How To: Rear Axle Bearing/Seal Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 6 gearT444E, Aug 28, 2021.
  1. Jan 13, 2022 at 12:53 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I did, did the breather mod everyone did here. Had -30 weather for a week or more, somehow something froze up. Had the breather in the drivers side cubby in the bed.
    Grossomotto[QUOTED] likes this.
  2. Jan 15, 2022 at 2:14 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Sure, the ABS system would still work. But they made two mirror image parts for a reason- to keep the sensor and wire on the opposite side of the axle as the shock absorber.
  3. Mar 11, 2022 at 5:38 AM
    rktman
    rktman Active Member
    MO
    2006 Tacoma 4x4 TRD Sport
    This a good write up, thanks.
    I was working on my 06 rear wheel bearing and pulled the old bearing off to discover the axle had some grooving and needed replacement.
    While looking for an axle, I noticed Dorman has a pre-pressed bearing and axle assembly that includes everything plus the wheel seal and o-ring.
    For $380 on ebay, I gave it a shot. Install went easy, bearing feels smooth. (I have the Timken/Koyo standing by just in case though)
    Side note, I was surprised in the price difference in Ebay, Oreillys, & Autozone for the same Dorman part number.
    Ebay was 380, Oreillys was 500, and Autozone was 720 for the Dorman 926-139.
    The Ebay seller was "parts_link", quick shipping at 3-4 days.
    Hope this helps someone.
    tomrad, vanhalo, burrito782 and 4 others like this.
  4. Jun 9, 2022 at 5:54 PM
    pistonsandpixiedust
    pistonsandpixiedust Well-Known Member
    Faye
    SA, TX
    Posting on behalf of my husband's '09 Prerunner
    RSI SmartCap, Ironman4X4 heavy duty suspension, awning and rooftop tent, solar panels, full custom kitchen set up, Black Rhino Armory wheels wrapped in Hercules Ventures. Full build coming soon to All Girls Garage, season 11, episode 9, airing 8/27/2022!!!!
    Wow!!! This is so awesome, I'm so stoked my videos were helpful, that means so much to me! Thanks for sharing here!!
  5. Jun 10, 2022 at 5:52 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    I didn't even know you're on this forum - I watch your vids all the time! Great info & tips!
  6. Jun 10, 2022 at 6:23 AM
    pistonsandpixiedust
    Faye
    SA, TX
    I lurk around on quite a few Toyota forums because I find that often the enthusiast owners will pick up on issues and trends before the dealership will so it gives me a good heads up on the knowledge!!
    Jimmyrace, stonybrook and Alealexi like this.
  7. Jun 10, 2022 at 1:14 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Oh your videos helped me out on many more things before I found out about the Toyota forums. They are very informative and helped me to keep an eye out on other issues that I would not have known to look out for. Thank you for your videos!
  8. Jun 11, 2022 at 10:35 AM
    pistonsandpixiedust
    Faye
    SA, TX
    Wow, thank you so much!!! :))
    GilbertOz and Alealexi[QUOTED] like this.
  9. Feb 28, 2023 at 5:34 AM
    Spif
    Spif vehicle: 2014 Taco 4x4 double cab
    2014 Taco 4x4 double cab - 125k miles
    This concerns me. In videos I see people just sliding the axel all the way down the shaft without much apparent care.
    How do you re-install while being careful not to dislodge this baffle inside the differential?
    How do you know when the axel has seated correctly into the differential?
  10. Oct 22, 2024 at 12:09 PM
    tomrad
    tomrad Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    Very nice write-up. Just wondered if he used the 12 ton or 20 ton Harbor Freight press?
  11. Oct 22, 2024 at 8:56 PM
    6 gearT444E
    6 gearT444E [OP] Certified Electron Pusher
    Deep South
    Herculiner Hootus
    20 ton. With the sounds made and force required I’m not sure a 12 ton would break the old bearing free.
    Jimmyrace likes this.
  12. Oct 22, 2024 at 8:58 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Sorry just saw this. When reinstalling make sure to reinstall the axle shaft slowly and try and keep the axle centered in the tube as best you can. If you feel any resistance back out and try and recenter. It’s more or a feel thing than a specific procedure.
  13. Oct 23, 2024 at 3:10 PM
    tomrad
    Thanks for all your info., it really helps.
    My right rear bearing has become noisy, but still can't feel any play in it. I'll be replacing it before too long. It sounds like the noise is in the front sometimes, as if it's in the front diff. I topped off the differential last year when I did the ECGS bushing so I know it's full.
    I replaced the left front bearing a few months ago (about 5k miles ago). It was easy to tell it was bad, lots of movement when wiggled by hand. Right front, can't feel any play in it.
  14. Oct 27, 2024 at 7:49 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    You can also use a larger nut to pull the new stud through the hole in the bearing.
  15. Oct 28, 2024 at 1:31 PM
    #35
    tomrad
    Turns out it's my right front that's making most of the noise. Replaced the left in May (about 4k miles ago or so). Good thing I bought two. I expected the right one might fail before too long. I don't know if a previous owner replaced one or both. I have put about 33k miles on it myself.
