How To: Remove 2012 Grille.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ajan246, Mar 20, 2012.
  1. Mar 20, 2012 at 10:31 PM
    ajan246
    ajan246 [OP] Well-Known Member
    Orange County, CA
    2012 Access PreRunner V6 2WD
    So I decided to plasti-dip my front grille and thought i'd make a quick write up on removing the 2012 grille since I couldn't find one on here. It is very simple but I figure this might help someone.
    There are 2 screws and 5 clips that hold the front grille on. To remove the clips you just simply get a thin flat head screw driver and pry up. Once the center part of the clip pushes up you can pull out the clip. Once the screws and clips are out just gently slide the grille out of its slots.
    The two screws (sorry for glowing micro-fiber):
    The top two clips:
    Passenger side:
    Driver side:
    The bottom three clips (I took these pictures with the grille removed just to show the location.):
    The middle one is a little difficult to get to. I found that if you get the top two clips and screws out you can sort of bend the grille backwards and pop out this clip.
    ... and Voila!
    ...and the finished plasti-dipped grille:
    Hope this helps!
    -ajan246
    robm7 and ChadsPride like this.
  2. Mar 20, 2012 at 10:36 PM
    Hiker
    Hiker Well-Known Member
    HotZona
    Was the grill originally chrome? If you could get the lower bumper to match, it might look pretty smooth..
  3. Mar 20, 2012 at 10:39 PM
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
    thanks for the write up.
  4. Mar 20, 2012 at 10:40 PM
    ajan246
    Orange County, CA
    Original grill:
    I'm wondering if you can spray paint on top of plasti-dip to match the color of the lower bumper and still be able to peel it off if you ever want to. Either that or i'm just gonna buy a color matched grille surround...
    ChadsPride likes this.
  5. Apr 6, 2012 at 10:17 AM
    west
    west Active Member
    West
    Houston, TX
    2012 Access Cab SR5
    I did all that and I cannot get it off!! Im afraid im going to break something if I pull any harder! Is there a trick to pulling it out?
  6. Apr 6, 2012 at 10:20 AM
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4
    There's two tabs on the ends of the grill that need to be pushed out. Just slight pull and she should come out.
  7. Apr 6, 2012 at 4:34 PM
    west
    west Active Member
    West
    Houston, TX
    2012 Access Cab SR5
    thx I got it, just had to wiggle it a lot
  8. Apr 6, 2012 at 7:39 PM
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    it was a bitch to get mine off. i went from a chrome one (off road package ) to a black one (sport package) and looked easy enough at first, undo two screws and pull right?
    it snaps out alright, but not without thinking you're about to snap the whole thing in half.
    the trick was to start pulling on the lower corner of one side until the main snap snaps out an then just do a sort of zipper effect al the way down the line
  9. May 17, 2012 at 5:17 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    replaced mine with a color-matched grille today, thank you for the write-up! :D
  10. May 17, 2012 at 5:31 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    Nice job OP. :thumbsup:
  11. May 18, 2012 at 10:34 AM
    zeecue
    zeecue Active Member
    Zac
    Arkansas
    12 PreRunner SR5
    Tinted Windows
    where are ya'll getting the '12 color matched body grilles?
  12. May 18, 2012 at 10:37 AM
    MYT4CO
    MYT4CO Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    +1 thanx for the write up, gonna need it when i get my grillcraft!
  13. May 18, 2012 at 10:44 AM
    6spd
    6spd Well-Known Member
    san diego
    2012 4x4
    nice! I would have swapped with you, as I have the chrome grill, and I would have rather preferred a basic black grill. shucks
  14. May 18, 2012 at 10:58 AM
    spins615
    spins615 Well-Known Member
    Mark
    Eastern PA
    12 TRD Sport
    i believe its just the top 2 tabs that need to be pulled..at least thats what i had to do on mine..the bottom tabs arent for the grille.
    So the two screws, and the two tabs on top that hold it in.
  15. May 18, 2012 at 3:29 PM
    zul
    PNW
    I emailed several local dealers and one of them got back to me about ordering & selling it to me. It was the same place I bought the truck, Vancouver Toyota. The parts manager was very helpful - he offered a competitive price right from the get-go (not as good as some of the online retailers, but I didnt have to have it shipped) and he kept me up to date throughout the process. Even made sure I had the part number correct (53100-04480-E0 for Pyrite Mica).
    He ships stuff too, but that will probably cost a little more - email Mark Sherman at msherman@vancouvertoyota.com. And no I dont work there, I just like to promote honest helpful people.
  16. May 18, 2012 at 3:33 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    I helped a local member do the BHLM and had never taken a 12 grill off before, with the 05-11's it takes like a minute, it took me a few though with the 12's lol....
    OP you need to do the BHLM its looks great on the 2012's
  17. May 23, 2012 at 2:49 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '12 DCSB 4x4 SR5
    Looks like I need to form a taco meet just a dang 12 grille off...everything went smoothly till no matter what i could not get the tabs to release..me and my dad tried to wiggle it around and such but no luck...UGH..i love the tabs..easily reusable :)
  18. May 23, 2012 at 3:54 PM
    spins615
    Mark
    Eastern PA
    12 TRD Sport
    Are you talking about these clips? Or the clips that are on the bottom of the grille inside engine bay?
    The ones in the engine bay are a little of a pain to get out. I found it easy if you pull it forward a little and putyourfingers in front of them by the light, and pull forward there. I'll try to post a picture of what I mean..I've taken mine off..prolly..15-20 times already? Headlights..horn..more headlights..yoda horns..yoda horns again.. :) I'm beginning to be a pro at taking the grille off :)
  19. May 23, 2012 at 3:56 PM
    neonlazer
    Lafayette, LA
    '12 DCSB 4x4 SR5
    The two screws and 5 clips were piece of cake. The clips on the bottom on the inside..i see two large clips on the ends. Looks as if they should be pushed down but wont move..there seems to be like 3 or so smaller clips under the lip of the grill..but nothing seems to come loose from the bumper.
  20. May 23, 2012 at 4:32 PM
    spins615
    Mark
    Eastern PA
    12 TRD Sport
    Those 8 clips with red arrows to them don't need to be removed..at least for me they don't lol. i removed the two screws and the two clips..then pull the grille right off...unless (being an engineer) I reengineered it to make it easier on myself :D which could be the case haha
    These are the clips that I'm referring to being a biotch to get through the slot so the grille comes off easily.
    Driver side:
    Passenger side:
    here's what I'm talking about pulling the front off..
    Put your hand behind the grille and pull the forward like so :)
    Driver side:
    Passenger Side:
