How To: Rebuild the Tacoma Starter Motor
Discussion in 'Technical Chat' started by ItalynStylion, Jan 27, 2012.
  1. Jan 27, 2012 at 9:40 AM
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    If you've recently driven through some deep water and your starter is acting oddly this tutorial is for you. If you're looking to remove/rebuild your starter for any other reason this will also help you out.
    I need to explain something before we get into it. The starter works in two stages. The starter first pushes it's gear onto the engine flywheel assembly and once it's engaged and the gear teeth mesh up, THEN the motor starts to turn. My very wet starter would engage upon holding the key in the start position but the motor wouldn't CRANK for about three seconds. Once it started cranking it wasn't labored or slow. This clued me in that the contacts on the stage two (the motor cranking) were bad. Here's how to fix it.
    Step 1
    Disconnect battery. There are two live posts on the starter and they absolutely will electrocute your stupid ass. Get the truck in the air and put it on jackstands. You'll need the front left wheel in the air so you can take it off. I would recommend setting the wheels totally straight (makes sense later). Take off the front left wheel and the little rubbery splash guard that sits behind the brake assebly by taking out the pop rivets. It's the one right above the barcode in the picture. Also, make sure you work via a super ghetto budget lighting setup. Most importantly, be sure to drink plenty of beer.
    Step 2
    So assuming you didn't kill yourself in step 1 we can get started. I don't have a picture for this step but women say I have a way with words. To prove it I will explain exactly what you see without the aid of a picture.
    Looking in where you removed the splash guard you'll see a brake line mounted to the frame rail (the top part is all coiled up). You'll also see the steering rack coming down and if you look past that, your defunct starter. Follow the steps in to get the starter out. I would recommend removing the bolt on the frame rail that holds the brake line in place. Don't move it too far or you'll likely kink the line but you can get a little play in it which you'll need later.
    IMPORTANT: Don't remove the lower exhaust manifold. This is strictly for pussies who failed geometry and can't get the starter out of the already sufficient window. Once you've removed the starter and everything attaching it you'll have to do a few flip turns with it to get it out. I repeat, don't waste your time removing the header, it will come out...get creative.
    Look at that....you're such a boss!
    Open .
    Step 3
    Now on to the cleaning. Now that you're 3 beers in and likely have your hands all cut up it's time to play with some alcohol and contact cleaner! Open up the actual motor assembly which is the part that is held together by two very very long bolts. Undo those and the two phillips head screws on the back. It should come entirely apart. While you're in here I'd recommend cleaning the inside of the STARTER YOKE ASSEMBLY and also the contact points on the STARTER ARMATURE ASSEMBLY. After they look clean blast it out with compressed air to get rid of any moisture or debris. Move up to the starter brush assembly. There are 4 "brushes" that contact the armature assembly. Make sure they're clean and dry and follow it up with some compressed air too. When you've finished this put all of this back together.
    Step 4
    I'll admit that what I told you do to above is likely not needed but you should do it anyway since the damn thing is removed. This section is likely where your problem lies. Hold onto your asses, here we go. (pictures included this time)
    Remember when I said the starter was a two stage process? Well the motor cranking is stage 2. Not only that, but the motor is wired in SERIES (daisy chain) meaning that if stage 1 doesn't happen (or is flawed) stage two CAN'T happen! Look at the picture below. What we're looking at is the electromagnet assembly that engages the shaft into the fly wheel. The bolt on the right side of the starter (above the black plastic harness) is the INPUT for the live power wire. The bolt near my finger on the left side is where the motor assembly gets power. Remove the three 8mm hex head screws holding on the end cap and remove it.
    Step 5
    Open up the electromagnet assembly and take out the center pin that's likely to be fairly ugly. There is a spring surrounding the center shaft, don't lose it. Once you have removed the center pin you'll be seeing what is in the second picture.
    (step 5 continued)
    Time for an explanation. In the second picture above you see two contacts. The one on the right is connected to the bolt on the right that we discussed was electrified from the truck. The contact on the left goes to the bolt on the left which will feed your motor. As you can see, the contact on the right is dirty and corroded as hell. The left one is what it will look like once you resurface it by sanding it down with fine sand paper. I tested continuity between the two contacts using a multimeter and there wasn't any. Then I looked at that center pin that was pulled out. The "washer" under the bushing is made of copper. Now, copper is used for two things and two things only, decoration or electrical connections. So that "washer" under the bushing is really what makes the connection between the two contacts that you're resurfacing. Sand it down as well so it's nice and shiny. What happens is that the actuator pulls that pin DOWN as the gear shaft engages. When this happens successfully, that copper washer slams down on the two contact points and connects the starter motor with the live power wire. Brilliant eh? So basically what's kept your starter from cranking this whole time is the corrosion on the contact points!
    Once everything is all shiny blast it out with some compressed air and put it all back together (don't forget the center pin spring). Clean the connections on the black harnesses (on the starter and the truck too). Reinstall your new starter...Oh wait, I mean, the starter that you rebuilt as though you were a direct descendant of Mr. Tesla himself; and crank that bitch up.
