How to recalibrate or disable the PCS?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cuajopelu, Jun 11, 2022.
  1. Jun 11, 2022 at 7:57 PM
    cuajopelu
    cuajopelu [OP] New Member
    Hi,
    How can I recalibrate or disable the PCS? I have the Techstream software.
  2. Jun 11, 2022 at 8:01 PM
    Bishop84
    Bishop84 Well-Known Member
    You need a radar cone with measurements for the cruise control radar.
    You need a target and measurements for the camera/lane departure.
    If you want to disable it, there is a firmware update that disables it, but is irreversible. Intended for lifted trucks and modified trucks.
    Kev250R and cuajopelu[OP] like this.
  3. Jun 11, 2022 at 8:30 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Just to emphasize on this, the PCS light will stay illuminated all the time if the firmware is loaded. It's not like you won't know it has been disabled. And I believe it is fixable by replacing the radar, but I could be wrong on that.
    But, what is your reasoning Op? It sounds like you lifted the truck or replaced your grille and now you get the light and error(s).
    cuajopelu[OP] likes this.
  4. Jun 12, 2022 at 3:36 AM
    cuajopelu
    Thanks guys!
    The reason I want to recalibrate or disable the PCS is because I change the Tacoma 2020 Sport grille to a custom grille and I positioned the radar in the buttom of the grille.
    The radar get on and off every 5 or 10 minutes. My first option is to recalibrate it in the lower position but if is not possible then I don't have any issue with disable it.
    Where I can find the cone and the measurements? I already have Techstream.
    Thanks again in advance!
  5. Jun 12, 2022 at 3:52 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    How long has the aftermarket grille been on? That's usually common for a while when aftermarket grilles are first installed. If you disable your PCS you'll have a permanent PCS light on your dash.
  6. Jun 12, 2022 at 4:19 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Oh, man. There are a TON of threads on here about what to do when switching out the OEM grill to a TRD Pro grill, regarding the TSS Sensor and what to do about it after the swap. If you are not going to lift the truck, then the solution is simple. When you reattach the sensor to the back of the grill, at the screw at the top of the sensor, place a thin washer between the sensor and the grill. This will alter the sensor angle in such a way as to make the TSS system think it is where it was initially. Also, if your truck is new or fairly new, then it hasn't broken in the sensor yet, as it is a learned system. I did all of this on my 2019 as I swapped out the grill a week after I got it. At first, I had the same PCS OFF light coming on all the time too. Then, after a while it seemed to have "learned" the new angle and it was working fine. That is, until around the 4000 mile mark, I drove my truck across the country from the west coast to the east coast. All of a sudden as I started the trip, the PCS OFF light would come on! When I stopped for gas or bathroom, it would go off when I started back again, but within 5 minutes of being back on the road, it would illuminate again. This happened the WHOLE DANG WAY across the country! Frustrated the hell outta me because what the heck good is the dang thing, if it is not going to be operational? BUT, once I got out onto the Outer Banks of NC, the next morning, when I got back into the truck to start my day, from then on, it has worked perfectly. That was at about 7000 miles or so. Now I have almost 48,000 miles on it and it has continued to work perfectly. Two things though, the TSS system works with two things in conjunction; the sensor and the CAMERA on the top of the windshield. If either one of them are blocked due to bugs, excessive dirt because of rain, mud snow, etc, the PCS OFF light will come on. Turn off the truck, clean either one or both of these, and when you start again, PCS OFF light will be off. A demonstration of this was done by @ROBMOTIVE on Youtube, where he would cover up each of these separately, with some duct tape, and you could see the PCS OFF light come on. Great video and was a good demonstration of how the TSS system works. Hope this helps....
    RealHappyPappy and RoxysToy like this.
