How to properly use e locker
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Aug 19, 2014.
  1. Aug 19, 2014 at 1:57 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I just did a tacoma elocker swap with 12voltguy.com harness and I am wondering what the safest procedure for locking and unlocking the rear diff is. Can it be unlocked while driving? Can you use it on high way? Can it be locked while driving?
  2. Aug 19, 2014 at 1:59 PM
    Aw9d
    Aw9d That one guy
    I always stop when I lock/un-lock the rear of my truck.
    yes you can drive with it locked, but turning will be a nightmare and you'll hop a lot. I wouldn't stay locked while driving on the highway.
    I was told you can unlock while moving, but you need to be going slow. I haven't tried it and won't.
  3. Aug 19, 2014 at 2:01 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    stop vehicle
    put truck into N, then 4lo
    engage locker
    drive a bit, you'll hear a "click" from the rear diff
    wont usually engage right away, gotta drive forward or reverse a little
    proceed to climb over rocks
    by the power of lockerskull
    keep climbing until you reach the moon
    you glorious locked astronaut
    you shouldn't need it on the road
    when you disengage it, when you start to drive you'll hear another "click" and the diff lock light should go off
  4. Aug 19, 2014 at 2:04 PM
    Indy
    Indy Master of all I survey.
    Driving locked won't be a nightmare, but it will be different. On road there's no reason (usually) to be locked, if you are you'll end up scrubbing the outside tire for every turn. If you do it a lot you'll eat a lot of otherwise useable miles off the rubber. On dirt it will just slide. On ice, it will be really interesting for all but a straight line.
    For the most part, lock when you need it, stay unlocked the rest of the time.
    For most selectable lockers you can engage and disengage at will, but you want to be going in a straight line and at a low speed so the axles are turning the same speed. If you're turning, stress and shock loading will do some damage.
  5. Aug 19, 2014 at 2:34 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    So, I've only used the locker when I'm out mudding or in sand. I've been curious about using it while mudding. Most of my mudding is only in a flat dried up pond that turns to slick mud and I just go spinning around. Not really a lot of stress on it, except a few bumps or whatever from deep tire tracks. Should I be more cautious with it? It says only use it to get unstuck.. But I don't see how it could harm it if I'm just spinning around.. unless it takes a jolt. How much force would it take to break something?
  6. Aug 19, 2014 at 2:43 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Use it before you think you'll need it. No use of it when you actually get stuck and the locker isn't engaged yet. Hence why sometimes you got to drive back and forth a bit.
  7. Aug 19, 2014 at 8:24 PM
    Indy
    Quite a bit. But a spinning wheel that stops RIGHT NOW carries quite a bit of energy. An open carrier actually safeguards a lot of moving parts. Thats one of the reasons you see a "just installed my locker" thread, followed a week later with a "how do i change a broken axle" thread :laugh:
  8. Aug 19, 2014 at 8:30 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    accelerate to 60, hit the lock button, post results
  9. Aug 19, 2014 at 8:43 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I'm betting nothing. Even with the gray wire mod, mine won't lock in until I'm under 5mph or stopped.
