how to properly fill the brake system back up accidently drained it
Discussion in '1st Gen. Tacomas (1995-2004)' started by rll131, Dec 19, 2011.
  1. Dec 19, 2011 at 8:39 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    2000 2.4 liter 4 banger
    was changing my brakes and for some reason i thought it would be a good idea to drain all the fluid so now i know i need to refill it. so should i get dot 3 or 4. also what is the proper method to bleed the brake system do the rear brakes need to be bleed or just the front calipers? its a 96 4x4 2.7 liter.
  2. Dec 19, 2011 at 8:44 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    either DOT 3 or 4 is fine
    start bleeding at right rear, left rear, right fron, left front
  3. Dec 19, 2011 at 9:14 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    thanks for the help.
  4. Dec 19, 2011 at 9:17 AM
    Halo913
    Halo913 Well-Known Member
    Adrian
    Tucson AZ
    Tacoma sport 4x4
    Pro-comp full suspension 3 inch lift, Built right UCA's
    Double check the top cap of the brake resovior. I'm pretty sure Toyota only uses Dot 3
  5. Dec 19, 2011 at 9:20 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    dot 3 and 4 are interchangeable, dot 5 is NOT however, but it is purple colored
  6. Dec 19, 2011 at 10:39 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Did the master cylinder resevoir go empty? If so, you may need to "bench bleed" it.
  7. Dec 19, 2011 at 1:01 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Did you pump the brakes with the lines off? Or did you just unbolt the line and let it drip. If its the latter, just bleed as normal. If you drained the master cylinder you might be in for some fun....
