on, not blinking))
    5. insert the new key(immobilizer light should be blinking)
    Then just sit there and wait, after about one minute the blinking immobilizer light should go off and you're done.
    Whole process need to be repeated for any additional keys, the just programmed key could be used as the "old key" for the additional keys.
    If there are 5 master keys registered with the immobilizer, it won't accept any more(and I don't know how would it tell you this, so just do a erase if you can't get it to work after trying for a few times). You have to erase them using a similar method(bring in just an old key, insert+remove one more time and open+close one more time, after the 7th close of the driver's door the immobilizer light will stay lighted for one second, remove the old key quickly after that and all but that one you just removed are erased.)
    If you don't have any working master key(meaning you only have valet keys). Then I've no idea what could you do other than ask for help from a dealership.
    Total cost is less than $25 if you still have at least 1 working master key. Less than 1/5 of what my local dealership wants.
    Hope this would be useful for those in need, please post your results if you decided to give this a try.
  15. Jun 14, 2014 at 7:44 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    how about programming a valet key?
  16. Jul 3, 2014 at 6:24 AM
    Databox
    Databox Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    sub'd
  17. Jul 3, 2014 at 6:45 AM
    DueToThe802
    DueToThe802 Well-Known Member
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    The transponder in the key has to be programmed into the ecu.
    While many fobs can be self inserted, most keys can not.
    Off the top of my head, only some newer GM keys can be done by yourself. Only the ones with a cross and circle "circle plus" and only if you already have two that work. I have tricked a few to accept a second one by pretending the first key is the first and second.
    Toyota does not have a reliable way to insert new keys without either the toyota tool, or a locksmith with a tcode or some other system that is not cloning transponder keys.
    Ive worked in a few shops, and have charged anywhere from 45-80 for the use of my machine to program a key you bought.
    Be careful, some sites sell fake keys that have either no transponder or the incorrect one.
    I would call some local auto locksmiths, get some quotes from them.
    should be about 60, depending on where you are.
  18. Jul 3, 2014 at 8:30 AM
    catsman50
    catsman50 Well-Known Member
    Jupiter, FL
    white prerunner 6speed
  19. Jul 3, 2014 at 9:33 AM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    love my base model prerunner.no electronic key.woo hoo.
