How to pump fuel from tank?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3rdTruck, Feb 6, 2015.
  1. Feb 6, 2015 at 3:22 PM
    3rdTruck
    3rdTruck [OP] New Member
    2010 PreRunner
    I was thinking of using fuel from my truck for emergency use in my portable generator. What would I have to do electrically to use the truck's fuel pump to move fuel to a 5-gallon gas can? I see where I can disconnect the fuel line in the engine compartment.
  2. Feb 6, 2015 at 3:31 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Worked for me for a 1990 Chevy Caprice wagon, on a Tacoma :notsure:
  3. Feb 6, 2015 at 4:48 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    If I was really wanting to do this, I'd get a hand pump (or electric) from a hardware store suitable for pumping fuel. I'd leave the truck fuel pump alone.
    Using a generator probably means you are going to be out in the country somewhere... wouldnt want my fuel pump to die while I was out there.
  4. Feb 6, 2015 at 6:42 PM
    Tuck91
    Tuck91 Well-Known Member
    2014 Toyota Tacoma Regular Cab 4x4
    Get a transfer tank & pump toolbox combo.
    06Tacooo and Skyway like this.
  5. Feb 6, 2015 at 10:18 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Guess. No info? :confused: Helpful post that a 3rd grader could post.
  6. Feb 6, 2015 at 10:23 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Your contribution to the thread was so much greater
    06Tacooo, Fitz235 and tcjacado like this.
  7. Feb 7, 2015 at 12:29 AM
    3rdTruck
    2010 PreRunner
    I looked at the bed mounted tanks from Aluminum Tank Industries. That's a possibility. It would take care of the problem of having a low tank when the fuel is needed for the generator.
  8. Feb 7, 2015 at 5:20 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There's another member that posted on here about a year ago needing to empty the tank. He was stationed on the Azores and the gas station put diesel in the tank. In the end, I belive, he disconnected the fuel line under the hood and jumped the fuel pump relay. That allowed the pump to empty the tank. In an emergency situation, that would get gas for the generator. I'd only get about 2 days constant running, tops, with a full tank in the truck on my generator...
  9. Feb 7, 2015 at 7:38 AM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    I would mount one of these in the bed somewhere...
    http://rotopax.com
    Take up very little room and not relying on the gas in your truck.
  10. Feb 7, 2015 at 8:11 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    THAT is what a 3rd grader would post.
  11. Feb 7, 2015 at 12:31 PM
    3rdTruck
    2010 PreRunner
    I just confirmed what scottalot posted. It is possible to get a 1/4" diameter, semi-rigid, piece of tubing into the gas tank. You do need to rotate it to get it past the anti-siphon device.
    06Tacooo likes this.
  12. Feb 7, 2015 at 5:39 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    It's not as simple as just jumping the fuel pump relay, the circuit opening relay also needs to be energized which only happens when the engine is running so you'd have to jumper that also. There is also the premise of whether you'd want the fuel pump to run at low or high speed.
  13. Feb 8, 2015 at 1:44 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  14. Mar 24, 2020 at 5:10 PM
    kgw51gmc
    kgw51gmc Active Member
    2001 Tacoma 2wd, 2.4, 5 speed, 240K miles.
    Mod's include-- ONE upper left ball joint replacement, many mufflers, lots of tires and oil changes. ALL ORIGINAL. Owned for 13 years now.........
    Take filler tube off tank, use long screw driver to knock/destroy the anti siphon thing in the tube, it won't get thru the filter sock, and then use a shaker hose or a reg hose and siphon it out.
    .Just did it tonight to get diesel out off tank (oops, covid19 makes us use improperly cans for fuel). On my 2002 2.4, 2wd five speed taco, sit on ground beside truck and reach in with 10 socket to undo hose clamps, and strong grip required to twist it loose off off tank. I took the...splash/spill guard thing off by filler cap so I could see.
    Skyway likes this.
  15. Mar 25, 2020 at 9:23 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    5 plus year old thread.
    SR-71A and Thuguon2.7 like this.
  16. Mar 25, 2020 at 12:40 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Appears it still helps some folks, Good wishes kgw51gmc
    Thuguon2.7 likes this.
  17. Mar 26, 2020 at 5:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    People always complain with, "Did you try the search function?"
    Member does and responds in kind.
    People complain, " Way to resurrect an ancient thread.".....
    Catch 22 much? o_O lol.
    Skyway and yeos like this.
