How to remove 2010 Tao grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waheed, Nov 3, 2012.
  1. Nov 3, 2012 at 10:09 AM
    waheed
    waheed [OP] Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    The top nuts and tab and nuts are easy, it's the bottom that I can't get to:frusty:
  2. Nov 3, 2012 at 10:13 AM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    IIRC, all you do is pop up those two plastic tabs, then undo the (10mm, I believe) nuts or whatever with a ratchet...then pull the grill STRAIGHT UP and it should come right out!
  3. Nov 3, 2012 at 10:52 AM
    waheed
    Waheed
    Vancouver
    Not that easy my friend, I'm in Canad, I don't know if it's the Canadian model but there are two plastic tabs on on each side of grill on BOTTOM next to the DTRL, they just don't slide UP like the other bud says
  4. Nov 3, 2012 at 10:55 AM
    waheed
    Waheed
    Vancouver
    Canadian Taco here, there is NO sliding this baby up, the two plastic screws on bottom of gril on inside the heads are facing OUTSIDE so I can't get to it, GET IT, the plastic screw heads hidden by freakin design, THERE has got to be a thread about this on this site.
  5. Nov 3, 2012 at 10:58 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    pictures. All taco's were built the same. It is very simple to pull it up.
  6. Nov 3, 2012 at 10:59 AM
    Haslefre
    Brady
    TN
    2019 Tundra
  7. Nov 3, 2012 at 11:20 AM
    waheed
    Waheed
    Vancouver
    THE top one in BIG green circle, I thought I had to remove that in order to remove grill :D ROOKIE MISTAKE, so bro, you saying that all I need to do is remove the TWO metal bolts TWO plastic tabs/screws on tap then PULL the grill UP to take it off................Thanks :thumbsup:
  8. Nov 3, 2012 at 11:31 AM
    waheed
    Waheed
    Vancouver
    Thanks for the advice bro, let me know when you in Vancouver, I'll return the favor :D:canada::rasta:
  9. Nov 3, 2012 at 11:32 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    After you have the 4 on top removed, just pull straight up. Just be careful the bottom ones easily break. I broke them on my stock grill. Although it didn't seem to effect the grill being held snugly in place. Was more careful with my Satoshi not to break the bottom ones on this.
  10. Nov 3, 2012 at 11:34 AM
    waheed
    Waheed
    Vancouver
  11. Nov 3, 2012 at 11:34 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Mine slides straight up
    Remove the two top bolts and the two pins , pull straight up
    The first time I did it I was suprised at how hard I had to pull
  12. Nov 3, 2012 at 11:35 AM
    waheed
    Waheed
    Vancouver
    I hear yaa buddy, took some time but I figured it out, I'm NOT a one trick pony :cheers::rasta:
  13. Nov 3, 2012 at 11:37 AM
    waheed
    Waheed
    Vancouver
    I tell you WHY it's HARD to pull, because there are two little TAB kinda thingie down there, you gotta squeeze the head it looks like a upside down V, THEN IT SLIDES OUT LIKE KNIFE THRU BUTTER :D
  14. Nov 3, 2012 at 11:40 AM
    waheed
    Waheed
    Vancouver
    how are you my Canadian friend....I'm in Surrey, you close, I'm assuming...I could use a local Taco expert :canada::thumbsup:
  15. Nov 3, 2012 at 11:40 AM
    OZ-T
    Peter North
    British Columbia
    Yes I know , I've taken mine of and on a few times
  16. Nov 3, 2012 at 11:41 AM
    OZ-T
    Peter North
    British Columbia
    Me too , let me know when you find one
  17. Nov 3, 2012 at 11:41 AM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I sprayed some White Lube in the two tab "sockets" at the bottom for the next time.
    Be sure to use something that's gonna stay pliable and not gonna freeze
    My grill's been in and out some 25+ times.
    Always expect one of those tabs to break, but so far so good.
    EDIT: something that's gonna stay liquid and not gum up below freezing, would be a better description
    CC
  18. Nov 4, 2012 at 10:01 AM
    waheed
    Waheed
    Vancouver
    I was refering to your majesty :)