  2. Jan 28, 2012 at 5:43 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Awesome write up. +1 for stickyicky
  3. Jan 28, 2012 at 5:51 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    LOL, I don't need to do this, but +1 for making me laugh! Great write up!
  4. Jan 28, 2012 at 6:22 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Great job. Now I know my 1st gen has the same starter as my old 91---EASY fixer!
    And cheap to fix.
  5. Jan 28, 2012 at 11:02 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    You missed step 0.5 - Dont drive into a ditch full of water.
    Wyoming09 likes this.
  6. Jan 28, 2012 at 11:03 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    LOL nice working lamp hahaha good write up :thumbsup:
    TXpro4X4 likes this.
  7. Jan 28, 2012 at 11:07 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    awesome write up
  8. Jan 28, 2012 at 1:00 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Where's your sense of adventure!!!
  9. Nov 15, 2013 at 3:13 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    OP, any chance of getting those PDF's working again?
  10. Mar 26, 2014 at 8:22 AM
    bbk3e
    bbk3e Member
    Raleigh
    99 Tacoma
    mostly stock
    Nice. I'm going to attempt this soon - bought some replacement parts already.
  11. Jan 27, 2015 at 7:11 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    Can someone post the pdf's please? Links are broken.
  12. Jan 27, 2015 at 7:38 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    TheDevilYouLove likes this.
  13. Jan 28, 2015 at 6:48 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    Finished doing this last night, My truck is so rusty that it was a PIA. Couldnt remove the sttering shaft out of the way, and having the drive shaft removed would have helped big time. Took me two hours from start to finish. I jacked up the front end and roomed the tire for more room. Cranks over faster and stronger now. Time will tell if I get the intermittent no start again, but so far so good.
    Thanks for the write up.
  14. Nov 24, 2015 at 1:17 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Steven, I see I've found some more of you awesome handiwork. Awesome writeup. So valuable. Thanks!
  15. Nov 24, 2015 at 10:26 AM
    ItalynStylion
    Steven
    DFW, Tx.
    You're welcome! Sorry I didn't see the requests a long time ago. I didn't have a subscription to this thread. Now that the new forum software is in place I was notified of the new posts. Thanks for posting a new link to the PDF!
    Crom likes this.
  16. Jun 12, 2016 at 9:24 PM
    ItalynStylion
    Steven
    DFW, Tx.
    It's actually pretty easy. First time (and only time) I did it I had no experience with it and just figured it out as I went.
    Crom likes this.
  17. Sep 28, 2016 at 7:12 PM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    Just used this to replace the contacts on my V6 4wd. Had to sort of figure out how the steering shaft's sliding yolk came out of the way since I couldn't load the PDF's (took a generous amount of PB Blaster, and some cleverness with a bronze mallet.) Got the truck used a year ago and started hearing the one loud click upon start up attempts even though only 45,000 on the ODO. Guy before me must have started it a lot and drove it close to home to have low miles in 7 years. battery was fine, so i got the parts and had at it with the the help a few threads here. In retrospect I looked at the PDF's...I don't see why taking the exhaust or skid plate off would help at all, so I'm glad I didn't worry about that. Even with the PDF's a little more detail concerning the steering shaft would have been nice though. We got it anyways. I ordered from Nations to ensure I got the right ones, but I think there were some cheaper options online that would have worked just fine once I saw which ones I got. who knows.
    ItalynStylion[OP] likes this.
  18. Sep 28, 2016 at 7:50 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Just a note. Those cables will NOT electrocute you. The only thing they might do is burn you if you short them out and get them hot. 12v DC won't be an issue from personal electrocution point of view. It is always best to disconnect negative battery cable as once that is done, nothing can be shorted, no spits and sparks, no flames, and no problems.
    The only injury I have ever seen with a starter was my dad when I was about 5 years old (I am now 68 for reference). He managed to get his wedding band between the positive starter post (prior to the relay) and the frame. The ring GLOWED red. He had a life-time scar and never wore a wedding band again. I ran across it when I was a little older and it was obvious it had been in an electrical arc with the visible pitting and it was a little distorted. I learned a few new words that afternoon. :)
  19. Nov 4, 2016 at 6:15 AM
    ItalynStylion
    Steven
    DFW, Tx.
    I think someone posted that the pictures were gone just a moment ago (and then the post got deleted? I'm sure I saw it). In any event, the pictures haven't gone anywhere, the host (Photobucket) is down today for Lord knows what reason. Photobucket is really in the shitter these days. I'll see if I can move the pictures eventually to another host that sucks a bit less.
  20. Nov 4, 2016 at 6:22 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Cool, that was my post and I did delete it because I found access to the pdf. They indicate you have to remove the intermediate steering shaft......yikes! And part of your exhaust which is also no easy task unless you've got a torch. In any case my starter is fine but I like to be prepared just in case if you know what I mean. I'd like to see your pictures as the old saying goes a picture is worth a thousand words. Thanks.
