How to protect wheels durring winter storage?
Discussion in 'Detailing' started by 02sr5trd, Oct 23, 2012.
  1. Oct 23, 2012 at 4:25 PM
    02sr5trd
    02sr5trd [OP] Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD OFF ROAD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    Well the time has come again for the snow to fly here in Ohio. With the snow comes alot of salt and other chemicals to clear the roads. I have chosen to remove my custom wheels and put my stocks back on. With that being said, My question is:
    What is the best way to store and protect my aluminum rims?
    -Obviously i have washed them to remove all the road grime.
    - the tires are still mounted. do I leave the air in the tires?
    - What should i put on the rims themself for protection?
    i have been told silicone spray, wd40 or wax but leave it on.
    - What about the lug nuts, i have heard of coating in oil?
    Thank you for any input and feel free to add any othe info that others may use upon finding this thread in a search.
  2. Oct 23, 2012 at 4:33 PM
    98tacoma27
    Ben
    Not Beech Creek
    If you can, stack them on concrete. If you can store them out of the weather, they really don't need to be coated with anything. Same for the lugs (just bring them onside).
    If you have to coat them use something like this and not WD40
  3. Oct 23, 2012 at 4:58 PM
    02sr5trd
    Donnie
    Ohio
    Ben,
    Thanks, yes i do plan to stack them, and they will be in my shed. Not on concrete but a wood floor.
    What about the air? To keep the tires from dry rotting would it help to let out the air?
  4. Oct 23, 2012 at 5:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    The woods fine. They won't dry rot but if it will ease your mind, hit the tires with a good quality dressing.
  5. Oct 24, 2012 at 3:06 AM
    02sr5trd
    Donnie
    Ohio
    Thanks again Ben. I appreciate your input.
  6. Oct 24, 2012 at 2:37 PM
    02sr5trd
    Donnie
    Ohio
    Bump- for any other tips, tricks or advice. Also any advice on steel rim storage if its any different than aluminum. ( just for other members browsing for awnsers)
  7. Oct 25, 2012 at 7:30 PM
    Madjik_Man
    Colorado Front Range
    I had a nice set of spring/summer and winter wheels for my Legacy. I'd honestly just clean them real well, but a tire dressing on and stack them in my garage. Nary a problem or blemish for several years that way.
  8. Oct 25, 2012 at 8:49 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Keep about 20 lbs of pressure in them to prevent the sidewalls from taking on a goofy shape.
  9. Oct 27, 2012 at 6:27 AM
    02sr5trd
    Donnie
    Ohio
    Cool. Thanks guys.
  10. Oct 27, 2012 at 6:49 AM
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    No! Don't stack them! Moisture will build up in between the tires, potentially rotting the rubber, and rusting or corroding the rims. Been there, done that. Since then, I've ALWAYS stored my off-season wheels with maximum air pressure and standing up on their ends in the back shed. Never had a problem since and I've been doing this for years with three vehicles...
  11. Oct 27, 2012 at 7:18 AM
    02sr5trd
    Donnie
    Ohio
    Thanks Brian. Has any one else ever had this problem?
  12. Oct 27, 2012 at 7:28 AM
    Madjik_Man
    I live in Colorado where it is very arid, unlike Vermont
    Plus each tire/wheel is wrapped in its own plastic bag (forgot to mention that)
  13. Oct 27, 2012 at 7:35 AM
    02sr5trd
    Donnie
    Ohio
    I didn't think about bags. I could just go to my local tire shop and ask for a few tire bags. What type of bags do you use?
  14. Oct 27, 2012 at 8:50 AM
    Madjik_Man
    The ones discount tire provides. They're just large plastic bags.
  15. Oct 27, 2012 at 8:52 AM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Hell I've stacked mine on the concrete and no dry rot or anything. Stack em up and leave em alone
  16. Oct 27, 2012 at 10:41 AM
    Backinblack03
    Brian
    VT
    ABS sucks.
    Eh, the bags tend to trap moisture and not let it out. Let 'em stay in the open air...
  17. Oct 27, 2012 at 10:56 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    Ya that's a good point. The bags would hold moisture. I wouldn't worry about them. Keep them dry like previously stated and you should b ok. I've stacked both my rims on top of each other and I haven't had any problems. But if your worried stack them next to each other standing up
